Текущее время: 30 апр 2024, 18:28
 Заголовок сообщения: Inno3D 1080Ti memory problems
СообщениеДобавлено: 21 ноя 2022, 22:30
Hello everyone,
I am first time trying to fix a card that gives memory errors in MATS.
Symptoms: the PC boots with the card, can run MATS, but would not boot to Windows on my test PC at all (just black screen). It was able to boot to my friend's PC, but was giving artifacts. He said once the PC started stuttering, then froze. After resetting the PC - artifacts started to appear. Sometimes visible even in GRUB.
The MATS log is here, seems has errors on 5 chips. I am no expert in the memory error types, but based on this - is it a dead core or really 5 bad memory chips? Or could it be something else?
mats version 400.281.  Testing GP102 with 20 MB of memory starting with 0 MB.
Read    Error Count: 0
Write   Error Count: 448
Unknown Error Count: 0
=== MEMORY ERRORS BY SUBPARTITION ===
SUBPART READ ERRORS WRITE ERRORS UNKNOWN ERRS
FBIOA0            0            0            0
FBIOA1            0            0            0
FBIOB0            0            0            0
FBIOB1            0            0            0
FBIOC0            0           16            0
FBIOC1            0           96            0
FBIOD0            0          128            0
FBIOD1            0          128            0
FBIOE0            0           80            0
FBIOE1            0            0            0
FBIOF0            0            0            0
FBIOF1            0            0            0
Failing Bits:
   C000 C001 C002 C003 C004 C005 C006 C007 C008 C009 C010 C011 C012 C013 C014 C015
C016 C017 C018 C019 C020 C021 C022 C023 C024 C025 C026 C027 C028 C029 C030 C031
C032 C033 C034 C035 C036 C037 C038 C039 C040 C041 C042 C043 C044 C045 C046 C047
C048 C049 C050 C051 C052 C053 C054 C055 C056 C057 C058 C059 C060 C061 C062 C063
D000 D001 D002 D003 D004 D005 D006 D007 D008 D009 D010 D011 D012 D013 D014 D015
D016 D017 D018 D019 D020 D021 D022 D023 D024 D025 D026 D027 D028 D029 D030 D031
D032 D033 D034 D035 D036 D037 D038 D039 D040 D041 D042 D043 D044 D045 D046 D047
D048 D049 D050 D051 D052 D053 D054 D055 D056 D057 D058 D059 D060 D061 D062 D063
E000 E001 E002 E003 E004 E006 E007 E011 E012 E013 E014 E015 E016 E017 E018 E019
E020 E022 E023 E027 E028 E029 E030 E031
=== MEMORY ERRORS BY BIT ===
P : Partition (FBIO)
                                            READ 0 READ 1 READ ?
P BIT READ ERRORS WRITE ERRORS UNKNOWN ERRS EXP. 1 EXP. 0 EXP. ?
C 000           0            3            0      2      1      0
C 001           0            4            0      2      2      0
C 002           0            2            0      2      0      0
C 003           0            3            0      2      1      0
C 004           0            6            0      4      2      0
C 005           0            4            0      0      4      0
C 006           0            3            0      1      2      0
C 007           0            4            0      4      0      0
C 008           0            4            0      0      4      0
C 009           0            4            0      0      4      0
C 010           0            4            0      0      4      0
C 011           0            4            0      4      0      0
C 012           0            4            0      4      0      0
C 013           0            4            0      4      0      0
C 014           0            4            0      4      0      0
C 015           0            4            0      4      0      0
C 016           0            4            0      2      2      0
C 017           0            3            0      2      1      0
C 018           0            3            0      1      2      0
C 019           0            4            0      3      1      0
C 020           0            4            0      3      1      0
C 021           0            4            0      0      4      0
C 022           0            4            0      0      4      0
C 023           0            4            0      4      0      0
C 024           0            4            0      0      4      0
C 025           0            4            0      0      4      0
C 026           0            4            0      0      4      0
C 027           0            4            0      4      0      0
C 028           0            4            0      4      0      0
C 029           0            4            0      4      0      0
C 030           0            4            0      4      0      0
C 031           0            4            0      4      0      0
C 032           0           20            0     18      2      0
C 033           0           21            0     18      3      0
C 034           0           19            0     16      3      0
C 035           0           22            0     21      1      0
C 036           0           22            0     20      2      0
C 037           0           24            0      0     24      0
C 038           0           16            0     12      4      0
C 039           0           24            0     24      0      0
C 040           0           24            0      0     24      0
C 041           0           24            0      0     24      0
C 042           0           24            0      0     24      0
C 043           0           24            0     24      0      0
C 044           0           24            0     24      0      0
C 045           0           24            0     24      0      0
C 046           0           24            0     24      0      0
C 047           0           24            0     24      0      0
C 048           0           21            0     18      3      0
C 049           0           20            0     18      2      0
C 050           0           22            0     21      1      0
C 051           0           21            0     20      1      0
C 052           0           22            0     21      1      0
C 053           0           24            0      0     24      0
C 054           0           19            0     15      4      0
C 055           0           24            0     24      0      0
C 056           0           24            0      0     24      0
C 057           0           24            0      0     24      0
C 058           0           24            0      0     24      0
C 059           0           24            0     24      0      0
C 060           0           24            0     24      0      0
C 061           0           24            0     24      0      0
C 062           0           24            0     24      0      0
C 063           0           24            0     24      0      0
D 000           0           37            0     34      3      0
D 001           0           45            0     41      4      0
D 002           0           41            0     38      3      0
D 003           0           44            0     42      2      0
D 004           0           39            0     37      2      0
D 005           0           16            0      0     16      0
D 006           0           39            0     34      5      0
D 007           0           48            0     48      0      0
D 008           0           16            0      0     16      0
D 009           0           16            0      0     16      0
D 010           0           16            0      0     16      0
D 011           0           48            0     48      0      0
D 012           0           48            0     48      0      0
D 013           0           48            0     48      0      0
D 014           0           48            0     48      0      0
D 015           0           48            0     48      0      0
D 016           0           45            0     40      5      0
D 017           0           37            0     35      2      0
D 018           0           41            0     37      4      0
D 019           0           40            0     38      2      0
D 020           0           39            0     37      2      0
D 021           0           16            0      0     16      0
D 022           0           44            0     36      8      0
D 023           0           48            0     48      0      0
D 024           0           16            0      0     16      0
D 025           0           16            0      0     16      0
D 026           0           16            0      0     16      0
D 027           0           48            0     48      0      0
D 028           0           48            0     48      0      0
D 029           0           48            0     48      0      0
