Текущее время: 23 ноя 2026, 16:09
MoneyBot
Заголовок сообщения: Gtx 1060 6gb. Частота gpu |
MoneyBot
evgenius
Заголовок сообщения: Re: Gtx 1060 6gb. Частота gpu  Добавлено: 07 ноя 2021, 12:53 |
| Интересующийся |
Сообщения: 57 Откуда: Гомель
добавил тест 94 на 105% и 110% dramclk тест 178 на 100% dramclk
MODS start: Sun Nov 7 11:15:56 2021
Command Line : gputest.js -oqa -old_gold -test 94 -fan_speed 70 -dramclk_percent 105 -ignore_fatal_errors -run_on_error -matsinfo
CPU Foundry : GenuineIntel Name : Intel(R) Pentium(R) CPU G2020 @ 2.90GHz Family : 6 Model : 10 Stepping : 9
Version MODS : 367.106 OperatingSystem: Linux (x86_64) Kernel : 4.1.2-gentoo KernelDriver : 3.63 HostName : tinylinux Sys-uuid : 29F27B40-D7DA-11DD-8DE4-08606E75DAC2
GPU 0 [01:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x00000000011f904000000030b8411191 Raw ECID (GHS) : 0x000000016430b8411000000001fc8200 ECID : PCBX14-01_x-7_y08 Device Id : GP106 Revision : a1 NV Base : 0xf6000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Display::Initialize: Faked EDID on display 0x100. Raw ECID (RM) : 0 Setting Fan of GPU 0 [01:00.0] to 70% Foundry : TSMC Subsystem VID : 0x1458 Subsystem DID : 0x374a Board ID : 0xef18 Chip SKU : 410-0 Project : G410-0040 Fuse File Fmt : JSON Display : 0x000100 VGA adapter : Secondary Native Mode : 1024x768 Memory Size : 6144 MB RAM Protocol : GDDR5 RAM Config : 1 ROM Version : 86.06.4b.00.32 ROM Type : Partner Production ROM OEM Vendor : Gigabyte ROM Timestamp : 2017-3-21 02:43:58 PState (mode) : 8 5 2 [0] PState Version : 3.0 EDC : Disabled GPC Clock : 2012.0/2012.4 MHz DEFAULT DRAM Clock : 4738.5/4738.5 MHz MPLL Host Clock : 833.3/833.3 MHz XCLK3XDIV2 XBar Clock : 1847.5/1885.8 MHz DEFAULT Sys Clock : 1708.5/1746.6 MHz DEFAULT Power Clock : 540.0/540.0 MHz SPPLL0 Display Clock : 1325.0/1325.0 MHz DISPPLL NVVDD : 1043 mV GPC Mask : 0x03 (2 GPCs) TPC Mask : [1f 1f] (10 TPCs) FB Mask : 0x07 (3 FB Partitions) ROP/L2 Mask : [3 3 3] (6 ROP/L2s) PES Mask : [7 7] (6 PESes) FBIO Mask : 0x07 (3 FBIO Partitions) FBIO Shift Mask: 0x00 XP Mask : 0x03 (2 3gio Pads) Nvdec Mask : 0x01 (1 engine) Nvenc Mask : 0x01 (1 engine) Gpu Temp : 32 deg C PEX Rx Lanes : 0xffff PEX Tx Lanes : 0xffff PEX Width, ASLM: 16 lanes, Not Supported PEX Link Speed : 5.0 Gbit/s PEX BandWidth : 80.0 Gbit/s ASPM, ASPM-CYA : (L0s/L1, Disabled) ASPM L1SS, CYA : (Disabled, L1.1/L1.2) LTR : Disabled
Chipset VID : 8086 (Intel) DID : 1C10 (IntelP67) Chipset ASPM : L0s/L1
gldGP106.bin was generated by MODS version 367.38, expected 367.106. Ignoring golden file mismatch RM Version : rel/gpu_drv/r367/r367_00-1613 gputest.js : 82 oqa.spc : 6 boards.js : 7
Running test(s) on GP106 (GPU 0 [01:00.0] DID: 0x1c03) Enter JsGpuTest.SetPState (test 0) Switched to PState 0 (0.max). Pcie Speed=5000, x16 ClkM = 4738.50 MHz ClkHost = 833.33 MHz ClkDisp = 1325.00 MHz ClkPA = 65.00 MHz ClkPB = 27.00 MHz ClkGpc = 2012.00 MHz ClkXbar = 1847.50 MHz ClkSys = 1708.50 MHz ClkHub = 648.00 MHz ClkUtilS = 108.00 MHz ClkPwr = 540.00 MHz NVVDD = 1043 mV Exit 000000000000 : JsGpuTest.SetPState (test 0) ok Enter NewWfMatsTest.Run (test 94) NewWfMats Memory Errors Read Error Count: 0 Write Error Count: 0 Unknown Error Count: 14
