Текущее время: 22 ноя 2024, 08:39
 Заголовок сообщения: MSI RX580 8GB missing PX_EN
СообщениеДобавлено: 15 окт 2021, 19:31
Hi to all and thanks for your attention
I have this 580 (maybe i can have one working), with all the voltages and resistance in order, but im missing PX_EN and DRAM_RSTA, the gpu goes warm, but i cant reconignize it on windows or other OS.
The seller say goes black some days ago and nothing else, some months ago changed thermal compund (paste and pads).
If anyone can help me i appreciate
PS i dont know if its permitted by rules but i can pay if we can fix it.
many thanks
 Заголовок сообщения: Re: MSI RX580 8GB missing PX_EN
СообщениеДобавлено: 15 окт 2021, 22:12
andreagtr писал(а):
but im missing ... DRAM_RSTA
Look for white capacitors:
СообщениеДобавлено: 15 окт 2021, 22:21
Thanks to your time!
What cap do you mean? Ive tested all the cap near the pcie connector and j read 0.230v for each one...
СообщениеДобавлено: 16 окт 2021, 00:23
Under the red line (on photo).
СообщениеДобавлено: 16 окт 2021, 09:57
I cant see the pic attached... i havent the permission, too young on this forum... im so sorry
Posted after 1 hour 6 seconds:
Ive tryed to test the 2 cap near the q1077, both had one side at ground the big one had other side connected to pin7 of u200 the other one i cant check with multimeter in diode mode and I cant follow where it goes...
СообщениеДобавлено: 18 ноя 2021, 04:30
Did you get any solution I have exactly that problem on two video cards.
СообщениеДобавлено: 18 ноя 2021, 12:50
andreagtr писал(а):
PX_EN
It is very important signal. How close to the GPU did you search for it? It goes through a series of resistors and 0 ohm resistors. It is connected to many places. A shorted transistor somewhere can pull it down along with DRAM_RSTA.
For example this dual NPN could pull these signals down or up permanently.
Posted after 5 minutes 48 seconds:
But you could support this forum with $99 :-) It is not a big deal for us westerners but definitely will help the forum to grow up.
Posted after 2 minutes 40 seconds:
Did you measure the whole net? What is a voltage drop and resistance of each signal in a different points? What is the exact model of this MSI card?
СообщениеДобавлено: 18 ноя 2021, 16:01
I have a 580 nitro rx here with the same problem.
СообщениеДобавлено: 18 ноя 2021, 17:43
на Сапфирах PX_EN появится когда карта будет стоять в материнке.
В этой теме нет новых непрочитанных сообщений. Gigabyte Rx580 gaming 8gb с памятью Samsung 8gb неправильно прошит биос
al0816
24
6034
03 ноя 2021, 14:52
agsmt Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RX 570 8gb (V341 Ver 2.2) missing VDDCI
bd250
20 окт 2022, 00:43
В этой теме нет новых непрочитанных сообщений. Sapphire RX580 4GB Nitro+ missing VDDCI
dani82
16 июл 2022, 13:06
com77 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MSI RX580 8GB есть все питания, но не определяется
chernovik
2562
05 мар 2021, 10:54
chernovik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI Rx580 8gb v341 rev1.1 нет изо
Dron1980
06 май 2022, 21:20
uncledim Перейти к последнему сообщению
Сейчас этот форум просматривают: Birmud, Элиском и гости: 96