D 030           0           48            0     48      0      0
D 031           0           48            0     48      0      0
D 032           0           43            0     39      4      0
D 033           0           43            0     39      4      0
D 034           0           41            0     36      5      0
D 035           0           46            0     40      6      0
D 036           0           41            0     37      4      0
D 037           0           24            0      5     19      0
D 038           0           45            0     36      9      0
D 039           0           44            0     44      0      0
D 040           0           20            0      0     20      0
D 041           0           20            0      0     20      0
D 042           0           20            0      0     20      0
D 043           0           44            0     44      0      0
D 044           0           44            0     44      0      0
D 045           0           44            0     44      0      0
D 046           0           44            0     44      0      0
D 047           0           44            0     44      0      0
D 048           0           46            0     36     10      0
D 049           0           44            0     38      6      0
D 050           0           40            0     36      4      0
D 051           0           40            0     39      1      0
D 052           0           42            0     38      4      0
D 053           0           24            0      4     20      0
D 054           0           41            0     31     10      0
D 055           0           44            0     44      0      0
D 056           0           20            0      0     20      0
D 057           0           20            0      0     20      0
D 058           0           20            0      0     20      0
D 059           0           44            0     44      0      0
D 060           0           44            0     44      0      0
D 061           0           44            0     44      0      0
D 062           0           44            0     44      0      0
D 063           0           44            0     44      0      0
E 000           0           40            0     40      0      0
E 001           0           40            0     40      0      0
E 002           0           40            0     40      0      0
E 003           0           40            0     40      0      0
E 004           0           40            0     40      0      0
E 006           0           40            0     40      0      0
E 007           0           40            0     40      0      0
E 011           0           40            0     40      0      0
E 012           0           40            0     40      0      0
E 013           0           40            0     40      0      0
E 014           0           40            0     40      0      0
E 015           0           40            0     40      0      0
E 016           0           40            0     40      0      0
E 017           0           40            0     40      0      0
E 018           0           40            0     40      0      0
E 019           0           40            0     40      0      0
E 020           0           40            0     40      0      0
E 022           0           40            0     40      0      0
E 023           0           40            0     40      0      0
E 027           0           40            0     40      0      0
E 028           0           40            0     40      0      0
E 029           0           40            0     40      0      0
E 030           0           40            0     40      0      0
E 031           0           40            0     40      0      0
=== MEMORY ERRORS BY ADDRESS ===
ADDRESS : Failing memory address, or buffer offset if starting with 'X+'
T : Type of memory error: W = write, R = read
S : Subpartition
B : Bank
E : Beat
U : PseudoChannel
   ADDRESS EXPECTED   ACTUAL  REREAD1  REREAD2 FAILBITS TPSBEU  ROW COL                                                      BIT(s)
000001c038 00000000 00000772 00000772 00000772 00000772 WC1140 0000 031                          C033,C036,C037,C038,C040,C041,C042
000001c030 00000000 00000765 00000765 00000765 00000765 WC1100 0000 031                          C032,C034,C037,C038,C040,C041,C042
000001c028 00000000 00000776 00000776 00000776 00000776 WC1140 0000 030                     C033,C034,C036,C037,C038,C040,C041,C042
000001c020 00000000 0000076f 0000076f 0000076f 0000076f WC1100 0000 030                C032,C033,C034,C035,C037,C038,C040,C041,C042
000001c018 00000000 00000763 00000763 00000763 00000763 WC1141 0000 031                          C048,C049,C053,C054,C056,C057,C058
000001c010 00000000 00000773 00000773 00000773 00000773 WC1101 0000 031                     C048,C049,C052,C053,C054,C056,C057,C058
000001c008 00000000 00000769 00000769 00000769 00000769 WC1141 0000 030                          C048,C051,C053,C054,C056,C057,C058
000001c000 00000000 00000764 00000764 00000764 00000764 WC1101 0000 030                               C050,C053,C054,C056,C057,C058
000001bfb8 00000000 00000720 00000720 00000720 00000720 WC0140 0000 01d                                         C005,C008,C009,C010
000001bfb0 00000000 0000073a 0000073a 0000073a 0000073a WC0100 0000 01d                          C001,C003,C004,C005,C008,C009,C010
000001bfa8 00000000 00000763 00000763 00000763 00000763 WC0140 0000 01c                          C000,C001,C005,C006,C008,C009,C010
000001bfa0 00000000 00000770 00000770 00000770 00000770 WC0100 0000 01c                               C004,C005,C006,C008,C009,C010
000001bf98 00000000 00000763 00000763 00000763 00000763 WC0141 0000 01d                          C016,C017,C021,C022,C024,C025,C026
000001bf90 00000000 00000768 00000768 00000768 00000768 WC0101 0000 01d                               C019,C021,C022,C024,C025,C026
000001bf88 00000000 00000764 00000764 00000764 00000764 WC0141 0000 01c                               C018,C021,C022,C024,C025,C026
000001bf80 00000000 00000775 00000775 00000775 00000775 WC0101 0000 01c                     C016,C018,C020,C021,C022,C024,C025,C026
000001c238 00000000 00000720 00000720 00000720 00000720 WC1141 0000 039                                         C053,C056,C057,C058
000001c230 00000000 00000720 00000720 00000720 00000720 WC1101 0000 039                                         C053,C056,C057,C058
000001c228 00000000 00000720 00000720 00000720 00000720 WC1141 0000 038                                         C053,C056,C057,C058
000001c220 00000000 00000720 00000720 00000720 00000720 WC1101 0000 038                                         C053,C056,C057,C058
000001c218 00000000 00000720 00000720 00000720 00000720 WC1140 0000 039                                         C037,C040,C041,C042
000001c210 00000000 00000720 00000720 00000720 00000720 WC1100 0000 039                                         C037,C040,C041,C042
000001c208 00000000 00000720 00000720 00000720 00000720 WC1140 0000 038                                         C037,C040,C041,C042
000001c200 00000000 00000720 00000720 00000720 00000720 WC1100 0000 038                                         C037,C040,C041,C042
000001c2f8 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03f                                         C037,C040,C041,C042
000001c2f0 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03f                                         C037,C040,C041,C042
000001c2e8 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03e                                         C037,C040,C041,C042
000001c2e0 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03e                                         C037,C040,C041,C042
000001c2d8 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03f                                         C053,C056,C057,C058
000001c2d0 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03f                                         C053,C056,C057,C058
000001c2c8 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03e                                         C053,C056,C057,C058
000001c2c0 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03e                                         C053,C056,C057,C058
000001c438 00000000 00000720 00000720 00000720 00000720 WD0140 0000 031                                         D005,D008,D009,D010
000001c430 00000000 00000720 00000720 00000720 00000720 WD0100 0000 031                                         D005,D008,D009,D010
