slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 12 фев 2022, 15:01 |
Зарегистрирован: 02 июл 2015, 01:09 Наличности на руках: 116.20
Сообщения: 117 Откуда: Беларусь
mods.log
MODS start: Thu Feb 10 10:27:32 2022
Command Line : gputest.js -skip_rm_state_init -mfg
CPU Foundry : GenuineIntel Name : Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz Family : 6 Model : 10 Stepping : 7
Version MODS : 367.106 OperatingSystem: Linux (x86_64) Kernel : 4.1.2-gentoo KernelDriver : 3.63 HostName : tinylinux Sys-uuid : 4C4C4544-0032-4310-8043-B6C04F39354A
GPU 0 [03:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x03, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x0000000001c053400000003c27c40591 Raw ECID (GHS) : 0x00000001643c27c4040000000d028380 ECID : PF2V41-13_x05_y14 Device Id : GP106 Revision : a1 NV Base : 0xe3000000 FB Base : 0xd0000000 IRQ : 11 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Chipset VID : FFFF (Unknown) DID : FFFF (Unknown) Rm call failed. default Disabled. Chipset ASPM : Disabled
gldGP106.bin was generated by MODS version 367.38, expected 367.106. Error 000000000349 : Global.LoadGoldenValuesHelper Out of date golden file. Error 000000000349 : Global.LoadGoldenValues Out of date golden file. Error 000000000349 : Global.InitializeGpuTests Out of date golden file. gputest.js : 82 mfg.spc : 12 boards.js : 7
Error Code = 000000000349 (Out of date golden file.)
MODS end : Thu Feb 10 10:28:10 2022 [38.700 seconds (00:00:38.700 h:m:s)]
report_modsmats.txt
mats version 400.184. Testing GP106 with 20 MB of memory starting with 0 MB.
Read Error Count: 0 Write Error Count: 1825298 Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION === SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS ------- ----------- ------------ ------------ FBIOA0 0 0 0 FBIOA1 0 0 0 FBIOB0 0 1825298 0 FBIOB1 0 0 0 FBIOC0 0 0 0 FBIOC1 0 0 0
Failing Bits: B000 B001 B002 B003 B004 B005 B006 B007 B008 B009 B010 B011 B012 B013 B014 B015 B016 B017 B018 B019 B020 B021 B022 B023 B024 B025 B026 B027 B028 B029 B030 B031
=== MEMORY ERRORS BY BIT === P : Partition (FBIO) READ 0 READ 1 READ ? P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ? - --- ----------- ------------ ------------ ------ ------ ------ B 000 0 842320 0 482815 359505 0 B 001 0 1057078 0 290758 766320 0 B 002 0 833682 0 482029 351653 0 B 003 0 1057504 0 290117 767387 0 B 004 0 983229 0 780467 202762 0 B 005 0 888723 0 481348 407375 0 B 006 0 983697 0 783321 200376 0 B 007 0 900252 0 446798 453454 0 B 008 0 829168 0 595222 233946 0 B 009 0 876435 0 353543 522892 0 B 010 0 816249 0 595327 220922 0 B 011 0 876583 0 353275 523308 0 B 012 0 794097 0 548068 246029 0 B 013 0 877757 0 384554 493203 0 B 014 0 793798 0 549541 244257 0 B 015 0 901560 0 327551 574009 0 B 016 0 844222 0 480884 363338 0 B 017 0 1062332 0 291146 771186 0 B 018 0 836742 0 482369 354373 0 B 019 0 1061928 0 290377 771551 0 B 020 0 987372 0 783130 204242 0 B 021 0 891889 0 484135 407754 0 B 022 0 986337 0 782907 203430 0 B 023 0 904791 0 448160 456631 0 B 024 0 833273 0 596439 236834 0 B 025 0 881546 0 354446 527100 0 B 026 0 821051 0 597593 223458 0 B 027 0 881866 0 353511 528355 0 B 028 0 798364 0 549843 248521 0 B 029 0 883583 0 384658 498925 0 B 030 0 798384 0 551900 246484 0 B 031 0 907739 0 328019 579720 0
=== MEMORY ERRORS BY ADDRESS === ADDRESS : Failing memory address, or buffer offset if starting with 'X+' T : Type of memory error: W = write, R = read P : Partition (FBIO) S : Subpartition B : Bank E : Beat ADDRESS EXPECTED ACTUAL REREAD1 REREAD2 FAILBITS TPSBE ROW COL BIT(s) ------- -------- ------ ------- ------- -------- ----- --- --- ------ 0001357cbc 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB0e7 0033 065 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 0001357cb8 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e6 0033 065 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357cb4 00000000 ff07000f ff07000f ff07000f ff07000f WB0e5 0033 065 B000,B001,B002,B003,B016,B017,B018,B024,B025,B026,B027,B028,B029,B030,B031 0001357cb0 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e4 0033 065 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357cac 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB0e3 0033 065 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 0001357ca8 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e2 0033 065 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357ca4 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e1 0033 065 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357ca0 00000000 ff0d000f ff0d000f ff0d000f ff0d000f WB0e0 0033 065 B000,B001,B002,B003,B016,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357c9c 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB0e7 0033 064 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 0001357c98 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e6 0033 064 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357c94 00000000 ff07000f ff07000f ff07000f ff07000f WB0e5 0033 064 B000,B001,B002,B003,B016,B017,B018,B024,B025,B026,B027,B028,B029,B030,B031 0001357c90 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e4 0033 064 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357c8c 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB0e3 0033 064 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 0001357c88 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e2 0033 064 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357c84 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB0e1 0033 064 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001357c80 00000000 ff0d000f ff0d000f ff0d000f ff0d000f WB0e0 0033 064 B000,B001,B002,B003,B016,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 0001353cbc 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0e7 0033 055 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0001353cb8 00000000 fffffffb fffffffb fffffffb fffffffb WB0e6 0033 055 B000,B001,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353cb4 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0e5 0033 055 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353cac 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0e3 0033 055 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0001353ca8 00000000 ffffffff ffffffff ffffffff ffffffff WB0e2 0033 055 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353ca4 00000000 ffef0000 ffef0000 ffef0000 ffef0000 WB0e1 0033 055 B016,B017,B018,B019,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353c9c 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0e7 0033 054 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0001353c98 00000000 fffffffb fffffffb fffffffb fffffffb WB0e6 0033 054 B000,B001,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353c94 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0e5 0033 054 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353c8c 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0e3 0033 054 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0001353c88 00000000 ffffffff ffffffff ffffffff ffffffff WB0e2 0033 054 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0001353c84 00000000 ffef0000 ffef0000 ffef0000 ffef0000 WB0e1 0033 054 B016,B017,B018,B019,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5fc 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0c7 0003 067 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000015e5f8 00000000 fffffffb fffffffb fffffffb fffffffb WB0c6 0003 067 B000,B001,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5f4 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0c5 0003 067 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5ec 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0c3 0003 067 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000015e5e8 00000000 ffffffff ffffffff ffffffff ffffffff WB0c2 0003 067 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5e4 00000000 ffef0000 ffef0000 ffef0000 ffef0000 WB0c1 0003 067 B016,B017,B018,B019,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5dc 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0c7 0003 066 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000015e5d8 00000000 fffffffb fffffffb fffffffb fffffffb WB0c6 0003 066 B000,B001,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5d4 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0c5 0003 066 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5cc 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0c3 0003 066 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000015e5c8 00000000 ffffffff ffffffff ffffffff ffffffff WB0c2 0003 066 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000015e5c4 00000000 ffef0000 ffef0000 ffef0000 ffef0000 WB0c1 0003 066 B016,B017,B018,B019,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 00001535fc 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB077 0003 057 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 00001535f8 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB076 0003 057 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535f4 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB075 0003 057 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535f0 00000000 000f000f 000f000f 000f000f 000f000f WB074 0003 057 B000,B001,B002,B003,B016,B017,B018,B019 00001535ec 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB073 0003 057 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 00001535e8 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB072 0003 057 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535e4 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB071 0003 057 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535e0 00000000 000f000f 000f000f 000f000f 000f000f WB070 0003 057 B000,B001,B002,B003,B016,B017,B018,B019 00001535dc 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB077 0003 056 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 00001535d8 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB076 0003 056 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535d4 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB075 0003 056 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535d0 00000000 000f000f 000f000f 000f000f 000f000f WB074 0003 056 B000,B001,B002,B003,B016,B017,B018,B019 00001535cc 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB073 0003 056 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 00001535c8 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB072 0003 056 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535c4 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB071 0003 056 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 00001535c0 00000000 000f000f 000f000f 000f000f 000f000f WB070 0003 056 B000,B001,B002,B003,B016,B017,B018,B019 000099d13c 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB087 0019 061 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 000099d138 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB086 0019 061 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 000099d134 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB085 0019 061 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 000099d130 00000000 000f000f 000f000f 000f000f 000f000f WB084 0019 061 B000,B001,B002,B003,B016,B017,B018,B019 000099d12c 00000000 000fff0f 000fff0f 000fff0f 000fff0f WB083 0019 061 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019 