Текущее время: 27 сен 2024, 14:55
uncledim
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 03 окт 2022, 11:50 |
Зарегистрирован: 22 дек 2016, 12:07 Наличности на руках: 1,135.36
Сообщения: 1102 Откуда: Moscow
Pandemonium6 писал(а): when it runs in Windows, only one or two phases work It's normal behavior, isn't it? btw, usb005 is not programmer only. have you checked phase faults in powircenter while running Windows, idle & at load?
Pandemonium6
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 03 окт 2022, 16:05 |
Зарегистрирован: 22 июл 2021, 03:06 Наличности на руках: 1,139.72
Сообщения: 761 Откуда: Holand
uncledim писал(а): It's normal behavior, isn't it? btw, usb005 is not programmer only. have you checked phase faults in powercenter while running Windows, idle & at load?
It is not a normal behavior. All other cards I have now in my hands, but from different manufacturers, behave differently. All phases start at once with smaller duty cycle but all phases work immediately from the start. This Asrock behaves differently. All are based on IR35217, I have replacement chips directly from Mouser USA. USB005 does not show any faults. There must be something wrong in configuration or something else. What is responsible for ruch behavior that all phases start at the same time? Which configuration value?
uncledim
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 03 окт 2022, 20:25 |
Pandemonium6 писал(а): What is responsible for ruch behavior that all phases start at the same time? Which configuration value?
Try to set 00 at 0x2C, 2D, 2E (See power saving section) See also attached config for example (powercolor rx 5600 itx, 7+1) ---------- Добавлено спустя 41 минуту 50 секунд: ---------- Pandemonium6 писал(а): I have read configuration by an original USB005 have you done it without pci-e connection to motherboard?
uncledim
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 04 окт 2022, 08:16 |
Pandemonium6 писал(а): through the riser, normally. I mean the card should only get power (3.3V is enough) from riser, no communication with pcie host. Once you allow card (vbios, OS driver) to start - you'll get incorrect dump.
Pandemonium6
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 07 окт 2022, 00:24 |
Hi I did everything properly this time. I saved configuration properly, swapped controllers again. After clearing 0x2C, 0x2D and 0x2E there is one phase as before but it stops running after 3-5 seconds and the VCORE disables itself. I have 3 more programming attempts on the counter so I can test something Zeroing these registers did not make it all phase mode. I programmed back the original file and it works as before.
uncledim
Заголовок сообщения: Re: Asrock 5700 XT IR35217 replaced no change Добавлено: 07 окт 2022, 08:51 |
Pandemonium6 писал(а): I saved configuration properly Is there ahy differences (vs "first attempt" config)? Pandemonium6 писал(а): Zeroing these registers did not make it all phase mode Maybe some additional mods are needed. See another config (gigabyte 5600 7+1) from Mafia67