000001c428 00000000 00000720 00000720 00000720 00000720 WD0140 0000 030                                         D005,D008,D009,D010
000001c420 00000000 00000720 00000720 00000720 00000720 WD0100 0000 030                                         D005,D008,D009,D010
000001c418 00000000 00000720 00000720 00000720 00000720 WD0141 0000 031                                         D021,D024,D025,D026
000001c410 00000000 00000720 00000720 00000720 00000720 WD0101 0000 031                                         D021,D024,D025,D026
000001c408 00000000 00000720 00000720 00000720 00000720 WD0141 0000 030                                         D021,D024,D025,D026
000001c400 00000000 00000720 00000720 00000720 00000720 WD0101 0000 030                                         D021,D024,D025,D026
000001c2b8 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03d                                         C037,C040,C041,C042
000001c2b0 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03d                                         C037,C040,C041,C042
000001c2a8 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03c                                         C037,C040,C041,C042
000001c2a0 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03c                                         C037,C040,C041,C042
000001c298 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03d                                         C053,C056,C057,C058
000001c290 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03d                                         C053,C056,C057,C058
000001c288 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03c                                         C053,C056,C057,C058
000001c280 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03c                                         C053,C056,C057,C058
000001c278 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03b                                         C053,C056,C057,C058
000001c270 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03b                                         C053,C056,C057,C058
000001c268 00000000 00000720 00000720 00000720 00000720 WC1141 0000 03a                                         C053,C056,C057,C058
000001c260 00000000 00000720 00000720 00000720 00000720 WC1101 0000 03a                                         C053,C056,C057,C058
000001c258 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03b                                         C037,C040,C041,C042
000001c250 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03b                                         C037,C040,C041,C042
000001c248 00000000 00000720 00000720 00000720 00000720 WC1140 0000 03a                                         C037,C040,C041,C042
000001c240 00000000 00000720 00000720 00000720 00000720 WC1100 0000 03a                                         C037,C040,C041,C042
000001c378 00000000 00000720 00000720 00000720 00000720 WC1140 0000 02b                                         C037,C040,C041,C042
000001c370 00000000 00000720 00000720 00000720 00000720 WC1100 0000 02b                                         C037,C040,C041,C042
000001c368 00000000 00000720 00000720 00000720 00000720 WC1140 0000 02a                                         C037,C040,C041,C042
000001c360 00000000 00000720 00000720 00000720 00000720 WC1100 0000 02a                                         C037,C040,C041,C042
000001c358 00000000 00000720 00000720 00000720 00000720 WC1141 0000 02b                                         C053,C056,C057,C058
000001c350 00000000 00000720 00000720 00000720 00000720 WC1101 0000 02b                                         C053,C056,C057,C058
000001c348 00000000 00000720 00000720 00000720 00000720 WC1141 0000 02a                                         C053,C056,C057,C058
000001c340 00000000 00000720 00000720 00000720 00000720 WC1101 0000 02a                                         C053,C056,C057,C058
000001c738 00000000 00000720 00000720 00000720 00000720 WD0140 0000 029                                         D005,D008,D009,D010
000001c730 00000000 0000073a 0000073a 0000073a 0000073a WD0100 0000 029                          D001,D003,D004,D005,D008,D009,D010
000001c728 00000000 00000763 00000763 00000763 00000763 WD0140 0000 028                          D000,D001,D005,D006,D008,D009,D010
000001c720 00000000 00000770 00000770 00000770 00000770 WD0100 0000 028                               D004,D005,D006,D008,D009,D010
000001c718 00000000 00000763 00000763 00000763 00000763 WD0141 0000 029                          D016,D017,D021,D022,D024,D025,D026
000001c710 00000000 00000768 00000768 00000768 00000768 WD0101 0000 029                               D019,D021,D022,D024,D025,D026
000001c708 00000000 00000764 00000764 00000764 00000764 WD0141 0000 028                               D018,D021,D022,D024,D025,D026
000001c700 00000000 00000775 00000775 00000775 00000775 WD0101 0000 028                     D016,D018,D020,D021,D022,D024,D025,D026
000001c6f8 00000000 00000720 00000720 00000720 00000720 WD0140 0000 03f                                         D005,D008,D009,D010
000001c6f0 00000000 00000720 00000720 00000720 00000720 WD0100 0000 03f                                         D005,D008,D009,D010
000001c6e8 00000000 00000720 00000720 00000720 00000720 WD0140 0000 03e                                         D005,D008,D009,D010
000001c6e0 00000000 00000720 00000720 00000720 00000720 WD0100 0000 03e                                         D005,D008,D009,D010
000001c6d8 00000000 00000720 00000720 00000720 00000720 WD0141 0000 03f                                         D021,D024,D025,D026
000001c6d0 00000000 00000720 00000720 00000720 00000720 WD0101 0000 03f                                         D021,D024,D025,D026
000001c6c8 00000000 00000720 00000720 00000720 00000720 WD0141 0000 03e                                         D021,D024,D025,D026
000001c6c0 00000000 00000720 00000720 00000720 00000720 WD0101 0000 03e                                         D021,D024,D025,D026
000001c778 00000000 00000766 00000766 00000766 00000766 WD0140 0000 02b                          D001,D002,D005,D006,D008,D009,D010
000001c770 00000000 0000076f 0000076f 0000076f 0000076f WD0100 0000 02b                D000,D001,D002,D003,D005,D006,D008,D009,D010
000001c768 00000000 00000720 00000720 00000720 00000720 WD0140 0000 02a                                         D005,D008,D009,D010
000001c760 00000000 00000765 00000765 00000765 00000765 WD0100 0000 02a                          D000,D002,D005,D006,D008,D009,D010
000001c758 00000000 00000773 00000773 00000773 00000773 WD0141 0000 02b                     D016,D017,D020,D021,D022,D024,D025,D026
000001c750 00000000 00000761 00000761 00000761 00000761 WD0101 0000 02b                               D016,D021,D022,D024,D025,D026
000001c748 00000000 00000765 00000765 00000765 00000765 WD0141 0000 02a                          D016,D018,D021,D022,D024,D025,D026
000001c740 00000000 0000076c 0000076c 0000076c 0000076c WD0101 0000 02a                          D018,D019,D021,D022,D024,D025,D026
000001c8f8 00000000 00000720 00000720 00000720 00000720 WD1141 0000 037                                         D053,D056,D057,D058
000001c8f0 00000000 00000720 00000720 00000720 00000720 WD1101 0000 037                                         D053,D056,D057,D058
000001c8e8 00000000 00000720 00000720 00000720 00000720 WD1141 0000 036                                         D053,D056,D057,D058
000001c8e0 00000000 00000720 00000720 00000720 00000720 WD1101 0000 036                                         D053,D056,D057,D058
000001c8d8 00000000 00000720 00000720 00000720 00000720 WD1140 0000 037                                         D037,D040,D041,D042
000001c8d0 00000000 00000720 00000720 00000720 00000720 WD1100 0000 037                                         D037,D040,D041,D042
000001c8c8 00000000 00000720 00000720 00000720 00000720 WD1140 0000 036                                         D037,D040,D041,D042
000001c8c0 00000000 00000720 00000720 00000720 00000720 WD1100 0000 036                                         D037,D040,D041,D042
000001cb78 00000000 00000720 00000720 00000720 00000720 WD1140 0000 02b                                         D037,D040,D041,D042
000001cb70 00000000 00000720 00000720 00000720 00000720 WD1100 0000 02b                                         D037,D040,D041,D042
000001cb68 00000000 00000720 00000720 00000720 00000720 WD1140 0000 02a                                         D037,D040,D041,D042
000001cb60 00000000 00000720 00000720 00000720 00000720 WD1100 0000 02a                                         D037,D040,D041,D042
