Pandemonium6 писал(а):
Reballing will not help. It could heal some signal balls but not the power plane with a hundred connections. I have read probably yours earlier post and I can't explain it since I have never had such symptoms. It looks like the whole GPU is disconnected.
have solved the problem. HIS solved by reball GPU, XFX by change memory bank 2pcs near pcie.
Working normal, even with resistant memory up to 2xx ohm
