MODS arguments :
MODS start: Thu Oct 20 23:32:51 2022
Command Line : gputest.js -test 275 -skip_rm_state_init
CPU
Arch : x86_64
Name : Intel(R) Core(TM) i5-4590 CPU @ 3.30GHz
Cores : 4
Version
MODS : 455.219
System
OperatingSystem: Linux (x86_64)
Kernel : 5.9.1-gentoo-x86_64
KernelDriver : 4.00
SBIOS Version : V1.10
SBIOS Date : 07/10/2018
HostName : tinylinux
Available RAM : 7421/7923 MB (Free/Size)
Sys-uuid :
HDD-Serno :
GPU 0 [01:00.0] dev.sub 0.0
DevInst : 0
PCI Location : 0x00, 0x01, 0x00, 0x00
GPU DID : 0x2216
PDI : 0xa6bc10e339297f8f
Raw ECID : 0x004005400000005d978c5dc4
Raw ECID (GHS) : 0x4705d978c5c00000015000080
ECID : SAMSUNG-SNPUCN-21_x0_y2
Device Id : GA102
Revision : a1
Sub Revision : 1
NV Base : 0xf6000000
FB Base : 0xe0000000
IRQ : 11
Chipset
VID : FFFF (Unknown)
Chipset DID : FFFF (Unknown)
Chipset ASPM : L0s/L1
Chipset LTR : Enabled
resumehandler.js: 1
gputest.js : 39
base.spc : 14
boards.js : 1
Running test(s) on GPU 0 [01:00.0] (DID: 0x2216)
ERROR: ERROR LOADING BUS INFO! RmControl call failed! RC = 674
Enter BaseBoostClockTest (test 275) Thu Oct 20 23:32:52 2022
Exit 000000275021 : BaseBoostClockTest (test 275) script failed to execute [0.001 seconds]
Error!
Error 000000275021 : BaseBoostClockTest (test 275) script failed to execute [0.004 seconds]
[ 0] ------------------------- BEGIN ASSERT INFO DUMP -------------------------
[ 0] TU10x floorsweeping parameter mask values: nvlink=0x0
[ 0] AmpereFs : Floorsweeping parameters present on commandline:
[ 0] AmpereFs : Floorsweeping parameters mask values:
[ 0] _b2DMGpuSubdevice: Floorsweeping parameters present on commandline:
_b2DMGpuSubdevice: Floorsweeping parameters mask values: gpc_rop[0]=0x0 gpc_rop[1]=0x0 gpc_rop[2]=0x0 gpc_rop[3]=0x0 gpc_rop[4]=0x0 gpc_rop[5]=0x0 gpc_rop[6]=0x0 gpc_rop[7]=0x0 gpc_rop[8]=0x0 gpc_rop[9]=0x0 gpc_rop[10]=0x0 gpc_rop[11]=0x0 gpc_rop[12]=0x0 gpc_rop[13]=0x0 gpc_rop[14]=0x0 gpc_rop[15]=0x0
[ 0] fbp_l2slice[0]=0x0 fbp_l2slice[1]=0x0 fbp_l2slice[2]=0x0 fbp_l2slice[3]=0x0 fbp_l2slice[4]=0x0 fbp_l2slice[5]=0x0 fbp_l2slice[6]=0x0 fbp_l2slice[7]=0x0 fbp_l2slice[8]=0x0 fbp_l2slice[9]=0x0 fbp_l2slice[10]=0x0 fbp_l2slice[11]=0x0 fbp_l2slice[12]=0x0 fbp_l2slice[13]=0x0 fbp_l2slice[14]=0x0 fbp_l2slice[15]=0x0
[ 0] Unknown init property : FbGddr5x8Mode
[ 0] UnlockHost2Jtag:Start
[ 0] WriteHost2Jtag: Writing data of size 2 [ 0x1fffe00 0x0 ] to cluster [ [ "chipletId":0 "instrId":8 ] ] with chain length 57
[ 0] WARNING... Failed to unlock Jtag for access!
[ 0] Found GPUs:
[ 0] DevInst 0 0000:01:00.0 DevId:2216 ChipId:172 GpuInst 0
[ 0] Created a NullDisplay
[ 0]
[ 0] Chipset
[ 0] VID : FFFF (Unknown)
[ 0] Chipset DID : FFFF (Unknown)
[ 0] Chipset ASPM : L0s/L1
[ 0] Chipset LTR : Enabled
[ 0]
[ 0] Successfully opened /proc/self/maps
[ 0] Forcing parallel test groups to be disabled due to
http://nvbugs/1888064[ 0] GPU 0 [01:00.0] : Will test these PerfPoints:
[ 0] fileid.js : 2
[ 0] random2d.js : 2
[ 0] comngpu.js : 5
[ 0] gpulist.js : 3
[ 0] resumehandler.js: 1
[ 0] gputest.js : 39
[ 0] base.spc : 14
[ 0] boards.js : 1
[ 0]
http://nvbugs/1888064[ 0] Primary GPU not detected, skipping DisableUserInterface.
