Текущее время: 29 ноя 2026, 17:02
MoneyBot
Заголовок сообщения: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error |
ll_r1d0_ll
Заголовок сообщения: Re: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error  Добавлено: 13 июл 2022, 12:53 |
| Интересующийся |
Зарегистрирован: 27 май 2022, 15:08 Наличности на руках: 41.03
Сообщения: 66 Откуда: Pakistanrepublic
com77 писал(а): ll_r1d0_ll Remove the GPU and memory, and look for a break along the lines D0 & D1, when you find it, restore it. There may be a broken track or transition. Hi thanks for the response. Without removing the main chip I measured each and every trace from a donor motherboard whose only mosfet section was blown. All the values seemed normal on each trace. I am trying to avoid removing the main chip because it will then take alot of effort remove the main chip then reball and reinstall. I was hoping if there would be any other method for testing or anyone who had the same issue like me.
com77
Заголовок сообщения: Re: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error  Добавлено: 15 июл 2022, 12:25 |
| Продвинутый форумчанин |
Зарегистрирован: 08 дек 2018, 12:28 Наличности на руках: 1,423.91
Сообщения: 1772 Откуда: Москва
ll_r1d0_llYes, it's the same here: viewtopic.php?f=48&t=112417Remove the GPU and look for a break.
_________________ 现在的也越来越难修啊,生意真是不好做啊! © Конфуций из Шэньчжэня
ll_r1d0_ll
Заголовок сообщения: Re: MSI/XFX/SAPPHIRE RX 480/580 D0 D1 Memory error  Добавлено: 22 окт 2022, 18:10 |
| Интересующийся |
com77 писал(а): _r1d0_ll Yes, it's the same here: viewtopic.php?f=48&t=112417 Remove the GPU and look for a break. Hello. Just to update it was the faulty resistor behind the memory . Replaced it and card booted up fine. Thanks for the reply