000001cb58 00000000 00000720 00000720 00000720 00000720 WD1141 0000 02b                                         D053,D056,D057,D058
000001cb50 00000000 00000720 00000720 00000720 00000720 WD1101 0000 02b                                         D053,D056,D057,D058
000001cb48 00000000 00000720 00000720 00000720 00000720 WD1141 0000 02a                                         D053,D056,D057,D058
000001cb40 00000000 00000720 00000720 00000720 00000720 WD1101 0000 02a                                         D053,D056,D057,D058
000001ca38 00000000 00000763 00000763 00000763 00000763 WD1141 0000 039                          D048,D049,D053,D054,D056,D057,D058
000001ca30 00000000 00000775 00000775 00000775 00000775 WD1101 0000 039                     D048,D050,D052,D053,D054,D056,D057,D058
000001ca28 00000000 00000773 00000773 00000773 00000773 WD1141 0000 038                     D048,D049,D052,D053,D054,D056,D057,D058
000001ca20 00000000 00000720 00000720 00000720 00000720 WD1101 0000 038                                         D053,D056,D057,D058
000001ca18 00000000 0000076f 0000076f 0000076f 0000076f WD1140 0000 039                D032,D033,D034,D035,D037,D038,D040,D041,D042
000001ca10 00000000 0000074e 0000074e 0000074e 0000074e WD1100 0000 039                          D033,D034,D035,D038,D040,D041,D042
000001ca08 00000000 00000720 00000720 00000720 00000720 WD1140 0000 038                                         D037,D040,D041,D042
000001ca00 00000000 0000073a 0000073a 0000073a 0000073a WD1100 0000 038                          D033,D035,D036,D037,D040,D041,D042
000001c878 00000000 00000765 00000765 00000765 00000765 WD1140 0000 033                          D032,D034,D037,D038,D040,D041,D042
000001c870 00000000 0000076d 0000076d 0000076d 0000076d WD1100 0000 033                     D032,D034,D035,D037,D038,D040,D041,D042
000001c868 00000000 00000769 00000769 00000769 00000769 WD1140 0000 032                          D032,D035,D037,D038,D040,D041,D042
000001c860 00000000 00000774 00000774 00000774 00000774 WD1100 0000 032                          D034,D036,D037,D038,D040,D041,D042
000001c858 00000000 00000720 00000720 00000720 00000720 WD1141 0000 033                                         D053,D056,D057,D058
000001c850 00000000 00000765 00000765 00000765 00000765 WD1101 0000 033                          D048,D050,D053,D054,D056,D057,D058
000001c848 00000000 00000773 00000773 00000773 00000773 WD1141 0000 032                     D048,D049,D052,D053,D054,D056,D057,D058
000001c840 00000000 00000761 00000761 00000761 00000761 WD1101 0000 032                               D048,D053,D054,D056,D057,D058
000001ca78 00000000 00000773 00000773 00000773 00000773 WD1141 0000 03b                     D048,D049,D052,D053,D054,D056,D057,D058
000001ca70 00000000 00000765 00000765 00000765 00000765 WD1101 0000 03b                          D048,D050,D053,D054,D056,D057,D058
000001ca68 00000000 00000763 00000763 00000763 00000763 WD1141 0000 03a                          D048,D049,D053,D054,D056,D057,D058
000001ca60 00000000 0000076f 0000076f 0000076f 0000076f WD1101 0000 03a                D048,D049,D050,D051,D053,D054,D056,D057,D058
000001ca58 00000000 00000772 00000772 00000772 00000772 WD1140 0000 03b                          D033,D036,D037,D038,D040,D041,D042
000001ca50 00000000 00000770 00000770 00000770 00000770 WD1100 0000 03b                               D036,D037,D038,D040,D041,D042
000001ca48 00000000 00000720 00000720 00000720 00000720 WD1140 0000 03a                                         D037,D040,D041,D042
000001ca40 00000000 00000768 00000768 00000768 00000768 WD1100 0000 03a                               D035,D037,D038,D040,D041,D042
000001cd40 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 022 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd48 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 022 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd50 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 023 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd58 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 023 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd60 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 022 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd68 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 022 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd70 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 023 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd78 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 023 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc40 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 032 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc48 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 032 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc50 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 033 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc58 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 033 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc60 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 032 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc68 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 032 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc70 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 033 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc78 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 033 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce40 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 03a E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce48 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 03a E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce50 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 03b E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce58 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 03b E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce60 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 03a E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce68 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 03a E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce70 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 03b E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce78 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 03b E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001c940 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 022 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c948 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 022 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c950 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 023 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c958 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 023 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c960 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 022 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c968 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 022 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c970 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 023 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c978 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 023 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c300 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 028 C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c308 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 028 C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c310 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 029 C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c318 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 029 C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c320 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 028 C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c328 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 028 C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c330 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 029 C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c338 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 029 C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001ca80 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WD1101 0000 03c                     D050,D051,D055,D059,D060,D061,D062,D063