000099d128 00000000 ff0fff0f ff0fff0f ff0fff0f ff0fff0f WB082 0019 061 B000,B001,B002,B003,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 000099d124 00000000 ff0f000f ff0f000f ff0f000f ff0f000f WB081 0019 061 B000,B001,B002,B003,B016,B017,B018,B019,B024,B025,B026,B027,B028,B029,B030,B031 000099d120 00000000 000f000f 000f000f 000f000f 000f000f WB080 0019 061 B000,B001,B002,B003,B016,B017,B018,B019 000099d11c 00000000 98a998a9 98a998a9 98a998a9 98a998a9 WB087 0019 060 B000,B003,B005,B007,B011,B012,B015,B016,B019,B021,B023,B027,B028,B031 000099d118 00000000 ebebebeb ebebebeb ebebebeb ebebebeb WB086 0019 060 B000,B001,B003,B005,B006,B007,B008,B009,B011,B013,B014,B015,B016,B017,B019,B021,B022,B023,B024,B025,B027,B029,B030,B031 000099d114 00000000 80808080 80808080 80808080 80808080 WB085 0019 060 B007,B015,B023,B031 000099d110 00000000 e9e9e9e9 e9e9e9e9 e9e9e9e9 e9e9e9e9 WB084 0019 060 B000,B003,B005,B006,B007,B008,B011,B013,B014,B015,B016,B019,B021,B022,B023,B024,B027,B029,B030,B031 000099d10c 00000000 f9f9f9f9 f9f9f9f9 f9f9f9f9 f9f9f9f9 WB083 0019 060 B000,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B016,B019,B020,B021,B022,B023,B024,B027,B028,B029,B030,B031 000099d108 00000000 a7a7a7a7 a7a7a7a7 a7a7a7a7 a7a7a7a7 WB082 0019 060 B000,B001,B002,B005,B007,B008,B009,B010,B013,B015,B016,B017,B018,B021,B023,B024,B025,B026,B029,B031 000099d104 00000000 adadadad adadadad adadadad adadadad WB081 0019 060 B000,B002,B003,B005,B007,B008,B010,B011,B013,B015,B016,B018,B019,B021,B023,B024,B026,B027,B029,B031 000099d100 00000000 cccccccc cccccccc cccccccc cccccccc WB080 0019 060 B002,B003,B006,B007,B010,B011,B014,B015,B018,B019,B022,B023,B026,B027,B030,B031 000099913c 00000000 99009900 99009900 99009900 99009900 WB087 0019 051 B008,B011,B012,B015,B024,B027,B028,B031 0000999138 00000000 eb00eb00 eb00eb00 eb00eb00 eb00eb00 WB086 0019 051 B008,B009,B011,B013,B014,B015,B024,B025,B027,B029,B030,B031 0000999134 00000000 80008000 80008000 80008000 80008000 WB085 0019 051 B015,B031 0000999130 00000000 e900e900 e900e900 e900e900 e900e900 WB084 0019 051 B008,B011,B013,B014,B015,B024,B027,B029,B030,B031 000099912c 00000000 f900f900 f900f900 f900f900 f900f900 WB083 0019 051 B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 0000999128 00000000 a700a700 a700a700 a700a700 a700a700 WB082 0019 051 B008,B009,B010,B013,B015,B024,B025,B026,B029,B031 0000999124 00000000 ad00ad00 ad00ad00 ad00ad00 ad00ad00 WB081 0019 051 B008,B010,B011,B013,B015,B024,B026,B027,B029,B031 0000999120 00000000 cc00cc00 cc00cc00 cc00cc00 cc00cc00 WB080 0019 051 B010,B011,B014,B015,B026,B027,B030,B031 000099911c 00000000 a900a900 a900a900 a900a900 a900a900 WB087 0019 050 B008,B011,B013,B015,B024,B027,B029,B031 0000999118 00000000 eb00eb00 eb00eb00 eb00eb00 eb00eb00 WB086 0019 050 B008,B009,B011,B013,B014,B015,B024,B025,B027,B029,B030,B031 0000999114 00000000 80008000 80008000 80008000 80008000 WB085 0019 050 B015,B031 0000999110 00000000 e900e900 e900e900 e900e900 e900e900 WB084 0019 050 B008,B011,B013,B014,B015,B024,B027,B029,B030,B031 000099910c 00000000 f900f900 f900f900 f900f900 f900f900 WB083 0019 050 B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 0000999108 00000000 a700a700 a700a700 a700a700 a700a700 WB082 0019 050 B008,B009,B010,B013,B015,B024,B025,B026,B029,B031 0000999104 00000000 ad00ad00 ad00ad00 ad00ad00 ad00ad00 WB081 0019 050 B008,B010,B011,B013,B015,B024,B026,B027,B029,B031 0000999100 00000000 cc00cc00 cc00cc00 cc00cc00 cc00cc00 WB080 0019 050 B010,B011,B014,B015,B026,B027,B030,B031 000070497c 00000000 009c009c 009c009c 009c009c 009c009c WB0e7 0012 063 B002,B003,B004,B007,B018,B019,B020,B023 0000704978 00000000 00eb00eb 00eb00eb 00eb00eb 00eb00eb WB0e6 0012 063 B000,B001,B003,B005,B006,B007,B016,B017,B019,B021,B022,B023 0000704974 00000000 00800080 00800080 00800080 00800080 WB0e5 0012 063 B007,B023 0000704970 00000000 00e900e9 00e900e9 00e900e9 00e900e9 WB0e4 0012 063 B000,B003,B005,B006,B007,B016,B019,B021,B022,B023 000070496c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0e3 0012 063 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000704968 00000000 00a700a7 00a700a7 00a700a7 00a700a7 WB0e2 0012 063 B000,B001,B002,B005,B007,B016,B017,B018,B021,B023 0000704964 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0e1 0012 063 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000704960 00000000 009e009e 009e009e 009e009e 009e009e WB0e0 0012 063 B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 000070495c 00000000 009c009c 009c009c 009c009c 009c009c WB0e7 0012 062 B002,B003,B004,B007,B018,B019,B020,B023 0000704958 00000000 00eb00eb 00eb00eb 00eb00eb 00eb00eb WB0e6 0012 062 B000,B001,B003,B005,B006,B007,B016,B017,B019,B021,B022,B023 0000704954 00000000 00800080 00800080 00800080 00800080 WB0e5 0012 062 B007,B023 0000704950 00000000 00e900e9 00e900e9 00e900e9 00e900e9 WB0e4 0012 062 B000,B003,B005,B006,B007,B016,B019,B021,B022,B023 000070494c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0e3 0012 062 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000704948 00000000 00a700a7 00a700a7 00a700a7 00a700a7 WB0e2 0012 062 B000,B001,B002,B005,B007,B016,B017,B018,B021,B023 0000704944 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0e1 0012 062 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000704940 00000000 009e009e 009e009e 009e009e 009e009e WB0e0 0012 062 B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 000070097c 00000000 00dd00dd 00dd00dd 00dd00dd 00dd00dd WB0e7 0012 053 B000,B002,B003,B004,B006,B007,B016,B018,B019,B020,B022,B023 0000700978 00000000 00eb00eb 00eb00eb 00eb00eb 00eb00eb WB0e6 0012 053 B000,B001,B003,B005,B006,B007,B016,B017,B019,B021,B022,B023 0000700974 00000000 00800080 00800080 00800080 00800080 WB0e5 0012 053 B007,B023 0000700970 00000000 00e900e9 00e900e9 00e900e9 00e900e9 WB0e4 0012 053 B000,B003,B005,B006,B007,B016,B019,B021,B022,B023 000070096c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0e3 0012 053 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000700968 00000000 00a700a7 00a700a7 00a700a7 00a700a7 WB0e2 0012 053 B000,B001,B002,B005,B007,B016,B017,B018,B021,B023 0000700964 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0e1 0012 053 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000700960 00000000 009e009e 009e009e 009e009e 009e009e WB0e0 0012 053 B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 000070095c 00000000 00dd00dd 00dd00dd 00dd00dd 00dd00dd WB0e7 0012 052 B000,B002,B003,B004,B006,B007,B016,B018,B019,B020,B022,B023 0000700958 00000000 00eb00eb 00eb00eb 00eb00eb 00eb00eb WB0e6 0012 052 B000,B001,B003,B005,B006,B007,B016,B017,B019,B021,B022,B023 0000700954 00000000 00800080 00800080 00800080 00800080 WB0e5 0012 052 B007,B023 0000700950 00000000 00e900e9 00e900e9 00e900e9 00e900e9 WB0e4 0012 052 B000,B003,B005,B006,B007,B016,B019,B021,B022,B023 000070094c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0e3 0012 052 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000700948 00000000 00a700a7 00a700a7 00a700a7 00a700a7 WB0e2 0012 052 B000,B001,B002,B005,B007,B016,B017,B018,B021,B023 0000700944 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0e1 0012 052 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000700940 00000000 009e009e 009e009e 009e009e 009e009e WB0e0 0012 052 B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 00012ae6bc 00000000 00dd00dd 00dd00dd 00dd00dd 00dd00dd WB027 0031 06d B000,B002,B003,B004,B006,B007,B016,B018,B019,B020,B022,B023 00012ae6b8 00000000 00eb00eb 00eb00eb 00eb00eb 00eb00eb WB026 0031 06d B000,B001,B003,B005,B006,B007,B016,B017,B019,B021,B022,B023 00012ae6b4 00000000 00800080 00800080 00800080 00800080 WB025 0031 06d B007,B023 00012ae6b0 00000000 00e900e9 00e900e9 00e900e9 00e900e9 WB024 0031 06d B000,B003,B005,B006,B007,B016,B019,B021,B022,B023 00012ae6ac 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB023 0031 06d B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 00012ae6a8 00000000 00a700a7 00a700a7 00a700a7 00a700a7 WB022 0031 06d B000,B001,B002,B005,B007,B016,B017,B018,B021,B023 00012ae6a4 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB021 0031 06d B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 00012ae6a0 00000000 009e009e 009e009e 009e009e 009e009e WB020 0031 06d B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 00012ae69c 00000000 9c0f9c0f 9c0f9c0f 9c0f9c0f 9c0f9c0f WB027 0031 06c B000,B001,B002,B003,B010,B011,B012,B015,B016,B017,B018,B019,B026,B027,B028,B031 00012ae698 00000000 eb0feb0f eb0feb0f eb0feb0f eb0feb0f WB026 0031 06c B000,B001,B002,B003,B008,B009,B011,B013,B014,B015,B016,B017,B018,B019,B024,B025,B027,B029,B030,B031 00012ae694 00000000 800f800f 800f800f 800f800f 800f800f WB025 0031 06c B000,B001,B002,B003,B015,B016,B017,B018,B019,B031 00012ae690 00000000 e94fe90f e94fe90f e94fe90f e94fe90f WB024 0031 06c B000,B001,B002,B003,B008,B011,B013,B014,B015,B016,B017,B018,B019,B022,B024,B027,B029,B030,B031 00012ae68c 00000000 f90ff90f f90ff90f f90ff90f f90ff90f WB023 0031 06c B000,B001,B002,B003,B008,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B027,B028,B029,B030,B031 00012ae688 00000000 a70fa70f a70fa70f a70fa70f a70fa70f WB022 0031 06c B000,B001,B002,B003,B008,B009,B010,B013,B015,B016,B017,B018,B019,B024,B025,B026,B029,B031 00012ae684 00000000 ad0fad0f ad0fad0f ad0fad0f ad0fad0f WB021 0031 06c B000,B001,B002,B003,B008,B010,B011,B013,B015,B016,B017,B018,B019,B024,B026,B027,B029,B031 00012ae680 00000000 9e0f9e0f 9e0f9e0f 9e0f9e0f 9e0f9e0f WB020 0031 06c B000,B001,B002,B003,B009,B010,B011,B012,B015,B016,B017,B018,B019,B025,B026,B027,B028,B031 00012aa6bc 00000000 ddeddded ddeddded ddeddded ddeddded WB027 0031 05d B000,B002,B003,B005,B006,B007,B008,B010,B011,B012,B014,B015,B016,B018,B019,B021,B022,B023,B024,B026,B027,B028,B030,B031 00012aa6b8 00000000 ebebebeb ebebebeb ebebebeb ebebebeb WB026 0031 05d B000,B001,B003,B005,B006,B007,B008,B009,B011,B013,B014,B015,B016,B017,B019,B021,B022,B023,B024,B025,B027,B029,B030,B031 00012aa6b4 00000000 80808080 80808080 80808080 80808080 WB025 0031 05d B007,B015,B023,B031 00012aa6b0 00000000 e9e9e9e9 e9e9e9e9 e9e9e9e9 e9e9e9e9 WB024 0031 05d B000,B003,B005,B006,B007,B008,B011,B013,B014,B015,B016,B019,B021,B022,B023,B024,B027,B029,B030,B031 00012aa6ac 00000000 f9f9f9f9 f9f9f9f9 f9f9f9f9 f9f9f9f9 WB023 0031 05d B000,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B016,B019,B020,B021,B022,B023,B024,B027,B028,B029,B030,B031 00012aa6a8 00000000 a7a7a7a7 a7a7a7a7 a7a7a7a7 a7a7a7a7 WB022 0031 05d B000,B001,B002,B005,B007,B008,B009,B010,B013,B015,B016,B017,B018,B021,B023,B024,B025,B026,B029,B031 00012aa6a4 00000000 adadadad adadadad adadadad adadadad WB021 0031 05d B000,B002,B003,B005,B007,B008,B010,B011,B013,B015,B016,B018,B019,B021,B023,B024,B026,B027,B029,B031 00012aa6a0 00000000 9e9e9e9e 9e9e9e9e 9e9e9e9e 9e9e9e9e WB020 0031 05d B001,B002,B003,B004,B007,B009,B010,B011,B012,B015,B017,B018,B019,B020,B023,B025,B026,B027,B028,B031 00012aa69c 00000000 ed5aedff ed5aedff ed5aedff ed5aedff WB027 0031 05c B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B011,B013,B014,B015,B017,B019,B020,B022,B024,B026,B027,B029,B030,B031 00012aa698 00000000 ebffeb5a ebffeb5a ebffeb5a ebffeb5a WB026 0031 05c B001,B003,B004,B006,B008,B009,B011,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B027,B029,B030,B031 00012aa694 00000000 80ff805a 80ff805a 80ff805a 80ff805a WB025 0031 05c B001,B003,B004,B006,B015,B016,B017,B018,B019,B020,B021,B022,B023,B031 00012aa690 00000000 e9ffe95a