Текущее время: 29 май 2024, 19:46
 Заголовок сообщения: ASUS (GL503VM (DA0BKLMBAD0 Rev D)) No Display / Bios needed
СообщениеДобавлено: 03 июн 2022, 02:34
Hi everyone,
Please help with a bios dump for this board:
Asus GL503VM-FY014T
DA0BKLMBAD0 Rev D
the laptop starts and initialize properly (I can hear sounds from windows), but nothing displayed on internal screen or from hdmi
all the voltages on the CPU & GPU rises, tried another screen, cable checked, a closer inspection shows the lack of "EDP_VDD_EN" signal on U14 (using DABKLMB1AA0 boardview as reference).. no short-circuit found and all resistances on CN3 are in normal range..
Where to dig ? I'm suspecting the bios, please help with the correct dump for this board (DA0BKLMBAD0 Rev D)
В сети
 Заголовок сообщения: Re: ASUS (GL503VM (DA0BKLMBAD0 Rev D)) No Display / Bios needed
СообщениеДобавлено: 03 июн 2022, 02:59
BIOS on asus is searched for by a sticker on the motherboard.
В сети
СообщениеДобавлено: 03 июн 2022, 03:10
Thanks for the reply, the sticker on the board is:
60NB0GI0-MB2230-210
31BKLMB00I0 D3GFP
The printed pcb model is:
DA0BKLMBAD0 Rev: D
В сети
СообщениеДобавлено: 03 июн 2022, 03:19
viewtopic.php?p=819038#p819038
В сети
СообщениеДобавлено: 03 июн 2022, 05:25
tested, still no display (windows loads normally)
cleared the me, still no display
В сети
СообщениеДобавлено: 03 июн 2022, 08:43
Obviously it's not about the BIOS...
СообщениеДобавлено: 04 июн 2022, 00:06
This board doesn't have integrated graphics power for the processor, that's why I was suspecting the bios because some BKL boards has.
all the lines resistances at CN3 and eDP channels are in normal range..
+VIN_BLIGHT = 19.27v
+3VLCD_CON = 0v (EDP_VDD_EN = 0v)
PCH_BRIGHT = 0v
EC_DISP_ON = 0v
PCH_EDP_HPD = 0v
PANEL_ID1 = 3.25v
PANEL_ID2 = 3.25v
eDP lines measured at capacitors from source side:
CPU_EDP_AUXN = 455mv
CPU_EDP_AUXP = 455mv
CPU_EDP_TXP0 = 240mv~260mv
CPU_EDP_TXN0 = 240mv~260mv
CPU_EDP_TXP1 = 240mv~260mv
CPU_EDP_TXN1 = 240mv~260mv
CPU_EDP_TXP2 = 240mv~260mv
CPU_EDP_TXN2 = 240mv~260mv
CPU_EDP_TXP3 = 240mv~260mv
CPU_EDP_TXN3 = 240mv~260mv
Where to dig ?
В сети
В этой теме нет новых непрочитанных сообщений. asus gl503vm (asus gl503vm) не работает подсветка клавиатуры
pwhp
663
03 май 2024, 18:39
king88 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus ROG GL503VM (dabklmb1aa0 rev a) Стопорится на 22 или 04 пост коде
Flagmans
1427
28 июл 2021, 18:52
Flagmans Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus GL503VM (GL503GE) Не могу нигде найти кулера
в форуме Куплю | Buy
Vlad_vs
09 июл 2019, 04:25
mariosik Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS GL503VM (DABKLMB1AA0) Помогите почистить ME
JAX
21
4187
19 дек 2020, 19:09
JAX Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GL503VM (quanta bkl) проблемы с видеокартой
DmitriyDDD
609
28 июл 2023, 07:48
samsonov54 Перейти к последнему сообщению
Сейчас этот форум просматривают: DmitryUN, Ligament, retronik, Yandex [BOT] и гости: 20
