Текущее время: 22 ноя 2024, 02:05
 Заголовок сообщения: CX62 (MS-16J71) No turn on after water damage
СообщениеДобавлено: 28 май 2022, 13:14
hello my friends
this laptop came with water damage problem and short circiut
it was Q22 and after replacing mosfet and it keeps burning
i remove PU5 Q22 and Q24(Ram supply)
now when i apply power and push power button i hear tiny click sound from cpu area and psu shows 0.1A and C.C light for just a little moment
i want to find does it means dead cpu?
 Заголовок сообщения: Re: CX62 (MS-16J71) No turn on after water damage
СообщениеДобавлено: 28 май 2022, 20:00
where are the measurements? resistance / voltage. or is it necessary to guess.
and RAM is whole? worker ? if the RAM is burned out, then the processor is probably too. After all, the processor communicates directly with RAM.
СообщениеДобавлено: 29 май 2022, 11:03
Serguz05 писал(а):
and RAM is whole? worker? if the RAM is burned out, then the processor is probably too. After all, the processor communicates directly with RAM.
i mean mosfet keeps burning after replacment
i tried replacing TPS51216(pu5)
without mosfets it turns on to 0.2A and 3.3v ,5v and +1V_SUS is on
after adding mosfets it goes to short circuit and even without mosfets use 1.2A when turned on so pu5 died again
i have no more TPS51216 and replaced by G5316RZ1D
now it turnes on and use 0.2A again
how can i find does pwm work correctly and dont kill mosfets again
СообщениеДобавлено: 29 май 2022, 14:45
is RAM installed? if the RAM is defective, then PU5 may burn out.
you also need to check the PU5 harness. what on VBST 15pin, pr72, pc39, pr86,
what is the resistance on Choke6 with ram and without ram.
СообщениеДобавлено: 29 май 2022, 16:31
its all without ram
+1_2VDIMM looks short to ground: 1 Ohm
i remove pu5 ,q22,q244 and still 1 ohm
is it harmful to apply 1V to output?
СообщениеДобавлено: 29 май 2022, 16:53
R EZ A писал(а):
1 Ohm
Well, here's the problem.
you can apply 1v and see what is heated.
СообщениеДобавлено: 31 май 2022, 17:07
cpu get warm
but its not short circuit
it just use 1A and cpu softly get warm
СообщениеДобавлено: 31 май 2022, 17:15
there should not be 1om. If only the processor is heating up, then it is most likely bad.
p.s. and most likely RAM too.
СообщениеДобавлено: 31 май 2022, 18:24
ps and most likely RAM too.
for last test i decided to put G5316RZ1D and mosfets
surprisingly it doesn't burn and 1.2V runs normally!
but with or without ram uses same current:0.3A
and no VCC_CORE,VCCSA or VCC_GT
EC_ALLSYSPG = 3.3V
СообщениеДобавлено: 31 май 2022, 20:19
what is the resistance.
---------- Добавлено спустя 6 минут 39 секунд: ----------
you can try flashing the bios. MSI website has clean bios and ME dump.
СообщениеДобавлено: 01 июн 2022, 16:46
---------- Added after 6 minutes 39 seconds: ----------
its 2.2 omh now
i already tried dump file in forum
also flashed file from msi website and all was same
СообщениеДобавлено: 01 июн 2022, 17:26
R EZ A писал(а):
its 2.2 omh now
this resistance in the RAM power circuit is extremely low.
there is no point in flashing bios.
В этой теме нет новых непрочитанных сообщений. Apple Macbook Pro A1278 (K90i, 820-2936) another motherboard with water damage issue
в форуме Apple
andromedax
22 окт 2015, 20:12
andromedax Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. U46SV (Asus) Water damage
NoLuck
11 фев 2017, 22:05
Гектор Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. G500 (LA-9631) water damage-no+1.05VS
R EZ A
28 авг 2017, 18:41
R EZ A Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 450 G6 (Quanta X8J DA0X8JMB8E0 Rev E DSC) Water Damage, identify of 2 chips
mohammedsf
14 окт 2023, 00:52
mohammedsf Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. apple a2337 (820-02016-a) water damage
в форуме Apple
serwanjaf7
24 апр 2024, 19:00
Serguz05 Перейти к последнему сообщению