=== MEMORY ERRORS BY SUBPARTITION === SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS ------- ----------- ------------ ------------ FBIOA0 0 0 4 FBIOA1 0 0 0 FBIOB0 0 0 0 FBIOB1 0 0 0 FBIOC0 0 0 10 FBIOC1 0 0 0
Failing Bits: A023 A029 A031 C016 C022 C027 C029
=== MEMORY ERRORS BY ADDRESS === ADDRESS : Failing memory address, or buffer offset if starting with 'X+' P : Partition (FBIO) S : Subpartition E : Beat ADDRESS EXPECTED ACTUAL PSE BIT(s) PATTERN OFFSET ------- -------- ------ --- ------ ------- ------ X+ad365a2c e3962452 e3972452 C03 C016 RandomPattern 0x144 X+7786823c 4bff8dfb 4bbf8dfb C07 C022 RandomPattern 0x54 X+7787f7dc eb29f2b0 e329f2b0 C07 C027 RandomPattern 0x11c X+d9c061fc 00000000 80000000 A07 A031 TripleSuper 0x4 X+eae22dac 4bff8dfb 4bbf8dfb C03 C022 RandomPattern 0x54 X+3d3577bc 4bff8dfb 4bbf8dfb C07 C022 RandomPattern 0x54 X+161e0011c eb29f2b0 e329f2b0 C07 C027 RandomPattern 0x11c X+5804cebc 501a51bd 701a51bd C07 C029 RandomPattern 0x74 X+e236963c eb29f2b0 e329f2b0 C07 C027 RandomPattern 0x11c X+e71129ec fffbffff 7f7bffff A03 A023,A031 SlowRising 0xdc X+e713606c ffffffff 5f7fffff A03 A023,A029,A031 SuperZeroOne 0x3c X+e71395fc ffffffff 7fffffff A07 A031 TripleSuper 0x14 X+e7102a1c eb29f2b0 e329f2b0 C07 C027 RandomPattern 0x11c X+e713a13c 4bff8dfb 4bbf8dfb C07 C022 RandomPattern 0x54 NewWfMats "Post-Run" callback failed (bad memory). NewWfMats POST_RUN callbacks failed. Exit 020000094194 : NewWfMatsTest.Run (test 94) bad memory Error! GPU tests completed. Error 000000000194 : Object.RunGpuTests bad memory
Failure(s) : LOOP TEST CODE MESSAGE ---- ------------------------ ------------ --------------------------- 1 NewWfMats 020000094194 bad memory
Error Code = 020000094194 (bad memory)
MODS end : Sun Nov 7 11:16:20 2021 [24.877 seconds (00:00:24.877 h:m:s)]
MODS start: Sun Nov 7 11:05:12 2021
Command Line : gputest.js -oqa -old_gold -test 94 -fan_speed 70 -dramclk_percent 110 -ignore_fatal_errors -run_on_error -matsinfo
GPU 0 [01:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x00000000011f904000000030b8411191 Raw ECID (GHS) : 0x000000016430b8411000000001fc8200 ECID : PCBX14-01_x-7_y08 Device Id : GP106 Revision : a1 NV Base : 0xf6000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Display::Initialize: Faked EDID on display 0x100. Raw ECID (RM) : 0 Setting Fan of GPU 0 [01:00.0] to 70% Foundry : TSMC Subsystem VID : 0x1458 Subsystem DID : 0x374a Board ID : 0xef18 Chip SKU : 410-0 Project : G410-0040 Fuse File Fmt : JSON Display : 0x000100 VGA adapter : Secondary Native Mode : 1024x768 Memory Size : 6144 MB RAM Protocol : GDDR5 RAM Config : 1 ROM Version : 86.06.4b.00.32 ROM Type : Partner Production ROM OEM Vendor : Gigabyte ROM Timestamp : 2017-3-21 02:43:58 PState (mode) : 8 5 2 [0] PState Version : 3.0 EDC : Disabled GPC Clock : 2012.0/2012.0 MHz DEFAULT DRAM Clock : 4959.0/4959.0 MHz MPLL Host Clock : 833.3/833.3 MHz XCLK3XDIV2 XBar Clock : 1847.5/1885.9 MHz DEFAULT Sys Clock : 1708.5/1746.6 MHz DEFAULT