Текущее время: 07 май 2024, 17:19
 Заголовок сообщения: P850 LA-8391p does not detect HDD's / no spin-up
СообщениеДобавлено: 09 мар 2022, 07:28
hello,
this board came with a dead UCL1 (SLG3NB271VTR), no chip in hand so I've tried SLG3NB3454 instead..
the board started and initialized but HDD is not detected in the bios, HDD doesn't spin-up..
3v & 5v and all pins are ok on jhdd
tried to flash the bios, nothing..
replaced all 4 caps on the data lines, still nothing..
does UCL1 affect Sata lines in any way ?
I've noticed that closing pin 18+19 on jhdd to force-on the drive leads the board to no init..
is there a chance to find a boardview ? I need help to locate RH43/RH48/RH41/RH242 & T86
 Заголовок сообщения: Re: P850 LA-8391p does not detect HDD's / no spin-up
СообщениеДобавлено: 09 мар 2022, 07:56
SLG3NB271VTR не меняется на SLG3NB3454
у SLG3NB3454 12-я нога - CLK_27M_XTAL_IN
у SLG3NB271VTR - NC
5 - 25M/// 24M
итд.
Компонентный ремонт ноутбуков в Краснодаре. +7 961 5O8-57-55 ( не посредник )
СообщениеДобавлено: 09 мар 2022, 19:30
thanks for the replay..
i know it is not compatible but does it affect operation of sata ports ?
since i don't have the slg3nb271 chip now i'm converting the board installing the clocks to no green-clocks for a test..
СообщениеДобавлено: 09 мар 2022, 20:55
https://aliexpress.ru/w/wholesale-3271v.html
СообщениеДобавлено: 27 мар 2022, 02:46
I also put 3454 (DAY11) instead of 271 and the same thing happens that when the laptop is turned on, it doesn't see hdd or odd. Now I'm trying to find SLG3NB271VTR or SLG3NB304VTR - (Rimas said that the laptop with that replacement works). viewtopic.php?f=54&t=54746&p=853104&hilit=%2Ala+8391p%2A#p853104
СообщениеДобавлено: 10 июн 2022, 05:05
The non-green clock conversion didn't work for me, it was repaired by using the correct exact chip "SLG3NB271VTR"
closing the topic
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. hp 8440 (fan not spin ) fan not spin in battery mode
rajeshkumar
26 авг 2016, 12:32
rajeshkumar Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. TOSHIBA SATELLITE P850-138 (LA-8391P) Постоянный ребут, непонятная реакция после старта без flash 4M BIOS..
в форуме Toshiba
Labus
02 июн 2014, 16:16
Labus Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Toshiba P850 (la-8391p) страпы UMA/DIS
в форуме Toshiba
koshmar
12 янв 2021, 12:47
tol1k93 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. P850-138 (la-8391p rev1.0) Просадка по B+ после КЗ по BATT+
в форуме Toshiba
jjoloka
18 янв 2018, 13:07
jjoloka Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 250 (G3 ) Not detect HDD
serwanjaf7
18 ноя 2017, 22:56
novatox Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 13
