Текущее время: 25 ноя 2026, 18:45
 Заголовок сообщения: Dell G3 3779 (LA-F611P) Self-Charging when charger is disconnected
СообщениеДобавлено: 01 окт 2022, 05:52
Hello everyone, I've spent 3 days on this laptop and I'm at my wits end.The initial fault was a burnt PU01 (RT9069-33GB) and PUB02 (TC7SH08FU), and upon replacement, laptop works and charges the battery.
The issue now is that, when laptop is powered from battery, it shows 'Charger Unknown', instead of 'Charger not Detected' in bios, and when charger is connected, it shows correct wattage and charges the battery, but when charger is disconnected, it still shows charger as connected and is seemingly charging and shows charger wattage in bios, as well as charging LED indicator is on. Indicator stays lit even if the laptop is off and charger is disconnected. I've replaced Charge IC and checked all resistors and mosfets and capacitors in the power chain... only thing I've not been able to replace is the EC (MEC1416-NU), since I don't have a replacement. could it be the EC controller? Any signals I should investigate? Any help will be appreciated.
 Заголовок сообщения: Re: Dell G3 3779 (LA-F611P) Self-Charging when charger is disconnected
СообщениеДобавлено: 01 окт 2022, 10:42
check the entire circuit PS_ID all resistors
PQ1, PQ2, PD1, PD2, PD3 check/replace
СообщениеДобавлено: 01 окт 2022, 16:05
PS_ID circuit is intact... PD1,2,3 are not on the motherboard
 Заголовок сообщения: Re: Dell G3 3779 (LA-F611P) Self-Charging when charger is disconnected  [РЕШЕНО]
СообщениеДобавлено: 02 окт 2022, 05:46
After much fidgeting with this board, it turned out that PUB02 was leaking excess voltage on pin 4 (HW_ACAV_IN) ... before replacement, voltage was around 2.08v with charger disconnected, that I suppose, made the EC think charger was still connected ... after PUB02 replacement, voltage is now 1.775v on pin 4 with charger disconnected. Laptop is working as it should.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell G3 3779 (LA-F611P) АКБ не заряжается, клавиатура и тачпад лагают
в форуме Dell
zokir
13
5990
23 сен 2020, 12:18
zokir Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell G3 3779 (la-f611p) подсветка клавиатуры
в форуме Dell
And_R
13 мар 2025, 15:02
And_R Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
kosmo555
18
3796
28 янв 2021, 14:39
kosmo555 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Samsung Charger Adapter Stopped Working Not Charging At all
labrepair
23 окт 2026, 13:39
labrepair Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Нужна схема БП HP AP091F13P 8 SELF rev: 06
sergmsv73
18 апр 2020, 23:30
sergmsv73 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 33