Power Clock : 540.0/540.0 MHz SPPLL0 Display Clock : 1325.0/1325.0 MHz DISPPLL NVVDD : 1043 mV GPC Mask : 0x03 (2 GPCs) TPC Mask : [1f 1f] (10 TPCs) FB Mask : 0x07 (3 FB Partitions) ROP/L2 Mask : [3 3 3] (6 ROP/L2s) PES Mask : [7 7] (6 PESes) FBIO Mask : 0x07 (3 FBIO Partitions) FBIO Shift Mask: 0x00 XP Mask : 0x03 (2 3gio Pads) Nvdec Mask : 0x01 (1 engine) Nvenc Mask : 0x01 (1 engine) Gpu Temp : 32 deg C PEX Rx Lanes : 0xffff PEX Tx Lanes : 0xffff PEX Width, ASLM: 16 lanes, Not Supported PEX Link Speed : 5.0 Gbit/s PEX BandWidth : 80.0 Gbit/s ASPM, ASPM-CYA : (L0s/L1, Disabled) ASPM L1SS, CYA : (Disabled, L1.1/L1.2) LTR : Disabled
Running test(s) on GP106 (GPU 0 [01:00.0] DID: 0x1c03) Enter JsGpuTest.SetPState (test 0) Switched to PState 0 (0.max). Pcie Speed=5000, x16 ClkM = 4959.00 MHz ClkHost = 833.33 MHz ClkDisp = 1325.00 MHz ClkPA = 65.00 MHz ClkPB = 27.00 MHz ClkGpc = 2012.00 MHz ClkXbar = 1847.50 MHz ClkSys = 1708.50 MHz ClkHub = 648.00 MHz ClkUtilS = 108.00 MHz ClkPwr = 540.00 MHz NVVDD = 1043 mV Exit 000000000000 : JsGpuTest.SetPState (test 0) ok Enter NewWfMatsTest.Run (test 94) NewWfMats Memory Errors Read Error Count: 0 Write Error Count: 2162 Unknown Error Count: 1970609
=== MEMORY ERRORS BY SUBPARTITION === SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS ------- ----------- ------------ ------------ FBIOA0 0 1956 1000000 FBIOA1 0 167 812924 FBIOB0 0 0 109469 FBIOB1 0 0 176 FBIOC0 0 39 48040 FBIOC1 0 0 0
Failing Bits: A000 A001 A002 A003 A004 A005 A006 A007 A008 A009 A010 A011 A012 A013 A014 A015 A016 A017 A018 A019 A020 A021 A022 A023 A024 A025 A026 A027 A028 A029 A030 A031 A032 A033 A034 A035 A036 A037 A038 A039 A040 A041 A042 A043 A044 A045 A046 A047 B016 B017 B018 B019 B020 B021 B022 B023 B024 B025 B026 B027 B028 B029 B030 B031 B036 B037 B039 B040 B041 B042 B043 B045 B046 B047 B050 B052 B055 B056 B059 B060 B062 B063 C000 C001 C002 C003 C004 C005 C006 C007 C008 C009 C010 C011 C012 C013 C014 C015 C016 C017 C018 C019 C020 C021 C022 C023 C024 C025 C026 C027 C028 C029 C030 C031
=== MEMORY ERRORS BY ADDRESS === ADDRESS : Failing memory address, or buffer offset if starting with 'X+' T : Type of memory error: W = write, R = read P : Partition (FBIO) S : Subpartition B : Bank E : Beat ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPSBE ROW COL BIT(s) ------- -------- ------ ------- ------- -------- ----- --- --- ------ 00863fcffc ffffffff 465effff 465effff 465effff b9a10000 WA057 165f 07d A016,A021,A023,A024,A027,A028,A029,A031 00863fcfec ffffffff 4618ffff 4618ffff 4618ffff b9e70000 WA053 165f 07d A016,A017,A018,A021,A022,A023,A024,A027,A028,A029,A031 00863fcf7c ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA057 165f 07b A023 00863fa3dc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WC057 165f 04c C023 00863fa35c ffffffff f77fffff f77fffff f77fffff 08800000 WC057 165f 04a C023,C027 00863f8dec ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA053 165f 05d A023,A031 00863f8ddc ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA057 165f 05c A023,A031 00863f8dcc ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA053 