e9ffe95a e9ffe95a e9ffe95a WB024 0031 05c B001,B003,B004,B006,B008,B011,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B027,B029,B030,B031 00012aa68c 00000000 f95af9ff f95af9ff f95af9ff f95af9ff WB023 0031 05c B000,B001,B002,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B017,B019,B020,B022,B024,B027,B028,B029,B030,B031 00012aa688 00000000 a7ffa75a a7ffa75a a7ffa75a a7ffa75a WB022 0031 05c B001,B003,B004,B006,B008,B009,B010,B013,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B029,B031 00012aa684 00000000 adffad5a adffad5a adffad5a adffad5a WB021 0031 05c B001,B003,B004,B006,B008,B010,B011,B013,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B026,B027,B029,B031 00012aa680 00000000 9e7f9e5a 9e7f9e5a 9e7f9e5a 9e7f9e5a WB020 0031 05c B001,B003,B004,B006,B009,B010,B011,B012,B015,B016,B017,B018,B019,B020,B021,B022,B025,B026,B027,B028,B031 00012a76bc 00000000 000f000f 000f000f 000f000f 000f000f WB037 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76b8 00000000 000f000f 000f000f 000f000f 000f000f WB036 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76b4 00000000 000f000f 000f000f 000f000f 000f000f WB035 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76b0 00000000 000f000f 000f000f 000f000f 000f000f WB034 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76ac 00000000 000f000f 000f000f 000f000f 000f000f WB033 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76a8 00000000 000f000f 000f000f 000f000f 000f000f WB032 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76a4 00000000 000f000f 000f000f 000f000f 000f000f WB031 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 00012a76a0 00000000 000f000f 000f000f 000f000f 000f000f WB030 0031 06d B000,B001,B002,B003,B016,B017,B018,B019 0000d1e73c 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB057 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e738 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB056 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e734 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB055 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e730 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB054 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e72c 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB053 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e728 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB052 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e724 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB051 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e720 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB050 0022 069 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e71c 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB057 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e718 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB056 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e714 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB055 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e710 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB054 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e70c 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB053 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e708 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB052 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e704 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB051 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1e700 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB050 0022 068 B009,B011,B013,B015,B025,B027,B029,B031 0000d1a73c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB057 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a738 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB056 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a734 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB055 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a730 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB054 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a72c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB053 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a728 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB052 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a724 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB051 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a720 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB050 0022 059 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a71c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB057 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a718 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB056 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a714 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB055 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a710 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB054 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a70c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB053 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a708 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB052 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a704 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB051 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000d1a700 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB050 0022 058 B001,B003,B005,B007,B017,B019,B021,B023 0000061d9c 00000000 000f000f 000f000f 000f000f 000f000f WB097 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d98 00000000 000f000f 000f000f 000f000f 000f000f WB096 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d94 00000000 000f000f 000f000f 000f000f 000f000f WB095 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d90 00000000 000f000f 000f000f 000f000f 000f000f WB094 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d8c 00000000 000f000f 000f000f 000f000f 000f000f WB093 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d88 00000000 000f000f 000f000f 000f000f 000f000f WB092 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d84 00000000 000f000f 000f000f 000f000f 000f000f WB091 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000061d80 00000000 000f000f 000f000f 000f000f 000f000f WB090 0001 004 B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff7c 00000000 000f000f 000f000f 000f000f 000f000f WB0c7 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff78 00000000 000f000f 000f000f 000f000f 000f000f WB0c6 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff74 00000000 000f000f 000f000f 000f000f 000f000f WB0c5 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff70 00000000 000f000f 000f000f 000f000f 000f000f WB0c4 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff6c 00000000 000f000f 000f000f 000f000f 000f000f WB0c3 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff68 00000000 000f000f 000f000f 000f000f 000f000f WB0c2 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff64 00000000 000f000f 000f000f 000f000f 000f000f WB0c1 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff60 00000000 000f000f 000f000f 000f000f 000f000f WB0c0 001b 03b B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff5c 00000000 000f000f 000f000f 000f000f 000f000f WB0c7 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff58 00000000 000f000f 000f000f 000f000f 000f000f WB0c6 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff54 00000000 000f000f 000f000f 000f000f 000f000f WB0c5 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff50 00000000 000f000f 000f000f 000f000f 000f000f WB0c4 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff4c 00000000 000f000f 000f000f 000f000f 000f000f WB0c3 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff48 00000000 000f000f 000f000f 000f000f 000f000f WB0c2 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff44 00000000 000f000f 000f000f 000f000f 000f000f WB0c1 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 0000a3ff40 00000000 000f000f 000f000f 000f000f 000f000f WB0c0 001b 03a B000,B001,B002,B003,B016,B017,B018,B019 00012c9cfc 00000000 000f000f 000f000f 000f000f 000f000f WB0f7 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cf8 00000000 000f000f 000f000f 000f000f 000f000f WB0f6 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cf4 00000000 000f000f 000f000f 000f000f 000f000f WB0f5 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cf0 00000000 000f000f 000f000f 000f000f 000f000f WB0f4 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cec 00000000 000f000f 000f000f 000f000f 000f000f WB0f3 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9ce8 00000000 000f000f 000f000f 000f000f 000f000f WB0f2 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9ce4 00000000 000f000f 000f000f 000f000f 000f000f WB0f1 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9ce0 00000000 000f000f 000f000f 000f000f 000f000f WB0f0 0032 007 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cdc 00000000 000f000f 000f000f 000f000f 000f000f WB0f7 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cd8 00000000 000f000f 000f000f 000f000f 000f000f WB0f6 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cd4 00000000 000f000f 000f000f 000f000f 000f000f WB0f5 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cd0 00000000 000f000f 000f000f 000f000f 000f000f WB0f4 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9ccc 00000000 000f000f 000f000f 000f000f 000f000f WB0f3 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cc8 00000000 000f000f 000f000f 000f000f 000f000f WB0f2 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cc4 00000000 000f000f 000f000f 000f000f 000f000f WB0f1 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 00012c9cc0 00000000 000f000f 000f000f 000f000f 000f000f WB0f0 0032 006 B000,B001,B002,B003,B016,B017,B018,B019 000041f73c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0d7 000a 079 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 000041f738 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB0d6 000a 079 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 000041f734 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB0d5 000a 079 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 000041f730 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB0d4 000a 079 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 000041f72c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0d3 000a 079 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 000041f728 00000000 00af00af 00af00af 00af00af 00af00af WB0d2 000a 079 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 000041f724 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0d1 000a 079 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 000041f720 00000000 009e009e 009e009e 009e009e 009e009e WB0d0 000a 079 B001,B002,B003,B004,B007,B017,B018,B019,B020,B023 000041f71c 00000000 000f000f 000f000f 000f000f 000f000f WB0d7 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f718 00000000 000f000f 000f000f 000f000f 000f000f WB0d6 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f714 00000000 000f000f 000f000f 000f000f 000f000f WB0d5 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f710 00000000 000f000f 000f000f 000f000f 000f000f WB0d4 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f70c 00000000 000f000f 000f000f 000f000f 000f000f WB0d3 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f708 00000000 000f000f 