You need tserver and a little skill to use it. First download it, put on the hard disk. But it may not give you immediate answer. I had two R9 390 cards in a row with artifacts and replacing memory chips did not help after pinpointing them by tserver. I reflowed both and they are good for now. Furmark works, mining works, the owner is happy.
crocodile70
Заголовок сообщения: Re: R 9 380 4gb tserver
Добавлено: 05 ноя 2021, 04:58
Зарегистрирован: 31 май 2020, 23:55 Наличности на руках: 424.63 Сообщения: 633 Откуда: Украина Днепр