165f 05c A023,A031 00863f8d5c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA057 165f 05a A023,A031 00863f8cec ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA053 165f 055 A023,A031 00863f8ccc ffffffff 567fffff 567fffff 567fffff a9800000 WA053 165f 054 A023,A024,A027,A029,A031 00863f8c7c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA057 165f 053 A023,A031 00863f8c6c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA053 165f 053 A023,A031 00863f8c5c ffffffff 577fffff 577fffff 577fffff a8800000 WA057 165f 052 A023,A027,A029,A031 00863f8c4c ffffffff 577fffff 577fffff 577fffff a8800000 WA053 165f 052 A023,A027,A029,A031 00863ef25c ffffffff 7fffffff 7fffffff 7fffffff 80000000 WA067 165f 072 A031 00863eb5ec ffffffff ffffff7f ffffff7f ffffff7f 00000080 WA163 165f 05d A039 00863dfbdc ffffffff 7fffffff 7fffffff 7fffffff 80000000 WA077 165f 06c A031 00863dfb7c ffffffff 6fffffff 6fffffff 6fffffff 90000000 WA077 165f 06b A028,A031 00863dfb5c ffffffff 7fffffff 7fffffff 7fffffff 80000000 WA077 165f 06a A031 00863df95c ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA077 165f 07a A023 00863db9ec ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA073 165f 04d A023,A031 00863d46ec ffffffff 575fffff 575fffff 575fffff a8a00000 WA043 165f 065 A021,A023,A027,A029,A031 00863d467c ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA047 165f 063 A023 00863d45fc ffffffff 5f7fffff 5f7fffff 5f7fffff a0800000 WA047 165f 07d A023,A029,A031 00863d456c ffffffff 5f1fffff 5f1fffff 5f1fffff a0e00000 WA043 165f 07b A021,A022,A023,A029,A031 00863d44cc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA043 165f 074 A023 00863d445c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA047 165f 072 A023,A031 00863d444c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA043 165f 072 A023,A031 00863d075c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA047 165f 05a A023,A031 00863d06ec ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA043 165f 055 A023,A031 00863d067c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA047 165f 053 A023,A031 00863d066c ffffffff 7f7fffff 7f7fffff 7f7fffff 80800000 WA043 165f 053 A023,A031 00863cd7fc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA057 165f 02d A023 00863cd7ec ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA053 165f 02d A023 00863c97dc ffffffff 7fffffff 7fffffff 7fffffff 80000000 WA057 165f 01c A031 00863c975c ffffffff 46ffffff 46ffffff 46ffffff b9000000 WA057 165f 01a A024,A027,A028,A029,A031 00863c9758 ffffffff f7ffffff f7ffffff f7ffffff 08000000 WA056 165f 01a A027 00863c95fc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA057 165f 00d A023 00863c95dc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA057 165f 00c A023 00863c95cc ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA053 165f 00c A023 00863c957c ffffffff ff7fffff ff7fffff ff7fffff 00800000 WA057 165f 00b A023 016a3f52fc ffffffff 461affff 461affff 461affff b9e50000 WA057 3c5f 075 A016,A018,A021,A022,A023,A024,A027,A028,A029,A031 016a3f52ec ffffffff 0000ffff 0000ffff 0000ffff ffff0000 WA053 3c5f 075 