000001ca88 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 03c D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001ca90 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 03d D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001ca98 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 03d D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001caa0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 03c D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001caa8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 03c D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cab0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 03d D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cab8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 03d D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c780 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 02c D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c788 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0140 0000 02c           D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c790 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0100 0000 02d      D000,D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c798 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0140 0000 02d                D000,D004,D006,D007,D011,D012,D013,D014,D015
000001c7a0 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0101 0000 02c      D016,D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c7a8 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0141 0000 02c                D016,D020,D022,D023,D027,D028,D029,D030,D031
000001c7b0 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0101 0000 02d      D016,D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c7b8 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0141 0000 02d                D016,D020,D022,D023,D027,D028,D029,D030,D031
000001cb00 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 028 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cb08 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 028 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cb10 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 029 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cb18 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 029 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cb20 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 028 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb28 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 028 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb30 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 029 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb38 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 029 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c480 ffffffff ffff0775 ffff0775 ffff0775 0000f88a WD0100 0000 034                     D001,D003,D007,D011,D012,D013,D014,D015
000001c488 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WD0140 0000 034           D000,D001,D003,D004,D007,D011,D012,D013,D014,D015
000001c490 ffffffff ffff0768 ffff0768 ffff0768 0000f897 WD0100 0000 035           D000,D001,D002,D004,D007,D011,D012,D013,D014,D015
000001c498 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WD0140 0000 035                D002,D003,D004,D007,D011,D012,D013,D014,D015
000001c4a0 ffffffff ffff0770 ffff0770 ffff0770 0000f88f WD0101 0000 034           D016,D017,D018,D019,D023,D027,D028,D029,D030,D031
000001c4a8 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WD0141 0000 034                D018,D019,D020,D023,D027,D028,D029,D030,D031
000001c4b0 ffffffff ffff073a ffff073a ffff073a 0000f8c5 WD0101 0000 035                D016,D018,D022,D023,D027,D028,D029,D030,D031
000001c4b8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 035 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c7c0 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0100 0000 02e           D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c7c8 ffffffff ffff0739 ffff0739 ffff0739 0000f8c6 WD0140 0000 02e                D001,D002,D006,D007,D011,D012,D013,D014,D015
000001c7d0 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0100 0000 02f           D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c7d8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 02f D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c7e0 ffffffff ffff076f ffff076f ffff076f 0000f890 WD0101 0000 02e                          D020,D023,D027,D028,D029,D030,D031
000001c7e8 ffffffff ffff0762 ffff0762 ffff0762 0000f89d WD0141 0000 02e           D016,D018,D019,D020,D023,D027,D028,D029,D030,D031
000001c7f0 ffffffff ffff0774 ffff0774 ffff0774 0000f88b WD0101 0000 02f                D016,D017,D019,D023,D027,D028,D029,D030,D031
000001c7f8 ffffffff ffff0761 ffff0761 ffff0761 0000f89e WD0141 0000 02f           D017,D018,D019,D020,D023,D027,D028,D029,D030,D031
000001c440 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 032 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c448 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 032 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c450 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 033 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c458 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 033 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c460 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 032 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c468 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 032 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c470 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 033 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c478 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 033 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c580 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0101 0000 024      D016,D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c588 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0141 0000 024                D016,D020,D022,D023,D027,D028,D029,D030,D031
000001c590 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0101 0000 025           D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c598 ffffffff ffff0739 ffff0739 ffff0739 0000f8c6 WD0141 0000 025                D017,D018,D022,D023,D027,D028,D029,D030,D031
000001c5a0 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0100 0000 024           D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c5a8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 024 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5b0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 025 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5b8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 025 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c640 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 03a D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c648 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 03a D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c650 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 03b D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c658 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 03b D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c660 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 03a D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c668 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 03a D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c670 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 03b D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c678 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 03b D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c380 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 02c C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c388 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 02c C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c390 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 02d C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c398 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 02d C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c3a0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 02c C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3a8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 02c C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3b0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 02d C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3b8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 02d C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c9c0 ffffffff ffff0749 ffff0749 ffff0749 0000f8b6 WD1101 0000 026           D049,D050,D052,D053,D055,D059,D060,D061,D062,D063