000f000f 000f000f 000f000f WB0d2 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f704 00000000 000f000f 000f000f 000f000f 000f000f WB0d1 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041f700 00000000 000f000f 000f000f 000f000f 000f000f WB0d0 000a 078 B000,B001,B002,B003,B016,B017,B018,B019 000041b71c 00000000 880088ff 880088ff 880088ff 880088ff WB0d7 000a 048 B000,B001,B002,B003,B004,B005,B006,B007,B011,B015,B027,B031 000041b718 00000000 ed00edff ed00edff ed00edff ed00edff WB0d6 000a 048 B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B011,B013,B014,B015,B024,B026,B027,B029,B030,B031 000041b714 00000000 f500f500 f500f500 f500f500 f500f500 WB0d5 000a 048 B008,B010,B012,B013,B014,B015,B024,B026,B028,B029,B030,B031 000041b710 00000000 b5feb500 b5feb500 b5feb500 b5feb500 WB0d4 000a 048 B008,B010,B012,B013,B015,B017,B018,B019,B020,B021,B022,B023,B024,B026,B028,B029,B031 000041b70c 00000000 f900f9ff f900f9ff f900f9ff f900f9ff WB0d3 000a 048 B000,B001,B002,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 000041b708 00000000 af00afff af00afff af00afff af00afff WB0d2 000a 048 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B013,B015,B024,B025,B026,B027,B029,B031 000041b704 00000000 ad00ad00 ad00ad00 ad00ad00 ad00ad00 WB0d1 000a 048 B008,B010,B011,B013,B015,B024,B026,B027,B029,B031 000041b700 00000000 9eff9e00 9eff9e00 9eff9e00 9eff9e00 WB0d0 000a 048 B009,B010,B011,B012,B015,B016,B017,B018,B019,B020,B021,B022,B023,B025,B026,B027,B028,B031 000079e57c 00000000 89008900 89008900 89008900 89008900 WB0d7 0014 033 B008,B011,B015,B024,B027,B031 000079e578 00000000 ed00ed00 ed00ed00 ed00ed00 ed00ed00 WB0d6 0014 033 B008,B010,B011,B013,B014,B015,B024,B026,B027,B029,B030,B031 000079e574 00000000 f500f500 f500f500 f500f500 f500f500 WB0d5 0014 033 B008,B010,B012,B013,B014,B015,B024,B026,B028,B029,B030,B031 000079e570 00000000 b500b500 b500b500 b500b500 b500b500 WB0d4 0014 033 B008,B010,B012,B013,B015,B024,B026,B028,B029,B031 000079e56c 00000000 f900f900 f900f900 f900f900 f900f900 WB0d3 0014 033 B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 000079e568 00000000 af00af00 af00af00 af00af00 af00af00 WB0d2 0014 033 B008,B009,B010,B011,B013,B015,B024,B025,B026,B027,B029,B031 000079e564 00000000 ad00ad00 ad00ad00 ad00ad00 ad00ad00 WB0d1 0014 033 B008,B010,B011,B013,B015,B024,B026,B027,B029,B031 000079e560 00000000 9e009e00 9e009e00 9e009e00 9e009e00 WB0d0 0014 033 B009,B010,B011,B012,B015,B025,B026,B027,B028,B031 000079e55c 00000000 f900f9ff f900f9ff f900f9ff f900f9ff WB0d7 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 000079e558 00000000 edffedff edffedff edffedff edffedff WB0d6 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B011,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B026,B027,B029,B030,B031 000079e554 00000000 f500f5ff f500f5ff f500f5ff f500f5ff WB0d5 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B012,B013,B014,B015,B024,B026,B028,B029,B030,B031 000079e550 00000000 b5ffb5ff b5ffb5ff b5ffb5ff b5ffb5ff WB0d4 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B012,B013,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B026,B028,B029,B031 000079e54c 00000000 f900f9ff f900f9ff f900f9ff f900f9ff WB0d3 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B024,B027,B028,B029,B030,B031 000079e548 00000000 afffaf7f afffaf7f afffaf7f afffaf7f WB0d2 0014 032 B000,B001,B002,B003,B004,B005,B006,B008,B009,B010,B011,B013,B015,B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B029,B031 000079e544 00000000 ad00adff ad00adff ad00adff ad00adff WB0d1 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B008,B010,B011,B013,B015,B024,B026,B027,B029,B031 000079e540 00000000 9eff9eff 9eff9eff 9eff9eff 9eff9eff WB0d0 0014 032 B000,B001,B002,B003,B004,B005,B006,B007,B009,B010,B011,B012,B015,B016,B017,B018,B019,B020,B021,B022,B023,B025,B026,B027,B028,B031 000079a57c 00000000 000000ff 000000ff 000000ff 000000ff WB0d7 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a578 00000000 000000ff 000000ff 000000ff 000000ff WB0d6 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a574 00000000 000000ff 000000ff 000000ff 000000ff WB0d5 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a570 00000000 000000ff 000000ff 000000ff 000000ff WB0d4 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a56c 00000000 000000ff 000000ff 000000ff 000000ff WB0d3 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a568 00000000 000000ff 000000ff 000000ff 000000ff WB0d2 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a564 00000000 000000ff 000000ff 000000ff 000000ff WB0d1 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a560 00000000 000000ff 000000ff 000000ff 000000ff WB0d0 0014 003 B000,B001,B002,B003,B004,B005,B006,B007 000079a55c 00000000 00ffffff 00ffffff 00ffffff 00ffffff WB0d7 0014 002 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023 000079a558 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0d6 0014 002 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000079a550 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0d4 0014 002 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 000079a54c 00000000 00ffffff 00ffffff 00ffffff 00ffffff WB0d3 0014 002 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023 000079a548 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB0d2 0014 002 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 000079a540 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB0d0 0014 002 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0000fdfd7c 00000000 00ffffff 00ffffff 00ffffff 00ffffff WB007 002a 023 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023 0000fdfd78 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB006 002a 023 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0000fdfd70 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB004 002a 023 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0000fdfd6c 00000000 00ffffff 00ffffff 00ffffff 00ffffff WB003 002a 023 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015,B016,B017,B018,B019,B020,B021,B022,B023 0000fdfd68 00000000 0000ffff 0000ffff 0000ffff 0000ffff WB002 002a 023 B000,B001,B002,B003,B004,B005,B006,B007,B008,B009,B010,B011,B012,B013,B014,B015 0000fdfd60 00000000 ffff0000 ffff0000 ffff0000 ffff0000 WB000 002a 023 B016,B017,B018,B019,B020,B021,B022,B023,B024,B025,B026,B027,B028,B029,B030,B031 0000fdbd7c 00000000 0000ef00 0000ef00 0000ef00 0000ef00 WB007 002a 013 B008,B009,B010,B011,B013,B014,B015 0000fdbd78 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB006 002a 013 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd74 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB005 002a 013 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd70 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB004 002a 013 B008,B009,B010,B011,B012,B013,B014,B015,B024,B025,B026,B027,B028,B029,B030,B031 0000fdbd6c 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB003 002a 013 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd68 00000000 00007f00 00007f00 00007f00 00007f00 WB002 002a 013 B008,B009,B010,B011,B012,B013,B014 0000fdbd64 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB001 002a 013 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd60 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB000 002a 013 B008,B009,B010,B011,B012,B013,B014,B015,B024,B025,B026,B027,B028,B029,B030,B031 0000fdbd5c 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB007 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd58 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB006 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd54 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB005 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd50 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB004 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd4c 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB003 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd48 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB002 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd44 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB001 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fdbd40 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB000 002a 012 B008,B009,B010,B011,B012,B013,B014,B015 0000fd6d7c 00000000 ff00df00 ff00df00 ff00df00 ff00df00 WB017 002a 023 B008,B009,B010,B011,B012,B014,B015,B024,B025,B026,B027,B028,B029,B030,B031 0000fd6d78 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB016 002a 023 B008,B009,B010,B011,B012,B013,B014,B015 0000fd6d70 00000000 bf000000 bf000000 bf000000 bf000000 WB014 002a 023 B024,B025,B026,B027,B028,B029,B031 0000fd6d6c 00000000 ff00ff00 ff00ff00 ff00ff00 ff00ff00 WB013 002a 023 B008,B009,B010,B011,B012,B013,B014,B015,B024,B025,B026,B027,B028,B029,B030,B031 0000fd6d68 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB012 002a 023 B008,B009,B010,B011,B012,B013,B014,B015 0000fd6d60 00000000 ef000000 ef000000 ef000000 ef000000 WB010 002a 023 B024,B025,B026,B027,B029,B030,B031 0000fd6d5c 00000000 000000ff 000000ff 000000ff 000000ff WB017 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d58 00000000 000000ff 000000ff 000000ff 000000ff WB016 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d54 00000000 000000ff 000000ff 000000ff 000000ff WB015 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d50 00000000 000000ff 000000ff 000000ff 000000ff WB014 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d4c 00000000 000000ff 000000ff 000000ff 000000ff WB013 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d48 00000000 000000ff 000000ff 000000ff 000000ff WB012 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d44 00000000 000000ff 000000ff 000000ff 000000ff WB011 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 0000fd6d40 00000000 000000ff 000000ff 000000ff 000000ff WB010 002a 022 B000,B001,B002,B003,B004,B005,B006,B007 00005cf61c 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB087 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf618 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB086 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf614 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB085 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf610 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB084 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf60c 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB083 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf608 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB082 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf604 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB081 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00005cf600 00000000 0000ff00 0000ff00 0000ff00 0000ff00 WB080 000f 038 B008,B009,B010,B011,B012,B013,B014,B015 00007275bc 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB087 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275b8 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB086 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275b4 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB085 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275b0 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB084 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275ac 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB083 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275a8 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB082 