Заголовок сообщения: Hp14s-dq1508sa (Quanta PAD DA0PADMB8F1 rev:F ) not turn on power led flashing
Добавлено: 10 ноя 2021, 00:46
Зарегистрирован: 22 мар 2020, 01:34 Наличности на руках: 10.01 Сообщения: 5 Откуда: Lurgan
Laptop Hp14s-dq1508sa Quanta PAD DA0PADMB8F1 rev:F Intel i3-1005G1 KBC: IT5570E-128
The laptop does not power up. After connection power cable led beside the charging port light in white color power consumption 0,010A. After pressing the power button, the power led starts blinking with led beside the charging port and motherboard restarting with 2s intervals power consumption increasing to 0,060mA and dropping to 0,010mA again. There is no diagram for this motherboard also no marking on the motherboard very difficult to recognize chips also all chips on the motherboard have custom marking. below are attached pictures of the motherboard with attached measurement. I was able to recognize a couple of chips on the motherboard tracing the pinout and compare them with the datasheets. I tried reprogramming the KBC chip without a result. Did not program bios yet cannot get the bios file for this motherboard. I desolder bios chip to download bios file. tried turning on the motherboard without bios chip the motherboard is the same reaction with or without bios chip. The 3.3V and 5V are present on the board after pressing the power button Maybe one of you guys had a similar issue with the same laptop, please help. I would be grateful if someone shared a bios file for this motherboard.
Rein
Заголовок сообщения: Re: Hp14s-dq1508sa (Quanta PAD DA0PADMB8F1 rev:F ) not turn on power led flashing
Hi, try to take bios from HP website and make a recovery image. Then use Win+B. Check your dumped bios file for $bid signature.
kamil1986
Добавлено: 11 ноя 2021, 14:18
I tried different bios does not help the same issue motherboard restarting in 2s intervals. 19V, 3.3V, and 5V Ldo are present on the motherboard I am not sure what is the chip QqCCj I can`t find any information about this chip, but on this chip, 3.3V nad 5V is present when I connect the power supply to the mother. After pressing, the power button 3.3V is present on the coil beside chip QqCCj. when the motherboard restarts all voltages except 19V 3.3Ldo and 5Ldo drop to 0V.
Sashamarzor
Добавлено: 11 ноя 2021, 20:42
Зарегистрирован: 18 сен 2020, 22:47 Наличности на руках: 46.05 Сообщения: 69 Откуда: Moscow
пожалуйста, обеспечьте сопротивление на всех катушках 3,3 В 5в 1.8 alv первичный (крошечная катушка на задней панели) 1,8 в vccin_aux 1.8v vccin ... это процессор g 10 поколения так что последовательность мощности следующая 19v 3,3 В 5в 1,8 v alw prim 1,8 в vcc_aux 1.05 vcc_st 1.2 ddr4 1.8 vcc_core проверьте, есть ли у вас 1.8v alw prim (крошечная катушка на задней панели платы)
kamil1986
Добавлено: 11 ноя 2021, 22:57
Hi, This is the 10th generation of intel CPU. Could you advise what motherboard is similar to this one with the available diagram. Every chip on this motherboard has a custom marking, there is no information on google about these chips. With a similar diagram, I will be able to recognize chips following the pinouts.
In which area of motherboard I should focus to find 1,8 vcc_aux and 1.05 vcc_st
Measurement below. In the pictures coils numbers.
Coil-1 84Ω no voltage is present after pressing the power button Coil-2 228Ω 1,8V is present in 2s intervals after pressing the power button Coil-3 325Ω no voltage is present after pressing the power button I think this is a coil for 1.2ddr4 Coil-4 45kΩ 5V is present in 2s intervals after pressing the power button Coil-5 2.5kΩ 3.3V is present in 2s intervals after pressing the power button Coil-6 575Ω 1,8V is present in 2s intervals after pressing the power button I think this is a coil for 1,8 v alw prim
Sashamarzor
Добавлено: 12 ноя 2021, 00:35
катушка 2 vccin_aux сопротивление в порядке катушка 5 (3.3в) 2.5хом вроде на низком уровне проверьте 3,3 лдо (напряжение и сопротивление) подача 3,3 В от источника питания скамьи к катушке 3 (3,3 В) сообщать о текущем потреблении, проверять тепловизионную камеру, если что-то нагревается схема для 10ген л.с. отсутствует vcc_st поступает напрямую от процессора, единственный способ узнать, где проверить, - это удалить процессор и перевести панель vcc_st визуально осмотреть материнскую плату под микрофоном, платы hp 10 поколения и очень плохо сделанные поиск недостающих элементов smd
kamil1986
Добавлено: 12 ноя 2021, 20:33
Hi, I performed a short circuit test at coil 5, unfortunately, one corner of APU starts to heat up. In my opinion, the CPU is damaged.
Сейчас этот форум просматривают: tskremus и гости: 106