000001c9c8 ffffffff ffff074f ffff074f ffff074f 0000f8b0 WD1141 0000 026                     D052,D053,D055,D059,D060,D061,D062,D063
000001c9d0 ffffffff ffff0743 ffff0743 ffff0743 0000f8bc WD1101 0000 027           D050,D051,D052,D053,D055,D059,D060,D061,D062,D063
000001c9d8 ffffffff ffff0744 ffff0744 ffff0744 0000f8bb WD1141 0000 027      D048,D049,D051,D052,D053,D055,D059,D060,D061,D062,D063
000001c9e0 ffffffff ffff0745 ffff0745 ffff0745 0000f8ba WD1100 0000 026           D033,D035,D036,D037,D039,D043,D044,D045,D046,D047
000001c9e8 ffffffff ffff074c ffff074c ffff074c 0000f8b3 WD1140 0000 026           D032,D033,D036,D037,D039,D043,D044,D045,D046,D047
000001c9f0 ffffffff ffff0752 ffff0752 ffff0752 0000f8ad WD1100 0000 027           D032,D034,D035,D037,D039,D043,D044,D045,D046,D047
000001c9f8 ffffffff ffff0754 ffff0754 ffff0754 0000f8ab WD1140 0000 027           D032,D033,D035,D037,D039,D043,D044,D045,D046,D047
000001c600 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 038 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c608 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 038 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c610 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 039 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c618 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 039 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c620 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 038 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c628 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 038 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c630 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 039 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c638 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 039 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001cdc0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 026 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cdc8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 026 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cdd0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 027 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cdd8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 027 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cde0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 026 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cde8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 026 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cdf0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 027 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cdf8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 027 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001c980 ffffffff ffff0772 ffff0772 ffff0772 0000f88d WD1101 0000 024                D048,D050,D051,D055,D059,D060,D061,D062,D063
000001c988 ffffffff ffff076f ffff076f ffff076f 0000f890 WD1141 0000 024                          D052,D055,D059,D060,D061,D062,D063
000001c990 ffffffff ffff0775 ffff0775 ffff0775 0000f88a WD1101 0000 025                     D049,D051,D055,D059,D060,D061,D062,D063
000001c998 ffffffff ffff0774 ffff0774 ffff0774 0000f88b WD1141 0000 025                D048,D049,D051,D055,D059,D060,D061,D062,D063
000001c9a0 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD1100 0000 024                D033,D035,D036,D039,D043,D044,D045,D046,D047
000001c9a8 ffffffff ffff073a ffff073a ffff073a 0000f8c5 WD1140 0000 024                D032,D034,D038,D039,D043,D044,D045,D046,D047
000001c9b0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 025 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c9b8 ffffffff ffff0753 ffff0753 ffff0753 0000f8ac WD1140 0000 025                D034,D035,D037,D039,D043,D044,D045,D046,D047
000001c540 ffffffff ffff076f ffff076f ffff076f 0000f890 WD0100 0000 022                          D004,D007,D011,D012,D013,D014,D015
000001c548 ffffffff ffff0772 ffff0772 ffff0772 0000f88d WD0140 0000 022                D000,D002,D003,D007,D011,D012,D013,D014,D015
000001c550 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 023 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c558 ffffffff ffff0731 ffff0731 ffff0731 0000f8ce WD0140 0000 023           D001,D002,D003,D006,D007,D011,D012,D013,D014,D015
000001c560 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0101 0000 022      D016,D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c568 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0141 0000 022                D016,D020,D022,D023,D027,D028,D029,D030,D031
000001c570 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD0101 0000 023      D016,D017,D018,D019,D022,D023,D027,D028,D029,D030,D031
000001c578 ffffffff ffff072e ffff072e ffff072e 0000f8d1 WD0141 0000 023                D016,D020,D022,D023,D027,D028,D029,D030,D031
000001bfc0 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WC0101 0000 01e                     C018,C019,C023,C027,C028,C029,C030,C031
000001bfc8 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WC0141 0000 01e                C017,C019,C020,C023,C027,C028,C029,C030,C031
000001bfd0 ffffffff ffff076e ffff076e ffff076e 0000f891 WC0101 0000 01f                     C016,C020,C023,C027,C028,C029,C030,C031
000001bfd8 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WC0141 0000 01f           C016,C017,C019,C020,C023,C027,C028,C029,C030,C031
000001bfe0 ffffffff ffff0769 ffff0769 ffff0769 0000f896 WC0100 0000 01e                C001,C002,C004,C007,C011,C012,C013,C014,C015
000001bfe8 ffffffff ffff076e ffff076e ffff076e 0000f891 WC0140 0000 01e                     C000,C004,C007,C011,C012,C013,C014,C015
000001bff0 ffffffff ffff0767 ffff0767 ffff0767 0000f898 WC0100 0000 01f                     C003,C004,C007,C011,C012,C013,C014,C015
000001bff8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC0140 0000 01f C000,C001,C002,C003,C004,C006,C007,C011,C012,C013,C014,C015
000001c3c0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 02e C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c3c8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 02e C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c3d0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1100 0000 02f C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c3d8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1140 0000 02f C032,C033,C034,C035,C036,C038,C039,C043,C044,C045,C046,C047
000001c3e0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 02e C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3e8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 02e C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3f0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1101 0000 02f C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c3f8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 02f C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001c680 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 03c D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c688 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 03c D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c690 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 03d D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c698 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 03d D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c6a0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 03c D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c6a8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 03c D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c6b0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 03d D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c6b8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 03d D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5c0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 026 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c5c8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 026 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c5d0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 027 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c5d8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 027 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c5e0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 026 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5e8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 026 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5f0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0100 0000 027 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c5f8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0140 0000 027 D000,D001,D002,D003,D004,D006,D007,D011,D012,D013,D014,D015