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275a4 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB081 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 00007275a0 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB080 0013 035 B001,B003,B005,B007,B017,B019,B021,B023 000072759c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB087 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727598 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB086 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727594 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB085 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727590 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB084 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 000072758c 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB083 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727588 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB082 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727584 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB081 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 0000727580 00000000 00aa00aa 00aa00aa 00aa00aa 00aa00aa WB080 0013 034 B001,B003,B005,B007,B017,B019,B021,B023 00002984fc 00000000 000f000f 000f000f 000f000f 000f000f WB077 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984f8 00000000 000f000f 000f000f 000f000f 000f000f WB076 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984f4 00000000 000f000f 000f000f 000f000f 000f000f WB075 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984f0 00000000 000f000f 000f000f 000f000f 000f000f WB074 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984ec 00000000 000f000f 000f000f 000f000f 000f000f WB073 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984e8 00000000 000f000f 000f000f 000f000f 000f000f WB072 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984e4 00000000 000f000f 000f000f 000f000f 000f000f WB071 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984e0 00000000 000f000f 000f000f 000f000f 000f000f WB070 0006 047 B000,B001,B002,B003,B016,B017,B018,B019 00002984dc 00000000 000f000f 000f000f 000f000f 000f000f WB077 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984d8 00000000 000f000f 000f000f 000f000f 000f000f WB076 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984d4 00000000 000f000f 000f000f 000f000f 000f000f WB075 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984d0 00000000 000f000f 000f000f 000f000f 000f000f WB074 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984cc 00000000 000f000f 000f000f 000f000f 000f000f WB073 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984c8 00000000 000f000f 000f000f 000f000f 000f000f WB072 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984c4 00000000 000f000f 000f000f 000f000f 000f000f WB071 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002984c0 00000000 000f000f 000f000f 000f000f 000f000f WB070 0006 046 B000,B001,B002,B003,B016,B017,B018,B019 00002954fc 00000000 000f000f 000f000f 000f000f 000f000f WB0c7 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954f8 00000000 000f000f 000f000f 000f000f 000f000f WB0c6 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954f4 00000000 000f000f 000f000f 000f000f 000f000f WB0c5 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954f0 00000000 000f000f 000f000f 000f000f 000f000f WB0c4 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954ec 00000000 000f000f 000f000f 000f000f 000f000f WB0c3 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954e8 00000000 000f000f 000f000f 000f000f 000f000f WB0c2 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954e4 00000000 000f000f 000f000f 000f000f 000f000f WB0c1 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954e0 00000000 000f000f 000f000f 000f000f 000f000f WB0c0 0006 077 B000,B001,B002,B003,B016,B017,B018,B019 00002954dc 00000000 000f000f 000f000f 000f000f 000f000f WB0c7 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954d8 00000000 000f000f 000f000f 000f000f 000f000f WB0c6 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954d4 00000000 000f000f 000f000f 000f000f 000f000f WB0c5 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954d0 00000000 000f000f 000f000f 000f000f 000f000f WB0c4 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954cc 00000000 000f000f 000f000f 000f000f 000f000f WB0c3 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954c8 00000000 000f000f 000f000f 000f000f 000f000f WB0c2 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954c4 00000000 000f000f 000f000f 000f000f 000f000f WB0c1 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002954c0 00000000 000f000f 000f000f 000f000f 000f000f WB0c0 0006 076 B000,B001,B002,B003,B016,B017,B018,B019 00002914fc 00000000 00880088 00880088 00880088 00880088 WB0c7 0006 047 B003,B007,B019,B023 00002914f8 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB0c6 0006 047 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 00002914f4 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB0c5 0006 047 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 00002914f0 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB0c4 0006 047 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 00002914ec 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0c3 0006 047 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 00002914e8 00000000 00af00af 00af00af 00af00af 00af00af WB0c2 0006 047 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 00002914e4 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0c1 0006 047 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 00002914e0 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB0c0 0006 047 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 00002914dc 00000000 00880088 00880088 00880088 00880088 WB0c7 0006 046 B003,B007,B019,B023 00002914d8 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB0c6 0006 046 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 00002914d4 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB0c5 0006 046 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 00002914d0 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB0c4 0006 046 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 00002914cc 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0c3 0006 046 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 00002914c8 00000000 00af00af 00af00af 00af00af 00af00af WB0c2 0006 046 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 00002914c4 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0c1 0006 046 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 00002914c0 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB0c0 0006 046 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 0000e1d23c 00000000 00880088 00880088 00880088 00880088 WB0f7 0025 069 B003,B007,B019,B023 0000e1d238 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB0f6 0025 069 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 0000e1d234 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB0f5 0025 069 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 0000e1d230 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB0f4 0025 069 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 0000e1d22c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0f3 0025 069 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000e1d228 00000000 00af00af 00af00af 00af00af 00af00af WB0f2 0025 069 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 0000e1d224 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0f1 0025 069 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000e1d220 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB0f0 0025 069 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 0000e1d21c 00000000 5a895a89 5a895a89 5a895a89 5a895a89 WB0f7 0025 068 B000,B003,B007,B009,B011,B012,B014,B016,B019,B023,B025,B027,B028,B030 0000e1d218 00000000 5aed5aed 5aed5aed 5aed5aed 5aed5aed WB0f6 0025 068 B000,B002,B003,B005,B006,B007,B009,B011,B012,B014,B016,B018,B019,B021,B022,B023,B025,B027,B028,B030 0000e1d214 00000000 5af55af5 5af55af5 5af55af5 5af55af5 WB0f5 0025 068 B000,B002,B004,B005,B006,B007,B009,B011,B012,B014,B016,B018,B020,B021,B022,B023,B025,B027,B028,B030 0000e1d210 00000000 5ab55ab5 5ab55ab5 5ab55ab5 5ab55ab5 WB0f4 0025 068 B000,B002,B004,B005,B007,B009,B011,B012,B014,B016,B018,B020,B021,B023,B025,B027,B028,B030 0000e1d20c 00000000 5af95af9 5af95af9 5af95af9 5af95af9 WB0f3 0025 068 B000,B003,B004,B005,B006,B007,B009,B011,B012,B014,B016,B019,B020,B021,B022,B023,B025,B027,B028,B030 0000e1d208 00000000 5aaf5aaf 5aaf5aaf 5aaf5aaf 5aaf5aaf WB0f2 0025 068 B000,B001,B002,B003,B005,B007,B009,B011,B012,B014,B016,B017,B018,B019,B021,B023,B025,B027,B028,B030 0000e1d204 00000000 5aad5aad 5aad5aad 5aad5aad 5aad5aad WB0f1 0025 068 B000,B002,B003,B005,B007,B009,B011,B012,B014,B016,B018,B019,B021,B023,B025,B027,B028,B030 0000e1d200 00000000 5abb5abb 5abb5abb 5abb5abb 5abb5abb WB0f0 0025 068 B000,B001,B003,B004,B005,B007,B009,B011,B012,B014,B016,B017,B019,B020,B021,B023,B025,B027,B028,B030 0000e1923c 00000000 000f000f 000f000f 000f000f 000f000f WB0f7 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19238 00000000 000f000f 000f000f 000f000f 000f000f WB0f6 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19234 00000000 000f000f 000f000f 000f000f 000f000f WB0f5 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19230 00000000 000f000f 000f000f 000f000f 000f000f WB0f4 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e1922c 00000000 000f000f 000f000f 000f000f 000f000f WB0f3 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19228 00000000 000f000f 000f000f 000f000f 000f000f WB0f2 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19224 00000000 000f000f 000f000f 000f000f 000f000f WB0f1 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e19220 00000000 000f000f 000f000f 000f000f 000f000f WB0f0 0025 059 B000,B001,B002,B003,B016,B017,B018,B019 0000e1921c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0f7 0025 058 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000e19218 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB0f6 0025 058 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 0000e19214 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB0f5 0025 058 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 0000e19210 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB0f4 0025 058 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 0000e1920c 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB0f3 0025 058 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000e19208 00000000 00af00af 00af00af 00af00af 00af00af WB0f2 0025 058 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 0000e19204 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB0f1 0025 058 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000e19200 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB0f0 0025 058 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 0000ecf0fc 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB007 0027 037 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000ecf0f8 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB006 0027 037 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 0000ecf0f4 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB005 0027 037 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 0000ecf0f0 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB004 