Текущее время: 10 ноя 2026, 01:45
 Заголовок сообщения: Lenovo S145-15IWL (FV440/FS441/FS540 NM-C121) Don't charge battery
СообщениеДобавлено: 30 ноя 2021, 19:09
Hello. I have a problem with this device, everything works except that the battery does not charge. The measurements in BQ24780S with the battery are:
1-ACN: 20,3
2-ACP: 20,3
3-CMSRC: 20,3
4-ACDRV: 26,2
5-ACOK: 3,3
6-ACDET: 2,8
7-IADP: 0,01
8-IDCHG: 0
9-PMON: 0,01
10-PROCHOT#: 0
11-SDA: 3,3
12-SCL: 3,3
13-CMPIN: 1
14-CMPOUT: 1
15-BATPRES#: 0,3
16-TB_STAT#: 1,42
17-BATSRC: 7,6
18-BATSRC: 7,6
19-SRN: 7,6
20-SRP: 7,6
21-ILIM: 1,42
22-GND: 0
23-LODRV: 0
24-REGN: 6
25-BTST: 7,20
26-HIDRV: 7,6
27-PHASE: 7,6
28-VCC: 20
I have changed BQ24780S, battery, AC adapter, and checked mosfets, and nothing. Help me please.
From lost to the river
 Заголовок сообщения: Re: Lenovo S145-15IWL (FV440/FS441/FS540 NM-C121) Don't charge battery
СообщениеДобавлено: 06 дек 2021, 16:20
18 should be BATDRV. Check this voltage before plugging in the adapter. "BATDRV voltage is 6V above BATSRC to turn on BATFET"
СообщениеДобавлено: 07 дек 2021, 17:51
Thanks for the observation. It was an error when transcribing the data. Sorry.
Then I write the corrected measurements again:
1-ACN: 20.3
2-ACP: 20.3
3-CMSRC: 20.3
4-ACDRV: 26.2
5-ACOK: 3.3
6-ACDET: 2.8
7-IADP: 0.01
8-IDCHG: 0
9-PMON: 0.01
10-PROCHOT #: 0
11-SDA: 3.3
12-SCL: 3.3
13-CMPIN: 1
14-CMPOUT: 1
15-BATPRES #: 0.3
16-TB_STAT #: 1.42
17-BATSRC: 7.6
18-BATDRV: 7.6
19-SRN: 7.6
20-SRP: 7.6
21-ILIM: 1.42
22-GND: 0
23-LODRV: 0
24-REGN: 6
25-BTST: 7.20
26-HIDRV: 7.6
27-FASE: 7.6
28-VCC: 20
I will review BATDRV.
 Заголовок сообщения: Re: Lenovo S145-15IWL (FV440/FS441/FS540 NM-C121) Don't charge battery  [РЕШЕНО]
СообщениеДобавлено: 29 дек 2021, 05:20
Finalmente no encontre la solucion. Tras comprobar los componentes uno a uno no di con la averia.
Cierro el hilo.
Gracias por su ayuda.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenovo s145 15iwl (fv440/fs441/fs540 nm-c121) отключить распаянную озу
galiaf2004
25 фев 2021, 15:02
galiaf2004 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. IdeaPad S145 (FV440/FS441/FS540 NM-C121) нужно отключить встроенную оперативную память
Ajax7
13
2089
19 мар 2025, 12:25
garant-service Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Lenovo s145-15iwl (Fv440/Fc441/Fs540 NM-C121) Нет инициализации.
999
16
1949
09 мар 2026, 07:09
samsonov54 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo s145-15iwl (NM-C121) Выбивает входные ключи 20В
milovidov.dl
4686
16 дек 2019, 20:43
milovidov.dl Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Lenovo S145-15IWL (NM-C121) Мигает светодиод включения раз в секунду.
Leo_vrn
24 фев 2020, 22:40
Leo_vrn Перейти к последнему сообщению
Сейчас этот форум просматривают: Sentox и гости: 37
