Текущее время: 06 ноя 2026, 20:48
 Заголовок сообщения: RX580 DRAM_RSTA signal
СообщениеДобавлено: 18 ноя 2020, 04:19
Hello everyone,
So I'm working on a RX580 MSI card and would be nice to have some thoughts about it if anyone had a similar issue before.
There is no MVDD nor VDDCI voltage but there is 1.8v and 0.8v.. applying 1.5v with an external power supply to MVDD the card just works fine. After taking a few measurements at the board, I noticed that the card doesn't allow the 0.8v_PGOOD to rise, and release the EN signal for MVDD PWM and so on.. after changing the 0.8v CI still didn't solved it so after further inspection I noticed that there is a problem with a missing DRAM_RSTA signal, which I just measured in a similar working card, and it's around 0.6v on a base of a transistor (Q1077). Then I noticed that this signal comes straight from the Memory Interface (or memory controller), and couldn't debug it further due to lack of information about the mem interface.
My question is, does this mean I do have an issue with the memory controller or there might be missing some previous signal to the memory controller in order to release the DRAM_RSTA signal? Anyone does have any further information about how this signal is generated by the memory interface? Any help would be appreciated!
Thanks
So, after analyzing further on a working card, the RST signal comes only after the beep and the issue is with PX_EN.. I shouldn't have 0.6v at the third pin of the transistor.. i'll now change my thinking line based on this and update if I get any progress
 Заголовок сообщения: Re: RX580 DRAM_RSTA signal
СообщениеДобавлено: 07 июн 2021, 22:33
Privet, did you find a solution?
СообщениеДобавлено: 18 ноя 2021, 01:48
Did you get any solution I have exactly that problem on two video cards.
СообщениеДобавлено: 18 ноя 2021, 03:40
viewtopic.php?f=48&t=88497&p=902126#p902126
Here is a diagram for your card
СообщениеДобавлено: 19 ноя 2021, 17:52
gpu ( точнее контроллер памяти в нем неисправен) было 2шт gigabyte, замена gpu решает проблему , прибывал принудительно поднимать этот сигнал 43 ошибка видеопамять не определяться
СообщениеДобавлено: 22 мар 2025, 14:32
Здравствуйте. Тоже столкнулся с такой проблемой на Gigabyte RX570. DRAM_RSTA садится на землю процем, поэтому Q1077 не садит базу Q1016b на землю, в следствии чего последний сажает на землю 0.8V_PGOOD и все напряжения кроме 1,8 и 0,8 не стартуют.
Ни чего лучше не придумал, как замкнуть соплёй припоя контакты R1015, который рядом с Q1077. Все напряжения поднялись, карта изображение дала, в винде драйвер встал и всё работает отлично.
СообщениеДобавлено: 08 апр 2026, 08:13
GIGABYTE RX580GAMING-8GD-MI REV 1.1
Сигнал DRAM_RSTA постоянно в нуле. Сигнал PX_EN 3В с копейками.
Соответственно пропадает PEX_VDD_PGOOD и так же пропадают питания ГПУ с видеопамятью. На доли секунды эти питания запускаются и падают в ноль.
Конечно же в такой ситуации частично неисправен ГПУ, так как сигнал DRAM_RSTA выходит с него.
По комментарию выше я переставил резистор R1014 на место R1015.
Видеокарта запустилась и работает стабильно.
В этой теме нет новых непрочитанных сообщений. Замена GPU RX580 на RX480 (ASUS DUAL-RX580-4G)
dyukoldyu
03 май 2021, 17:58
RLS Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Hp 6550b (6050A2326701) 3.3v/5v Entrip signal switching on and off.
scobay
27 фев 2017, 12:19
andromedax Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Sony VPCSA (MBX-237) signal +ECVCC
в форуме Sony
AL._.EX
03 май 2017, 19:51
AL._.EX Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell inspiron 20 3043 (неизвестно) на мониторе No signal
в форуме Dell
seregavlg
27 апр 2019, 15:19
seregavlg Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Запрос дампа на прибор ночного видения Signal N320RT
в форуме Ремонт цифровой фото и видеотехники | Repair of digital photo and video
KSL
11 окт 2019, 18:24
KSL Перейти к последнему сообщению
Сейчас этот форум просматривают: bojfriend, Smxkman и гости: 53
