Текущее время: 22 ноя 2024, 16:37
 Заголовок сообщения: E5440 (la-9832p) AC Adapter Unkown
СообщениеДобавлено: 22 янв 2022, 20:36
Hello all
i got a dell laptop with board number la-9832p_Rev1.0 for repair . when I connect the AC adapter it gives me an AC adapter unknown error on the bios menu. when I opened it PU1 was burned which I changed with a new one but I got still the same error. pr8, pr9 have correct ohms but I changed them with new ones. I changed pq2 too but I got the same error again. pl3 is checked and is correct too
any idea where could be the problem and I should check where?
 Заголовок сообщения: Re: E5440 (intel) AC Adapter Unkown
СообщениеДобавлено: 22 янв 2022, 21:39
NB_PSID ( PS_ID ) to multicontroller. (1-wire signal from AC adapter dell).
---------- Добавлено спустя 15 минут 32 секунды: ----------
R EZ A писал(а):
PU1 was burned
Might have to change the multicontroller. PS_ID what resistance .
check, replace PQ2, PQ3.
 Заголовок сообщения: Re: E5440 (la-9832p) AC Adapter Unkown
СообщениеДобавлено: 25 янв 2022, 20:41
I changed PQ2 , PQ3 but still got an adapter unknown error. I even shorted pin 3-4 of pu1 and d-s pq2 but nothing happened
СообщениеДобавлено: 27 янв 2022, 19:45
any idea ?
СообщениеДобавлено: 27 янв 2022, 23:18
Is the power supply original?
post measurements PQ2, PQ3, PD5, PU1, check resistors, check +5V_ALW, +3.3V_ALW,
ECE5048-LZY flashable multicontroller. possibly an error. but it has a locked BOOT area in which battery data is stored. it's not that easy .
попробуй другой оригинальный блок питания.
---------- Добавлено спустя 2 минуты 16 секунд: ----------
sorry -
try another original power supply.
СообщениеДобавлено: 29 янв 2022, 21:55
This new one PU1 was with firmware, or with empty content?
СообщениеДобавлено: 30 янв 2022, 00:30
with what firmware ?
PU1 TS5A63157
https://www.ti.com/lit/ds/symlink/ts5a6 ... le.ru%252F
СообщениеДобавлено: 30 янв 2022, 11:18
Sorry, I thought the speech was about the Dallas chip.
СообщениеДобавлено: 31 янв 2022, 19:01
Are you sure you've soldered PU1 correctly (I mean not upside down). What is the voltage on pin 3 and pin 4 of PU1 (and resistance to ground in NB_PSID and PS_ID lines in turned off state)? You can try to unsolder PU1 and then short pin 3 to pin 4 to see if it's working this way. Did you check PD5 (if it's present on the board)?
Doctrina est fructus dulcis, radicis amarae.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Latitude E5440 (Compal LA-9832P VAW30) Стартует но не дает картинку
в форуме Dell
Oleh Molinskyi
3605
14 апр 2019, 20:07
Oleh Molinskyi Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Latitude E5440 (LA-9832P) включается, не входит в bios
в форуме Dell
ko1esik
3619
28 дек 2019, 16:35
ko1esik Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. DELL Latitude E5440 (VAW30 LA-9832P rev: 1.0(A00)) Не включается
в форуме Dell
erikalov
20 дек 2019, 20:28
ulyanoff Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL latitude e5440 (la-9832p) Проблема с биосом, нет WIFI
в форуме Dell
vanyap1
2368
30 июл 2020, 17:58
vanyap1 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. E5440 (LA-9832P) Need wifi detect
в форуме Dell
R EZ A
18 ноя 2020, 17:43
R EZ A Перейти к последнему сообщению
Сейчас этот форум просматривают: dubstep11 и гости: 37