0027 037 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 0000ecf0ec 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB003 0027 037 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000ecf0e8 00000000 00af00af 00af00af 00af00af 00af00af WB002 0027 037 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 0000ecf0e4 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB001 0027 037 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000ecf0e0 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB000 0027 037 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 0000ecf0dc 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB007 0027 036 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000ecf0d8 00000000 00ed00ed 00ed00ed 00ed00ed 00ed00ed WB006 0027 036 B000,B002,B003,B005,B006,B007,B016,B018,B019,B021,B022,B023 0000ecf0d4 00000000 00f500f5 00f500f5 00f500f5 00f500f5 WB005 0027 036 B000,B002,B004,B005,B006,B007,B016,B018,B020,B021,B022,B023 0000ecf0d0 00000000 00b500b5 00b500b5 00b500b5 00b500b5 WB004 0027 036 B000,B002,B004,B005,B007,B016,B018,B020,B021,B023 0000ecf0cc 00000000 00f900f9 00f900f9 00f900f9 00f900f9 WB003 0027 036 B000,B003,B004,B005,B006,B007,B016,B019,B020,B021,B022,B023 0000ecf0c8 00000000 00af00af 00af00af 00af00af 00af00af WB002 0027 036 B000,B001,B002,B003,B005,B007,B016,B017,B018,B019,B021,B023 0000ecf0c4 00000000 00ad00ad 00ad00ad 00ad00ad 00ad00ad WB001 0027 036 B000,B002,B003,B005,B007,B016,B018,B019,B021,B023 0000ecf0c0 00000000 00bb00bb 00bb00bb 00bb00bb 00bb00bb WB000 0027 036 B000,B001,B003,B004,B005,B007,B016,B017,B019,B020,B021,B023 0000ecb0fc 00000000 890f8907 890f8907 890f8907 890f8907 WB007 0027 007 B000,B001,B002,B008,B011,B015,B016,B017,B018,B019,B024,B027,B031 0000ecb0f8 00000000 ed0fed0f ed0fed0f ed0fed0f ed0fed0f WB006 0027 007 B000,B001,B002,B003,B008,B010,B011,B013,B014,B015,B016,B017,B018,B019,B024,B026,B027,B029,B030,B031 0000ecb0f4 00000000 f50ff50f f50ff50f f50ff50f f50ff50f WB005 0027 007 B000,B001,B002,B003,B008,B010,B012,B013,B014,B015,B016,B017,B018,B019,B024,B026,B028,B029,B030,B031 0000ecb0f0 00000000 b50fb50f b50fb50f b50fb50f b50fb50f WB004 0027 007 B000,B001,B002,B003,B008,B010,B012,B013,B015,B016,B017,B018,B019,B024,B026,B028,B029,B031 0000ecb0ec 00000000 f90ff90f f90ff90f f90ff90f f90ff90f WB003 0027 007 B000,B001,B002,B003,B008,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B027,B028,B029,B030,B031 0000ecb0e8 00000000 af0faf0f af0faf0f af0faf0f af0faf0f WB002 0027 007 B000,B001,B002,B003,B008,B009,B010,B011,B013,B015,B016,B017,B018,B019,B024,B025,B026,B027,B029,B031 0000ecb0e4 00000000 ad0fad8f ad0fad8f ad0fad8f ad0fad8f WB001 0027 007 B000,B001,B002,B003,B007,B008,B010,B011,B013,B015,B016,B017,B018,B019,B024,B026,B027,B029,B031 0000ecb0e0 00000000 bb0fbb0f bb0fbb0f bb0fbb0f bb0fbb0f WB000 0027 007 B000,B001,B002,B003,B008,B009,B011,B012,B013,B015,B016,B017,B018,B019,B024,B025,B027,B028,B029,B031 0000ecb0dc 00000000 890f8907 890f8907 890f8907 890f8907 WB007 0027 006 B000,B001,B002,B008,B011,B015,B016,B017,B018,B019,B024,B027,B031 0000ecb0d8 00000000 ed0fed0f ed0fed0f ed0fed0f ed0fed0f WB006 0027 006 B000,B001,B002,B003,B008,B010,B011,B013,B014,B015,B016,B017,B018,B019,B024,B026,B027,B029,B030,B031 0000ecb0d4 00000000 f50ff50f f50ff50f f50ff50f f50ff50f WB005 0027 006 B000,B001,B002,B003,B008,B010,B012,B013,B014,B015,B016,B017,B018,B019,B024,B026,B028,B029,B030,B031 0000ecb0d0 00000000 b50fb50f b50fb50f b50fb50f b50fb50f WB004 0027 006 B000,B001,B002,B003,B008,B010,B012,B013,B015,B016,B017,B018,B019,B024,B026,B028,B029,B031 0000ecb0cc 00000000 f90ff90f f90ff90f f90ff90f f90ff90f WB003 0027 006 B000,B001,B002,B003,B008,B011,B012,B013,B014,B015,B016,B017,B018,B019,B024,B027,B028,B029,B030,B031 0000ecb0c8 00000000 af0faf0f af0faf0f af0faf0f af0faf0f WB002 0027 006 B000,B001,B002,B003,B008,B009,B010,B011,B013,B015,B016,B017,B018,B019,B024,B025,B026,B027,B029,B031 0000ecb0c4 00000000 ad0fad8f ad0fad8f ad0fad8f ad0fad8f WB001 0027 006 B000,B001,B002,B003,B007,B008,B010,B011,B013,B015,B016,B017,B018,B019,B024,B026,B027,B029,B031 0000ecb0c0 00000000 bb0fbb0f bb0fbb0f bb0fbb0f bb0fbb0f WB000 0027 006 B000,B001,B002,B003,B008,B009,B011,B012,B013,B015,B016,B017,B018,B019,B024,B025,B027,B028,B029,B031 000100cdfc 00000000 f996f996 f996f996 f996f996 f996f996 WB047 002a 067 B001,B002,B004,B007,B008,B011,B012,B013,B014,B015,B017,B018,B020,B023,B024,B027,B028,B029,B030,B031 000100cdf8 00000000 edededed edededed edededed edededed WB046 002a 067 B000,B002,B003,B005,B006,B007,B008,B010,B011,B013,B014,B015,B016,B018,B019,B021,B022,B023,B024,B026,B027,B029,B030,B031 000100cdf4 00000000 f5f5f5f5 f5f5f5f5 f5f5f5f5 f5f5f5f5 WB045 002a 067 B000,B002,B004,B005,B006,B007,B008,B010,B012,B013,B014,B015,B016,B018,B020,B021,B022,B023,B024,B026,B028,B029,B030,B031 000100cdf0 00000000 b5b9b5b9 b5b9b5b9 b5b9b5b9 b5b9b5b9 WB044 002a 067 B000,B003,B004,B005,B007,B008,B010,B012,B013,B015,B016,B019,B020,B021,B023,B024,B026,B028,B029,B031 000100cdec 00000000 f9f9f9f9 f9f9f9f9 f9f9f9f9 f9f9f9f9 WB043 002a 067 B000,B003,B004,B005,B006,B007,B008,B011,B012,B013,B014,B015,B016,B019,B020,B021,B022,B023,B024,B027,B028,B029,B030,B031 000100cde8 00000000 afafafaf afafafaf afafafaf afafafaf WB042 002a 067 B000,B001,B002,B003,B005,B007,B008,B009,B010,B011,B013,B015,B016,B017,B018,B019,B021,B023,B024,B025,B026,B027,B029,B031 000100cde4 00000000 adadadad adadadad adadadad adadadad WB041 002a 067 B000,B002,B003,B005,B007,B008,B010,B011,B013,B015,B016,B018,B019,B021,B023,B024,B026,B027,B029,B031 000100cde0 00000000 bbbbbbbb bbbbbbbb bbbbbbbb bbbbbbbb WB040 002a 067 B000,B001,B003,B004,B005,B007,B008,B009,B011,B012,B013,B015,B016,B017,B019,B020,B021,B023,B024,B025,B027,B028,B029,B031 000100cddc 00000000 965a965a 965a965a 965a965a 965a965a WB047 002a 066 B001,B003,B004,B006,B009,B010,B012,B015,B017,B019,B020,B022,B025,B026,B028,B031 000100cdd8 00000000 ed5aed5a ed5aed5a ed5aed5a ed5aed5a WB046 002a 066 B001,B003,B004,B006,B008,B010,B011,B013,B014,B015,B017,B019,B020,B022,B024,B026,B027,B029,B030,B031 000100cdd4 00000000 f55af55a f55af55a f55af55a f55af55a WB045 002a 066 B001,B003,B004,B006,B008,B010,B012,B013,B014,B015,B017,B019,B020,B022,B024,B026,B028,B029,B030,B031 000100cdd0 00000000 b95ab95a b95ab95a b95ab95a b95ab95a WB044 002a 066 B001,B003,B004,B006,B008,B011,B012,B013,B015,B017,B019,B020,B022,B024,B027,B028,B029,B031 000100cdcc 00000000 f95af95a f95af95a f95af95a f95af95a WB043 002a 066 B001,B003,B004,B006,B008,B011,B012,B013,B014,B015,B017,B019,B020,B022,B024,B027,B028,B029,B030,B031 000100cdc8 00000000 af5aaf5a af5aaf5a af5aaf5a af5aaf5a WB042 002a 066 B001,B003,B004,B006,B008,B009,B010,B011,B013,B015,B017,B019,B020,B022,B024,B025,B026,B027,B029,B031 000100cdc4 00000000 ad5aad5a ad5aad5a ad5aad5a ad5aad5a WB041 002a 066 B001,B003,B004,B006,B008,B010,B011,B013,B015,B017,B019,B020,B022,B024,B026,B027,B029,B031 000100cdc0 00000000 bb5abb5a bb5abb5a bb5abb5a bb5abb5a WB040 002a 066 B001,B003,B004,B006,B008,B009,B011,B012,B013,B015,B017,B019,B020,B022,B024,B025,B027,B028,B029,B031 0001008dfc 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB047 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008df8 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB046 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008df4 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB045 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008df0 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB044 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008dec 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB043 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008de8 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB042 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008de4 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB041 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001008de0 00000000 5a005a00 5a005a00 5a005a00 5a005a00 WB040 002a 057 B009,B011,B012,B014,B025,B027,B028,B030 0001005dfc 00000000 000f000f 000f000f 000f000f 000f000f WB057 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005df8 00000000 000f000f 000f000f 000f000f 000f000f WB056 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005df4 00000000 000f000f 000f000f 000f000f 000f000f WB055 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005df0 00000000 000f000f 000f000f 000f000f 000f000f WB054 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005dec 00000000 000f000f 000f000f 000f000f 000f000f WB053 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005de8 00000000 000f000f 000f000f 000f000f 000f000f WB052 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005de4 00000000 000f000f 000f000f 000f000f 000f000f WB051 002a 067 B000,B001,B002,B003,B016,B017,B018,B019 0001005de0 00000000 002f002f 002f002f 002f002f 002f002f WB050 002a 067 B000,B001,B002,B003,B005,B016,B017,B018,B019,B021 0001005ddc 00000000 000f000f 000f000f 000f000f 000f000f WB057 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dd8 00000000 000f000f 000f000f 000f000f 000f000f WB056 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dd4 00000000 000f000f 000f000f 000f000f 000f000f WB055 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dd0 00000000 000f000f 000f000f 000f000f 000f000f WB054 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dcc 00000000 000f000f 000f000f 000f000f 000f000f WB053 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dc8 00000000 000f000f 000f000f 000f000f 000f000f WB052 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dc4 00000000 000f000f 000f000f 000f000f 000f000f WB051 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0001005dc0 00000000 000f000f 000f000f 000f000f 000f000f WB050 002a 066 B000,B001,B002,B003,B016,B017,B018,B019 0000a3fcdc 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB0c7 001b 026 B009,B011,B013,B015,B025,B027,B029,B031 0000a3fcd8 00000000 aa00aa00 aa00aa00 aa00aa00 aa00aa00 WB0c6 001b 026 B009,B011,B013,B015,B025,B027,B029,B031 If you are getting failure for first MB of FB then try option -no_scan_out Error Code = 00000001
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 12 фев 2022, 15:30 |
Зарегистрирован: 02 июл 2019, 17:52 Наличности на руках: 700.75
Сообщения: 490 Откуда: Одесса
slava_oz писал(а): Error Code = 000000000349 (Out of date golden file.) Добавьте ключ "-old_gold" и всё у вас получится.
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 12 фев 2022, 16:17 |
Зарегистрирован: 02 июл 2015, 01:09 Наличности на руках: 116.20
Сообщения: 117 Откуда: Беларусь
CatSW писал(а): Добавьте ключ "-old_gold" и всё у вас получится.
Он есть "$LOCATION/$PKGNAME/mods" gputest.js -oqa -old_gold -test 94 -fan_speed 100 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -matsinfo Образ вот этот viewtopic.php?p=831481#p831481Может другой нужен?
YunicheK
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 12 фев 2022, 18:26 |
Зарегистрирован: 07 апр 2018, 15:32 Наличности на руках: 426.77
Думаю проблема здесь в том, что запускается один скрипт, а аргументы вы приводите из другого скрипта, который вовсе не выполняется, иначе не может быть такого, что в логах светятся только аргументы -skip_rm_state_init -mfg, если бы на деле выполнялся бы скрипт с аргументами -oqa -old_gold -test 94 -fan_speed 100 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -matsinfo. В общем разберитесь с тем, в каком скрипте вы смотрите что есть все нужные аргументы, а какой скрипт на самом деле выполняется.