[ 0] Entering AddThread
[ 0] Leaving AddThread
[ 0] Entering StartRunning
[ 0] Not Tasker Thread Group main_tests
[ 0] +++thread_name:'main_tests' thread ID: 11 +++
[ 0] Leaving StartRunning
[ 0] Group [main_group] Entering WaitForAllThreadsToFinish
[ 0] waiting on thread ID 11
[ 0] Entering RunThread
[ 0] Calling my start listeners:
[ 0] About to call my run function
[ 0] Running test(s) on GPU 0 [01:00.0] (DID: 0x2216)
[ 0] NVRM: Check failed: Requested object not found [NV_ERR_OBJECT_NOT_FOUND] (0x00000057) returned from 0x000000000198d82f
[ 0] ERROR LOADING BUS INFO! RmControl call failed! RC = 674
[ 0] Enter SignalSetupCompleteAndWait
[ 0] Enter WaitForAllThreadsToSetup
[ 0] Thread main_tests setup is done
[ 0] WaitForAllThreadsToSetup: allSetupDone = true
[ 0] Holding off to let background threads start
[ 0] [resumeHandler] Saving status for test 0 of 1 (#0)
[ 0] Not Tasker Thread Group device_0_test_0
[ 0] +++thread_name:'device_0_test_0' thread ID: 12 +++
[ 0] Group [device_group] Entering WaitForAllThreadsToFinish
[ 0] Enter SetDeviceCpuAffinity
[ 0] Setting affinity on thread 12
[ 0] waiting on thread ID 12
[ 0] Warning: SetPState is not supported. Skipping.
[ 0] Thread device_0_test_0 setup is done
[ 0] Finished my run function
[ 0] Calling my stop listeners:
[ 0] Leaving RunThread
[ 0] DONE waiting on thread ID 12
[ 0] Leaving WaitForAllThreadsToFinish
[ 0] [resumeHandler] Saving status for test 1 of 1 (#275)
[ 0] Not Tasker Thread Group device_0_test_275
[ 0] +++thread_name:'device_0_test_275' thread ID: 13 +++
[ 0] waiting on thread ID 13
[ 0] Setting affinity on thread 13
[ 0] Thread device_0_test_275 setup is done
[ 0] ModsTest Js Properties:
[ 0] Test name: BaseBoostClockTest
[ 0] MassertVerboseFlags: 0x0000
[ 0] MassertAllowed: 0x0
[ 0] MassertDisabled: false
[ 0] UnexpectedHwIntVerboseFlags: 0x0000
[ 0] UnexpectedHwIntAllowed: 0x0
[ 0] UnexpectedHwIntDisabled: false
[ 0] PrintQueueOverflowVerboseFlags: 0x0000
[ 0] PrintQueueOverflowAllowed: 0x0
[ 0] PrintQueueOverflowDisabled: false
[ 0] Testing device : GPU 0 [01:00.0]
[ 0] DisableRcWatchdog : false
[ 0] PwrSampleIntervalMs : 500
[ 0] TargetNvSwitch : false
[ 0] CheckPickers : false
[ 0] TestConfiguration Js Properties:
[ 0] StartLoop: 0
[ 0] RestartSkipCount: 100
[ 0] Loops: 1000
[ 0] Seed: 0x12345678
[ 0] TimeoutMs: 1000.000000
[ 0] Display: 1024x768x32 60Hz
[ 0] ZDepth: 32
[ 0] FSAAMode: Disabled
[ 0] Surface: 1024x768
[ 0] PushBufferLocation: Memory::Coherent
[ 0] DstLocation: Memory::Optimal
[ 0] SrcLocation: Memory::Optimal
[ 0] MemoryType: Memory::Coherent
[ 0] UseIndMem: false
[ 0] ChannelType: UseNewestAvailable (multiple channels NOT allowed)
[ 0] ChannelSize: 0x00100000 (1048576)
[ 0] UseTiledSurface: false
[ 0] DisableCrt: false
[ 0] EarlyExitOnErrCount: false
[ 0] Verbose: false
[ 0] ShortenTestForSim: false
[ 0] Dma Protocol: Default
[ 0] NotifierLocation: Memory::Coherent
[ 0] GpFifoEntries: 0x00000200 (512)
[ 0] AutoFlush: true
[ 0] AutoFlushThresh: 256
[ 0] ChannelLogging: false
[ 0] AllowVIC: true
[ 0] SemaphorePayloadSize: Default
[ 0] DisplayMgrRequirements: PreferRealDisplay
[ 0] UseOldRNG: false
[ 0] UphyLogMask: 0x0
[ 0] GoldenValues Js Properties:
[ 0] PlatformName: GA102
[ 0] NameSuffix:
[ 0] Action: Golden.Check
[ 0] SkipCount: 100
[ 0] Codes: 0
[ 0] NumCodeBins: 97
[ 0] StopOnError: true
[ 0] BufferFetchHint: opCpuDma
[ 0] CalculationAlgorithm: CpuCalcAlgorithm
[ 0] CheckDmaOnFail: false
[ 0] RetryDmaOnFail: false
[ 0] SendTrigger: false
[ 0] TriggerLoop: 0
[ 0] TriggerSubdevice: 0
[ 0] PrintCsv: false
[ 0] Print: 0 (Never)
[ 0] Interact: 0 (Never)
[ 0] DumpTga: 0 (Never)
[ 0] DumpPng: 0 (Never)
[ 0] Enter BaseBoostClockTest (test 275) Thu Oct 20 23:32:52 2022
[ 0] First error recorded: 21 script failed to execute
[ 0] JavaScript stack trace:
[ 0] #0: BaseBoostClockTest_Run() in gputest.jse:0
[ 0] #1: Run() in <native>:0
[ 0] #2: RunGpuTestThread() in gputest.jse:2965
[ 0] #3: apply() in <native>:0
[ 0] #4: RunThread() in gputest.jse:601
[ 0] #5: GroupRunFcn() in gputest.jse:615
[ 0] Exit 000000275021 : BaseBoostClockTest (test 275) script failed to execute [0.001 seconds]
Error!