A016,A017,A018,A019,A020,A021,A022,A023,A024,A025,A026,A027,A028,A029,A030,A031 016a3f52e8 ffffffff e7f7ffff e7f7ffff e7f7ffff 18080000 WA052 3c5f 075 A019,A027,A028 016a3f52cc ffffffff 5f7fffff 5f7fffff 5f7fffff a0800000 WA053 3c5f 074 A023,A029,A031 016a3f527c ffffffff 0000ffff 0000ffff 0000ffff ffff0000 WA057 3c5f 073 A016,A017,A018,A019,A020,A021,A022,A023,A024,A025,A026,A027,A028,A029,A030,A031 016a3f5278 ffffffff f777ffff f777ffff f777ffff 08880000 WA056 3c5f 073 A019,A023,A027 016a3f526c ffffffff 0000ffff 0000ffff 0000ffff ffff0000 WA053 3c5f 073 A016,A017,A018,A019,A020,A021,A022,A023,A024,A025,A026,A027,A028,A029,A030,A031 016a3f5268 ffffffff e777ffff e777ffff e777ffff 18880000 WA052 3c5f 073 A019,A023,A027,A028 NewWfMats "Post-Run" callback failed (bad memory). NewWfMats POST_RUN callbacks failed. Exit 020000094194 : NewWfMatsTest.Run (test 94) bad memory Error! GPU tests completed. Error 000000000194 : Object.RunGpuTests bad memory
MODS end : Sun Nov 7 11:05:40 2021 [28.654 seconds (00:00:28.654 h:m:s)]
MODS start: Sun Nov 7 10:49:41 2021
Command Line : gputest.js -oqa -old_gold -test 178 -fan_speed 70 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -matsinfo
GPU 0 [01:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x00000000011f904000000030b8411191 Raw ECID (GHS) : 0x000000016430b8411000000001fc8200 ECID : PCBX14-01_x-7_y08 Device Id : GP106 Revision : a1 NV Base : 0xf6000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Display::Initialize: Faked EDID on display 0x100. Raw ECID (RM) : 0 Setting Fan of GPU 0 [01:00.0] to 70% Foundry : TSMC Subsystem VID : 0x1458 Subsystem DID : 0x374a Board ID : 0xef18 Chip SKU : 410-0 Project : G410-0040 Fuse File Fmt : JSON Display : 0x000100 VGA adapter : Secondary Native Mode : 1024x768 Memory Size : 6144 MB RAM Protocol : GDDR5 RAM Config : 1 ROM Version : 86.06.4b.00.32 ROM Type : Partner Production ROM OEM Vendor : Gigabyte ROM Timestamp : 2017-3-21 02:43:58 PState (mode) : 8 5 2 [0] PState Version : 3.0 EDC : Disabled GPC Clock : 2012.0/2012.2 MHz DEFAULT DRAM Clock : 4513.5/4513.5 MHz MPLL Host Clock : 833.3/833.3 MHz XCLK3XDIV2 XBar Clock : 1847.5/1847.8 MHz DEFAULT Sys Clock : 1708.5/1708.5 MHz DEFAULT Power Clock : 540.0/540.0 MHz SPPLL0 Display Clock : 1325.0/1325.0 MHz DISPPLL NVVDD : 1043 mV GPC Mask : 0x03 (2 GPCs) TPC Mask : [1f 1f] (10 TPCs) FB Mask : 0x07 (3 FB Partitions) ROP/L2 Mask : [3 3 3] (6 ROP/L2s) PES Mask : [7 7] (6 PESes) FBIO Mask : 0x07 (3 FBIO Partitions) FBIO Shift Mask: 0x00 XP Mask : 0x03 (2 3gio Pads) Nvdec Mask : 0x01 (1 engine) Nvenc Mask : 0x01 (1 engine) Gpu Temp : 31 deg C PEX Rx Lanes : 0xffff PEX Tx Lanes : 0xffff PEX Width, ASLM: 16 lanes, Not Supported PEX Link Speed : 5.0 Gbit/s PEX BandWidth : 80.0 Gbit/s ASPM, ASPM-CYA : (L0s/L1, Disabled) ASPM L1SS, CYA : (Disabled, L1.1/L1.2) LTR : Disabled