000001c200 ffffffff ffff0775 ffff0775 ffff0775 0000f88a WC1100 0000 038                     C033,C035,C039,C043,C044,C045,C046,C047
000001c208 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WC1140 0000 038           C032,C033,C035,C036,C039,C043,C044,C045,C046,C047
000001c210 ffffffff ffff0768 ffff0768 ffff0768 0000f897 WC1100 0000 039           C032,C033,C034,C036,C039,C043,C044,C045,C046,C047
000001c218 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WC1140 0000 039                C034,C035,C036,C039,C043,C044,C045,C046,C047
000001c220 ffffffff ffff0770 ffff0770 ffff0770 0000f88f WC1101 0000 038           C048,C049,C050,C051,C055,C059,C060,C061,C062,C063
000001c228 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WC1141 0000 038                C050,C051,C052,C055,C059,C060,C061,C062,C063
000001c230 ffffffff ffff073a ffff073a ffff073a 0000f8c5 WC1101 0000 039                C048,C050,C054,C055,C059,C060,C061,C062,C063
000001c238 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 039 C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001cac0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 03e D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cac8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 03e D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cad0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 03f D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cad8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 03f D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cae0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 03e D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cae8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 03e D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001caf0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 03f D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001caf8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 03f D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cd00 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 020 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd08 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 020 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd10 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 021 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd18 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 021 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cd20 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 020 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd28 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 020 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd30 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 021 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd38 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 021 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cbc0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 02e D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cbc8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 02e D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cbd0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 02f D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cbd8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 02f D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cbe0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 02e D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cbe8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 02e D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cbf0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 02f D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cbf8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 02f D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c500 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WD0100 0000 020                     D002,D003,D007,D011,D012,D013,D014,D015
000001c508 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD0140 0000 020                D001,D003,D004,D007,D011,D012,D013,D014,D015
000001c510 ffffffff ffff076c ffff076c ffff076c 0000f893 WD0100 0000 021                D000,D001,D004,D007,D011,D012,D013,D014,D015
000001c518 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD0140 0000 021                D001,D003,D004,D007,D011,D012,D013,D014,D015
000001c520 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WD0101 0000 020                D018,D019,D020,D023,D027,D028,D029,D030,D031
000001c528 ffffffff ffff0774 ffff0774 ffff0774 0000f88b WD0141 0000 020                D016,D017,D019,D023,D027,D028,D029,D030,D031
000001c530 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0101 0000 021 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001c538 ffffffff ffff0766 ffff0766 ffff0766 0000f899 WD0141 0000 021                D016,D019,D020,D023,D027,D028,D029,D030,D031
000001c4c0 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WD0100 0000 036                     D002,D003,D007,D011,D012,D013,D014,D015
000001c4c8 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD0140 0000 036                D001,D003,D004,D007,D011,D012,D013,D014,D015
000001c4d0 ffffffff ffff076e ffff076e ffff076e 0000f891 WD0100 0000 037                     D000,D004,D007,D011,D012,D013,D014,D015
000001c4d8 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WD0140 0000 037           D000,D001,D003,D004,D007,D011,D012,D013,D014,D015
000001c4e0 ffffffff ffff0769 ffff0769 ffff0769 0000f896 WD0101 0000 036                D017,D018,D020,D023,D027,D028,D029,D030,D031
000001c4e8 ffffffff ffff076e ffff076e ffff076e 0000f891 WD0141 0000 036                     D016,D020,D023,D027,D028,D029,D030,D031
000001c4f0 ffffffff ffff0767 ffff0767 ffff0767 0000f898 WD0101 0000 037                     D019,D020,D023,D027,D028,D029,D030,D031
000001c4f8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD0141 0000 037 D016,D017,D018,D019,D020,D022,D023,D027,D028,D029,D030,D031
000001cc00 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 030 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc08 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 030 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc10 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 031 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc18 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 031 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cc20 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 030 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc28 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 030 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc30 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 031 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc38 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 031 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc80 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 034 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc88 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 034 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc90 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 035 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cc98 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 035 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cca0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 034 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cca8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 034 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ccb0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 035 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ccb8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 035 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce00 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 038 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce08 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 038 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce10 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 039 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce18 