Текущее время: 26 сен 2024, 08:39
amkwca
Заголовок сообщения: msi rx570 armor 4gb Добавлено: 17 дек 2021, 10:03 |
Зарегистрирован: 17 дек 2021, 09:54 Наличности на руках: 44.00
Сообщения: 24 Откуда: canada
I'm trying to repair this rx580 msi card it shows all the voltages are perfect ,12v, 5v, 3.3v, 1.8 , vram 1.5 ,ram control 0.9 , vcore 0.9. the resistance for all to ground looks normal too. when powering the card the core is getting hot too but the card gives no beeps or display on boot. I try with another card and make this one as a secondry, the motherboard beeps and boot and the card is being detected. I tried to flash the Vbios at DOS and it accepts flashing too. I tried different roms too. but I'm still getting no beeps or boot as a primary card. Somebody can help?
amkwca
Заголовок сообщения: Re: msi rx570 armor 4gb Добавлено: 27 дек 2021, 01:41 |
I've done the following ./tserver -boardtest=memfa I got fail then pico memfa.log and I got the following screen it looks I have errors on 6 chips and 2 are ok. what do u advice? the chips are hynix sk hynix h5gc4h24aja Posted after 49 seconds:https://drive.google.com/file/d/1bNGCGb ... p=drivesdk