Running test(s) on GP106 (GPU 0 [01:00.0] DID: 0x1c03) Enter JsGpuTest.SetPState (test 0) Switched to PState 0 (0.max). Pcie Speed=5000, x16 ClkM = 4513.50 MHz ClkHost = 833.33 MHz ClkDisp = 1325.00 MHz ClkPA = 65.00 MHz ClkPB = 27.00 MHz ClkGpc = 2012.00 MHz ClkXbar = 1847.50 MHz ClkSys = 1708.50 MHz ClkHub = 648.00 MHz ClkUtilS = 108.00 MHz ClkPwr = 540.00 MHz NVVDD = 1043 mV Exit 000000000000 : JsGpuTest.SetPState (test 0) ok Enter NewWfMatsTest.NewWfMats_RunBgStress (test 178) WfMatsBgStress started bg thread 19 Syncing Setup() functions between GLStress and WfMatsBgStress Enter GLStressTest.Run (test 2) Bps: 150.6352 GB read or written per second (3935.3057 GB in 26.125 sec) Bps: 69.5% percent of raw FB bw (216.6480 GB per second) WARNING: Errors found, but GLStress can't decode FB offsets because the primary surface is at an undisclosed location. GLStress Memory Errors Read Error Count: 0 Write Error Count: 0 Unknown Error Count: 770980
=== MEMORY ERRORS BY SUBPARTITION === SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS ------- ----------- ------------ ------------ FBIOA0 0 0 0 FBIOA1 0 0 0 FBIOB0 0 0 0 FBIOB1 0 0 0 FBIOC0 0 0 0 FBIOC1 0 0 0
Failing Bits: None Background GLStress on dev 0 completed 1390000 frames. dev 0: GLStress 1390000 Frames, DrawPct 100.0, avg Watts 47.403, max Watts 80.318. INPUT_PEX12V avg Watts 14.105, max Watts 20.161 INPUT_EXT12V_8PIN0 avg Watts 32.724, max Watts 59.630 INPUT_PWR_SRC_PP avg Watts 1.968, max Watts 2.271 OUTPUT_NVVDD avg Watts 57.449, max Watts 95.202 GLStress "Post-Run" callback failed (gpu stress test found pixel miscompares). GLStress POST_RUN callbacks failed. Exit 020000002582 : GLStressTest.Run (test 2) gpu stress test found pixel miscompares Error! Error 020000002582 : Object.WfMatsBgStress_Thread gpu stress test found pixel miscompares Error 020000178582 : NewWfMatsTest.WfMatsBgStress_POST_CLEANUP (test 178) gpu stress test found pixel miscompares WfMatsBgStress "Post-Cleanup" callback failed (gpu stress test found pixel miscompares). WfMatsBgStress Cleanup failed. Error 020000178582 : NewWfMatsTest.RunLiveFbioTuning (test 178) gpu stress test found pixel miscompares Exit 020000178582 : NewWfMatsTest.NewWfMats_RunBgStress (test 178) gpu stress test found pixel miscompares Error! GPU tests completed. Error 000000000582 : Object.RunGpuTests gpu stress test found pixel miscompares
Failure(s) : LOOP TEST CODE MESSAGE ---- ------------------------ ------------ --------------------------- 1 WfMatsBgStress 020000178582 gpu stress test found pixel miscompares
Error Code = 020000002582 (gpu stress test found pixel miscompares)
MODS end : Sun Nov 7 10:50:20 2021 [39.526 seconds (00:00:39.526 h:m:s)]
Pandemonium6
Заголовок сообщения: Re: Gtx 1060 6gb. Частота gpu  Добавлено: 09 ноя 2021, 09:20 |
| Продвинутый форумчанин |
Зарегистрирован: 22 июл 2021, 02:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
This is an error of your measurement. Remove the ground crocodile and its wire and tough the scope probe directly to the output capacitor using paper clip method: https://i.stack.imgur.com/7OPgl.jpgYou make a ground loop and you measure the drop over the ground. And increase bandwidth of your scope, set it to full 100MHz (if your scope is 100MHz). Set it to full because inductor PWM pulses look rounded, you don't see inductive spikes and ringing.