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 10:55 |
Разобрался с логом, но лучше не стало. Лог, оказывается, был от автозапуска в commands. С запуском runmodsmats лог вот такой
mod.log
MODS start: Sat Feb 12 12:03:39 2022
Command Line : gputest.js -mfg -old_gold -testforce 178 -skip 171 -skip 293 -fan_speed 100 -dramclk_percent 100
CPU Foundry : GenuineIntel Name : Intel(R) Core(TM) i3-2120 CPU @ 3.30GHz Family : 6 Model : 10 Stepping : 7
Version MODS : 367.106 OperatingSystem: Linux (x86_64) Kernel : 4.1.2-gentoo KernelDriver : 3.63 HostName : tinylinux Sys-uuid : 4C4C4544-0032-4310-8043-B6C04F39354A
GPU 0 [03:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x03, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x0000000001c053400000003c27c40591 Raw ECID (GHS) : 0x00000001643c27c4040000000d028380 ECID : PF2V41-13_x05_y14 Device Id : GP106 Revision : a1 NV Base : 0xf3000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 28 high. Trying to clear interrupt by writing 0x0 to register 0x001140 NV_PMC_INTR_0 bit 28 high. Trying to clear interrupt by writing 0x0 to register 0x001144 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state.
** ModsDrvBreakPoint **
------------------------- BEGIN ASSERT INFO DUMP ------------------------- | -- | 00000400 ( DFP-6 ). NVRM: | 0x07 | TMDS | 0x00000008 | -- | 00000800 ( DFP-7 ). NVRM: ----------------------------------------------------------------------------------- NVRM: Since none of the original boot devices were valid, falling back to: 00000200 ( DFP-5 ). NVRM: | Suggested (boot/resume) device(s): 00000200 ( DFP-5 ). NVRM: | Selecting as primary device: 00000200 ( DFP-5 ). NVRM: ----------------------------------------------------------------------------------- NVRM: _pmuLoggerConstructSegment: Segment ID = 0x0, (size=0xbf40). NVRM: _pmuLoggerConstructSegment: Segment ID = 0x1, (size=0xfa0). NVRM: inforomGetOCTObject: OCT object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
-------------------------- END ASSERT INFO DUMP --------------------------
------------------------- BEGIN ASSERT INFO DUMP ------------------------- -------------------------------------- NVRM: Since none of the original boot devices were valid, falling back to: 00000200 ( DFP-5 ). NVRM: | Suggested (boot/resume) device(s): 00000200 ( DFP-5 ). NVRM: | Selecting as primary device: 00000200 ( DFP-5 ). NVRM: ----------------------------------------------------------------------------------- NVRM: _pmuLoggerConstructSegment: Segment ID = 0x0, (size=0xbf40). NVRM: _pmuLoggerConstructSegment: Segment ID = 0x1, (size=0xfa0). NVRM: inforomGetOCTObject: OCT object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: pmuInstBlkVasUpdate_IMPL: Error 0x00000065 returned from pmuInstBlkBind_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/nv/objpmu.c:2509
------------------------- BEGIN ASSERT INFO DUMP ------------------------- ng back to: 00000200 ( DFP-5 ). NVRM: | Suggested (boot/resume) device(s): 00000200 ( DFP-5 ). NVRM: | Selecting as primary device: 00000200 ( DFP-5 ). NVRM: ----------------------------------------------------------------------------------- NVRM: _pmuLoggerConstructSegment: Segment ID = 0x0, (size=0xbf40). NVRM: _pmuLoggerConstructSegment: Segment ID = 0x1, (size=0xfa0). NVRM: inforomGetOCTObject: OCT object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: bp @ ../../../../resman/arch/nvalloc/common/src/nv/objgvaspace.c:1045
------------------------- BEGIN ASSERT INFO DUMP ------------------------- oggerConstructSegment: Segment ID = 0x0, (size=0xbf40). NVRM: _pmuLoggerConstructSegment: Segment ID = 0x1, (size=0xfa0). NVRM: inforomGetOCTObject: OCT object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: busMapPmuBufferAperture_GF100: error allocating VA space. NVRM: pmuLoggerStateLoad_IMPL: error mapping logger buffer into the PMU virtual-address space (status=0x40). NVRM: bp @ ../../../../resman/kernel/pmu/nv/pmulogger.c:200
------------------------- BEGIN ASSERT INFO DUMP ------------------------- object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: pmuStateLoad_IMPL: Error while loading logger. (status = 0x40) NVRM: bp @ ../../../../resman/kernel/pmu/nv/objpmu.c:2650
-------------------------- END ASSERT INFO DUMP -------------------------- Error 000000000229 : Gpu.Initialize hardware was not initialized Error 000000000229 : Global.PrintGpuInitError hardware was not initialized Error 000000000229 : Global.InitializeGpuTests hardware was not initialized
------------------------- BEGIN ASSERT INFO DUMP ------------------------- r=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x0000001b priv_level=0x00000000 priv_master=0x00000019! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d3084e64ec3138 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: *** Cannot load state into the device Warning: MSI for device 0000:3:00.0 not serviced Error 000000000229 : Gpu.Initialize hardware was not initialized Error 000000000229 : Global.PrintGpuInitError hardware was not initialized Error 000000000229 : Global.InitializeGpuTests hardware was not initialized Skipping DisableUserInterface. Skipping EnableUserInterface. Beginning GPU shut down Shutdown : GPU devices not initialized, skipping GPU nvlink shutdown NVOC: __nvoc_objDelete: Child class OBJREFCNT not freed from parent class OBJHWPM.NVOC: __nvoc_objDelete: Child class OBJREFCNT not freed from parent class OBJPERF.NVRM: busFlushVirtualBar2_VBAR2 found unfreed bar2 mapping of offset 0x17ffe4000! NVRM: bp @ ../../../../resman/kernel/bus/nv50/vbar2.c:364
------------------------- BEGIN ASSERT INFO DUMP ------------------------- rc/nv/objgvaspace.c:1045
** ModsDrvBreakPoint ** NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6237680: offset=0x17ffe1000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 62543C0: offset=0x17f20e000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 624FDD0: offset=0x17f20f000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6238450: offset=0xc3580000 type=1 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6255D40: offset=0x17f140000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6289650: offset=0x17f20c000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6256180: offset=0x17f20d000 type=0 NVRM: busFlushVirtualBar2_VBAR2 found 7 unreleased bar2 mappings NVRM: bp @ ../../../../resman/kernel/bus/nv50/vbar2.c:390
-------------------------- END ASSERT INFO DUMP -------------------------- Error 000000000818 : Gpu.ShutDown Mods detected an assertion failure
Error Code = 000000000818 (Mods detected an assertion failure)
MODS end : Sat Feb 12 12:03:46 2022 [7.953 seconds (00:00:07.953 h:m:s)]
Что тоже не очень.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 12:53 |
slava_oz писал(а): Что тоже не очень. Увы, но похоже что ГПУ - брелок. Проверяйте сопротивления по питаниям, диф пары, и более подробно опишите, как карта себя ведёт.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 13:24 |
slava_oz писал(а): Артефачит немного. Показывает проблемы по 1 чипу памяти. МОДС тестирует память на номинальных частотах. Для гарантии можете использовать ключ "- test 94" - это NewWfMats тест, подробнее читайте MODS.pdf. И неплохо бы разобратся, почем так много ошибок в логе - попробуйте другую версию МОДСа или мат. платы.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 14:01 |
slava_oz писал(а): Другой матери пока нет под рукой. Жаль. slava_oz писал(а): Интернет гов... Тогда измените командную строку МОДСа на: gputest.js -mfg -old_gold -test 94 а то наворотили там ХЗ что - например ключ "-dramclk_percent 100" бессмыслен, так как в мануале написано: "-dramclk_percent <string> ---- Set dramclk to X % of default. 50 <= X <= 150" - т.е. в процентах от значения по умолчанию, и что же МОДС должен делать, когда ему говорят установить частоту памяти равную 100% от частоты, которую и так он сам устанавливает по умолчанию???
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 14:14 |
CatSW писал(а): dramclk_percent 100 Это не я воротил - это в образе, который на первой странице так наворотили. CatSW писал(а): Тогда измените командную строку МОДСа на: gputest.js -mfg -old_gold -test 94 Вряд-ли это изменит ситуацию с отображением информации о видеокарте.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 14:20 |
slava_oz писал(а): Это не я воротил - это в образе, который на первой странице так наворотили. Я и не про вас говорил, и да, все мы люди, и мы иногда ошибаемся)) slava_oz писал(а): Вряд-ли это изменит ситуацию с отображением информации о видеокарте. Сделайте, можете просто даже так: gputest.js -mfg -old_gold Этого будет вполне достаточно. И выложите ещё раз лог.
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 14:36 |
Сделал первый вариант.
mods.log
MODS start: Sun Feb 13 02:29:43 2022
Command Line : gputest.js -mfg -old_gold -test 94
GPU 0 [01:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x01, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x0000000001c053400000003c27c40591 Raw ECID (GHS) : 0x00000001643c27c4040000000d028380 ECID : PF2V41-13_x05_y14 Device Id : GP106 Revision : a1 NV Base : 0xf3000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 20 high. Trying to clear interrupt by writing 0x0 to register 0x009140 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. Timed out waiting for MSI for PCI device 0000:1:00.0 (iteration 0) MSI mechanism for PCI device 0000:1:00.0 is not working. 0 out of 10 interrupts got through. Error 000000000609 : Gpu.Initialize Interrupt request mechanism does not work Error 000000000609 : Global.PrintGpuInitError Interrupt request mechanism does not work Error 000000000609 : Global.InitializeGpuTests Interrupt request mechanism does not work ERROR: Unable to determine current VGA mode, ax=0x4f03 ERROR: Unable to set VESA mode 0x3, ax=0x4f02 Error 000000000237 : Global.EnableUserInterface unable to set mode PexDevMgr not initialized. Bridge device shutdowns will likely do nothing.
Error Code = 000000000609 (Interrupt request mechanism does not work)
MODS end : Sun Feb 13 02:29:45 2022 [2.624 seconds (00:00:02.624 h:m:s)]
---------- Добавлено спустя 1 минуту 54 секунды: ---------- Может быть проблема в этом "MSI mechanism for PCI device 0000:1:00.0 is not working." И на этой матери ничего не получится? Видеокарту переставил в другой слот. Материнка Intel. Думаю проблема именно в ней.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 15:01 |
slava_oz писал(а): "MSI mechanism for PCI device 0000:1:00.0 is not working." И на этой матери ничего не получится? Скорее всего, карту и ГПУ МОДС видит, но инициализировать не может. Такое бывает с материнками, не вы первый. Так что ищите другую материнку, или к приятелю с пивом, флешкой и картой - МОДСу всё равно где запустится, даже на чужом компе))) slava_oz писал(а): Материнка Intel. Это не смертельно, у меня такая же.
