Заголовок сообщения: Zotac GTX1080Ti - Help with activating the GS9238 ci
Добавлено: 03 окт 2022, 18:06
Зарегистрирован: 18 мар 2020, 03:02 Наличности на руках: 21.68 Сообщения: 184 Откуда: Brasil
greetings, I'm having trouble getting the GS9238 ci to work generating the 1.8v for bios and logic sequences on the board. Could someone give me an idea about the problem? follows an image with the voltages present in the IC:
MoneyBot
madking
Заголовок сообщения: Re: Zotac GTX1080Ti - Help with activating the GS9238 ci
Добавлено: 03 окт 2022, 18:37
Зарегистрирован: 03 ноя 2017, 00:24 Наличности на руках: 3,829.01 Сообщения: 4193 Откуда: Budapest
what is the resistance of LX
TheMArcos
Добавлено: 03 окт 2022, 19:31
starts with 0.8k and goes up 1.8k, I already injected 1v and there is no heating, with the thermal camera.
I haven't tried replacing the GS yet, I wanted to know if the polarization is normal first.
madking
Добавлено: 03 окт 2022, 21:38
replacing the GS
TheMArcos
Добавлено: 14 окт 2022, 02:47
thanks for the help, the IC arrived and after replacement the new ci worked generating the 18v. I will close the top
Сейчас этот форум просматривают: Pahha, yurr, Zipaoff и гости: 54