[ 0] Error 000000275021 : BaseBoostClockTest (test 275) script failed to execute [0.004 seconds]
[ 0] DONE waiting on thread ID 13
[ 0] [resumeHandler] CleanupResume(testArray, 1, 275).
[ 0] -------------------------- END ASSERT INFO DUMP --------------------------
----------call stack----------
Thread 10 (LWP 2953):
#0 0x00007fafb0212177 in ?? ()
#1 0x00000000005915ce in ?? ()
#2 0x00007faf897f5108 in ?? ()
#3 0x0000000000000b8c in ?? () from /lib64/ld-linux-x86-64.so.2
#4 0x0000000000000000 in ?? ()
Thread 9 (LWP 2952):
#0 0x00007fafb03b87a2 in ?? ()
#1 0x0000000000000000 in ?? ()
Thread 8 (LWP 2951):
#1 0x0000000000000067 in ?? ()
#2 0x0000000000000000 in ?? ()
Thread 7 (LWP 2950):
#0 0x00007fafb0238b7f in ?? ()
#1 0x000000000a6bc9c0 in ?? ()
#2 0x00007faf8affa7d0 in ?? ()
#3 0x0000000000000002 in ?? ()
#4 0x000027100a6bc960 in ?? ()
#5 0x00007faf8affa800 in ?? ()
#6 0x00000000005a3084 in ?? ()
#7 0x0000000000000000 in ?? ()
Thread 6 (LWP 2947):
#0 0x00007fafb03b84b5 in ?? ()
#1 0x0000000000000003 in ?? ()
#2 0x0000000000000001 in ?? ()
#3 0x0000000000000004 in ?? ()
#4 0x00007faf9cff46f0 in ?? ()
#5 0x0000000000000007 in ?? ()
#6 0x000000010b068b00 in ?? ()
#7 0x00007fafb03b8270 in ?? ()
#8 0x00007faf9cff46f0 in ?? ()
#9 0x000000000af1e388 in ?? ()
#10 0x0000000000000000 in ?? ()
Thread 5 (LWP 2946):
#1 0x00000000ffffffff in ?? ()
#2 0x00007faf9d7f57c0 in ?? ()
#4 0xffffffff0ab8b630 in ?? ()
#5 0x000000000058d720 in ?? ()
#6 0x000000000058d7a9 in ?? ()
#7 0x000000000ab8b630 in ?? ()
#8 0x000000000ab8b630 in ?? ()
#9 0x0000000100000003 in ?? ()
#10 0x0000000100000004 in ?? ()
#11 0x00007faf84002820 in ?? ()
#12 0x0000000000000000 in ?? ()
Thread 4 (LWP 2945):
#1 0x0000000000000005 in ?? ()
#4 0x00007faf9dff6700 in ?? ()
#5 0x000000000000000b in ?? ()
#6 0x0000000000000000 in ?? ()
Thread 3 (LWP 2944):
#1 0x0000000000001ab5 in ?? () from /lib64/ld-linux-x86-64.so.2
#2 0x0000000000000004 in ?? ()
#3 0x00007faf9e7f76f0 in ?? ()
#4 0x000000000000356b in ?? () from /lib64/ld-linux-x86-64.so.2
Thread 2 (LWP 2943):
#1 0x0000000000000077 in ?? ()
Thread 1 (LWP 2798):
#0 0x00007fafb03b33e7 in ?? ()
#1 0x0000000000000001 in ?? ()
#2 0x00007fff3c2ef0f0 in ?? ()
#3 0x00007fff3c2ef128 in ?? ()
#4 0x000000000af067d0 in ?? ()
#5 0x000000000ade0da0 in ?? ()
#6 0x000000000ade0da8 in ?? ()
#7 0x00007fafb03b31d0 in ?? ()
#8 0x00007faf897fc628 in ?? ()
#9 0x0000000000000001 in ?? ()