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 15:30 |
CatSW писал(а): Так что ищите другую материнку На след. неделе попробую на других матерях. YunicheK писал(а): -skip_msi_intr_check Сейчас попробуем ---------- Добавлено спустя 11 минут 21 секунду: ----------
mods.log
MODS start: Sun Feb 13 03:38:04 2022
Command Line : gputest.js -mfg -old_gold -test 94 -skip_msi_intr_check
GPU 0 [03:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x03, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x0000000001c053400000003c27c40591 Raw ECID (GHS) : 0x00000001643c27c4040000000d028380 ECID : PF2V41-13_x05_y14 Device Id : GP106 Revision : a1 NV Base : 0xf3000000 FB Base : 0xe0000000 IRQ : 16 NV_PMC_INTR_0 bit 28 high. Trying to clear interrupt by writing 0x0 to register 0x001140 NV_PMC_INTR_0 bit 28 high. Trying to clear interrupt by writing 0x0 to register 0x001144 NV_PMC_INTR_0 bit 30 high. Trying to clear interrupt by writing 0x2 to register 0x12004c Successfully cleared GPU's interrupt state. MODS kernel driver version 3.63 does not support proper hooking. of INTA interrupts for this GPU. Please upgrade the MODS kernel driver to version 3.65 or newer. Error 000000000284 : Gpu.Initialize unsupported system configuration Error 000000000284 : Global.PrintGpuInitError unsupported system configuration Error 000000000284 : Global.InitializeGpuTests unsupported system configuration ERROR: Unable to determine current VGA mode, ax=0x4f03 ERROR: Unable to set VESA mode 0x3, ax=0x4f02 Error 000000000237 : Global.EnableUserInterface unable to set mode PexDevMgr not initialized. Bridge device shutdowns will likely do nothing.
Error Code = 000000000284 (unsupported system configuration)
MODS end : Sun Feb 13 03:38:05 2022 [1.797 seconds (00:00:01.797 h:m:s)]
Что-то про "MODS kernel driver version 3.63 does not support proper hooking. of INTA interrupts for this GPU."
motohomiak
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 18:26 |
Зарегистрирован: 10 янв 2022, 16:12 Наличности на руках: 28.05
Сообщения: 22 Откуда: SPb
Добрый вечер Тестил карточку 1070, изо нет, вторым устройством видится матс -е 1 проходит, -е 5 вот такие ошибки: This message will only appear once. SUBPART RANK0 RD ERR RANK0 WR ERR UNKNOWN ERR ------------- ------------- ------------- ------------ FBIOA[ 31: 0] 0 499520 0 FBIOA[ 63: 32] 0 0 0 FBIOB[ 31: 0] 0 499520 0 FBIOB[ 63: 32] 0 454426 0 FBIOC[ 31: 0] 0 335888 0 FBIOC[ 63: 32] 0 499520 0 FBIOD[ 31: 0] 0 0 0 FBIOD[ 63: 32] 0 499520 0 Подскажите, по вашему мнению с каких банок начать ?? или менять все? или еще какой то тест попробовать?
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 18:28 |
Глянул. Там не только чёрт, там кто угодно ногу сломает. Запустил на другой версии mats, там ядро посвежее - всё равно не считывает видеокарту.
mods.log
MODS start: Sun Feb 13 14:16:22 2022
Version MODS : 367.106 OperatingSystem: Linux (x86_64) Kernel : 4.17.4-gentoo KernelDriver : 3.87 HostName : tinylinux Sys-uuid : 4C4C4544-0032-4310-8043-B6C04F39354A HDD-Serno : 5VM73X79
GPU 0 [03:00.0] dev.sub 0.0 --------------------------- PCI Location : 0x00, 0x03, 0x00, 0x00 DID : 0x1c03 Raw ECID : 0x0000000001c053400000003c27c40591 Raw ECID (GHS) : 0x00000001643c27c4040000000d028380 ECID : PF2V41-13_x05_y14 Device Id : GP106 Revision : a1 NV Base : 0xf3000000 FB Base : 0xe0000000 IRQ : 11
------------------------- BEGIN ASSERT INFO DUMP ------------------------- ent ID = 0x0, (size=0xbf40). NVRM: _pmuLoggerConstructSegment: Segment ID = 0x1, (size=0xfa0). NVRM: inforomGetOCTObject: OCT object load failed, status=0x57 NVRM: Breakpoint on RC Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x00000019! NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_GPC 0x00000003! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
------------------------- BEGIN ASSERT INFO DUMP ------------------------- C Disable Override is disabled NVRM: PCI-E device status errors pending (00000009): NVRM: Clearing these errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x00000019! NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_GPC 0x00000003! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
------------------------- BEGIN ASSERT INFO DUMP ------------------------- se errors.. NVRM: PCI-E device AER errors pending (00200000): NVRM: Clearing these errors.. NVRM: _initThermDefaults: Unable to read VBIOS temperature limits. NVRM: THRMCTL: Current thermal table is not sufficient for VLE support. NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x00000019! NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_GPC 0x00000003! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
------------------------- BEGIN ASSERT INFO DUMP ------------------------- wRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: fbSetCmdSrcIdxForShadowRegs_GP102 Attempt to change the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x00000019! NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_GPC 0x00000003! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
------------------------- BEGIN ASSERT INFO DUMP ------------------------- nge the shadow register cmdSrcIdx to existing cmdSrcIdx (0). Ignoring... NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_SYS 0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : addr=0x00100d1c wrdata=0x00000042! NVRM: mcPrintPprivDebugRegs_GK104 SYS(0) ringstation details : subid=0x00000019 priv_level=0x00000000 priv_master=0x00000019! NVRM: mcPrintPprivDebugRegs_GK104 ringmaster interrupt GBL_WRITE_ERROR_GPC 0x00000003! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(0) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
------------------------- BEGIN ASSERT INFO DUMP ------------------------- GPC(1) ringstation details : addr=0x0013cbe4 wrdata=0x00000000 info=0x1f408201! NVRM: mcPrintPprivDebugRegs_GK104 GPC(1) ringstation details : subid=0x0000001f priv_level=0x00000000 priv_master=0x00000001! NVRM: threadId: 0x0000003e8 irql: 0x000000000 flags: 0x020 NVRM: enterTime: 0x16d343ef6c9ba378 Limits: nonComputeTime: 0x000000000 computeTime: 0x0003d0900 NVRM: _threadNodeCheckTimeout: Timeout was set to: 4000 msecs! NVRM: pmuInstBlkBind_GF100: Error 0x00000065 returned from pmuContextSwitchWait_HAL(pGpu, pPmu). NVRM: bp @ ../../../../resman/kernel/pmu/fermi/pmugf100.c:986
** ModsDrvBreakPoint ** NVRM: *** Cannot load state into the device Error 000000000229 : Gpu.Initialize hardware was not initialized Error 000000000229 : Global.PrintGpuInitError hardware was not initialized Error 000000000229 : Global.InitializeGpuTests hardware was not initialized Skipping DisableUserInterface. Skipping EnableUserInterface. Beginning GPU shut down Shutdown : GPU devices not initialized, skipping GPU nvlink shutdown NVOC: __nvoc_objDelete: Child class OBJREFCNT not freed from parent class OBJHWPM.NVOC: __nvoc_objDelete: Child class OBJREFCNT not freed from parent class OBJPERF.NVRM: busFlushVirtualBar2_VBAR2 found unfreed bar2 mapping of offset 0x17ffe4000! NVRM: bp @ ../../../../resman/kernel/bus/nv50/vbar2.c:364
------------------------- BEGIN ASSERT INFO DUMP ------------------------- M: bp @ ../../../../resman/arch/nvalloc/common/src/nv/objgvaspace.c:1045
** ModsDrvBreakPoint ** NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6258AB0: offset=0x17ffe1000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 62757F0: offset=0x17f20e000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6271200: offset=0x17f20f000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6259880: offset=0x124fc0000 type=1 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 6277170: offset=0x17f140000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 62AAEC0: offset=0x17f20c000 type=0 NVRM: busFlushVirtualBar2_VBAR2: unreleased bar2 mapping 62775B0: offset=0x17f20d000 type=0 NVRM: busFlushVirtualBar2_VBAR2 found 7 unreleased bar2 mappings NVRM: bp @ ../../../../resman/kernel/bus/nv50/vbar2.c:390
MODS end : Sun Feb 13 14:16:30 2022 [8.135 seconds (00:00:08.135 h:m:s)]
Остается только материнку поменять.
Последний раз редактировалось slava_oz 13 фев 2022, 18:53, всего редактировалось 1 раз.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 18:44 |
slava_oz писал(а): Please upgrade the MODS kernel driver to version 3.65 or newer. Просит же обновится. У вас 1060? Эта версия её отлично тестирует, откатывайтесь к дистрибутиву и только ключи у МОДСа поменяйте.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 18:50 |
YunicheK писал(а): Так дело то не в версии ядра, а в версии драйвера. А, точно) Может выложите ему работающий сборник - а то он будет неделю осваивать варианты сборки/запуска/работы МОДСа?! (Я не могу - авторские права чту))))) motohomiak писал(а): Подскажите, по вашему мнению с каких банок начать ?? Снимайте по одной, кроме исправных, часто бывает что одна битая даёт ошибки по всем остальным. Когда останутся 2 исправные - назад по одной будете ставить. motohomiak писал(а): матс -е 1 проходит Это просто даёт шанс, что ГПУ жив.
CatSW
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 19:08 |
slava_oz писал(а): Ребят, я по запаре снова не тот лог выложил. Исправил. Бывает) Вы хоть банку неисправную махнули? МОДС не даст пройти тестам, если сбоит память.
slava_oz
Заголовок сообщения: Re: MATS 295/367/400 со встройки с автозагрузкой Добавлено: 13 фев 2022, 19:25 |
CatSW писал(а): МОДС не даст пройти тестам, если сбоит память. Это как? Он же для этого и предназначен. Махну на следующей неделе. Сначала попробую на другой материнке.