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 039 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ce20 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 038 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce28 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 038 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce30 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 039 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ce38 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 039 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001c900 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 020 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c908 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 020 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c910 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 021 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c918 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 021 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c920 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 020 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c928 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 020 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c930 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 021 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c938 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 021 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c280 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WC1101 0000 03c           C048,C049,C051,C052,C055,C059,C060,C061,C062,C063
000001c288 ffffffff ffff0769 ffff0769 ffff0769 0000f896 WC1141 0000 03c                C049,C050,C052,C055,C059,C060,C061,C062,C063
000001c290 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WC1101 0000 03d                     C050,C051,C055,C059,C060,C061,C062,C063
000001c298 ffffffff ffff0763 ffff0763 ffff0763 0000f89c WC1141 0000 03d                C050,C051,C052,C055,C059,C060,C061,C062,C063
000001c2a0 ffffffff ffff076f ffff076f ffff076f 0000f890 WC1100 0000 03c                          C036,C039,C043,C044,C045,C046,C047
000001c2a8 ffffffff ffff0776 ffff0776 ffff0776 0000f889 WC1140 0000 03c                     C032,C035,C039,C043,C044,C045,C046,C047
000001c2b0 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WC1100 0000 03d                C033,C035,C036,C039,C043,C044,C045,C046,C047
000001c2b8 ffffffff ffff0772 ffff0772 ffff0772 0000f88d WC1140 0000 03d                C032,C034,C035,C039,C043,C044,C045,C046,C047
000001c240 ffffffff ffff0773 ffff0773 ffff0773 0000f88c WC1100 0000 03a                     C034,C035,C039,C043,C044,C045,C046,C047
000001c248 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WC1140 0000 03a                C033,C035,C036,C039,C043,C044,C045,C046,C047
000001c250 ffffffff ffff076e ffff076e ffff076e 0000f891 WC1100 0000 03b                     C032,C036,C039,C043,C044,C045,C046,C047
000001c258 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WC1140 0000 03b           C032,C033,C035,C036,C039,C043,C044,C045,C046,C047
000001c260 ffffffff ffff0769 ffff0769 ffff0769 0000f896 WC1101 0000 03a                C049,C050,C052,C055,C059,C060,C061,C062,C063
000001c268 ffffffff ffff076e ffff076e ffff076e 0000f891 WC1141 0000 03a                     C048,C052,C055,C059,C060,C061,C062,C063
000001c270 ffffffff ffff0767 ffff0767 ffff0767 0000f898 WC1101 0000 03b                     C051,C052,C055,C059,C060,C061,C062,C063
000001c278 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WC1141 0000 03b C048,C049,C050,C051,C052,C054,C055,C059,C060,C061,C062,C063
000001cd80 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 024 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd88 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 024 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd90 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 025 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cd98 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 025 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cda0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 024 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cda8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 024 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cdb0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 025 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cdb8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 025 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ccc0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 036 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ccc8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 036 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ccd0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0100 0000 037 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001ccd8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0140 0000 037 E000,E001,E002,E003,E004,E006,E007,E011,E012,E013,E014,E015
000001cce0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 036 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cce8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 036 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ccf0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0101 0000 037 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001ccf8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WE0141 0000 037 E016,E017,E018,E019,E020,E022,E023,E027,E028,E029,E030,E031
000001cb80 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 02c D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb88 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 02c D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb90 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 02d D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cb98 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 02d D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001cba0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 02c D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cba8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 02c D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cbb0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 02d D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001cbb8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 02d D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c800 ffffffff ffff0769 ffff0769 ffff0769 0000f896 WD1101 0000 030                D049,D050,D052,D055,D059,D060,D061,D062,D063
000001c808 ffffffff ffff076e ffff076e ffff076e 0000f891 WD1141 0000 030                     D048,D052,D055,D059,D060,D061,D062,D063
000001c810 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD1101 0000 031                D049,D051,D052,D055,D059,D060,D061,D062,D063
000001c818 ffffffff ffff0764 ffff0764 ffff0764 0000f89b WD1141 0000 031           D048,D049,D051,D052,D055,D059,D060,D061,D062,D063
000001c820 ffffffff ffff072c ffff072c ffff072c 0000f8d3 WD1100 0000 030           D032,D033,D036,D038,D039,D043,D044,D045,D046,D047
000001c828 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1140 0000 030 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c830 ffffffff ffff076c ffff076c ffff076c 0000f893 WD1100 0000 031                D032,D033,D036,D039,D043,D044,D045,D046,D047
000001c838 ffffffff ffff0765 ffff0765 ffff0765 0000f89a WD1140 0000 031                D033,D035,D036,D039,D043,D044,D045,D046,D047
000001c880 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1100 0000 034 D032,D033,D034,D035,D036,D038,D039,D043,D044,D045,D046,D047
000001c888 ffffffff ffff0734 ffff0734 ffff0734 0000f8cb WD1140 0000 034           D032,D033,D035,D038,D039,D043,D044,D045,D046,D047
000001c890 ffffffff ffff0733 ffff0733 ffff0733 0000f8cc WD1100 0000 035                D034,D035,D038,D039,D043,D044,D045,D046,D047
000001c898 ffffffff ffff0732 ffff0732 ffff0732 0000f8cd WD1140 0000 035           D032,D034,D035,D038,D039,D043,D044,D045,D046,D047
000001c8a0 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD1101 0000 034      D048,D049,D050,D051,D054,D055,D059,D060,D061,D062,D063
000001c8a8 ffffffff ffff0730 ffff0730 ffff0730 0000f8cf WD1141 0000 034      D048,D049,D050,D051,D054,D055,D059,D060,D061,D062,D063
000001c8b0 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1101 0000 035 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
000001c8b8 ffffffff ffff0720 ffff0720 ffff0720 0000f8df WD1141 0000 035 D048,D049,D050,D051,D052,D054,D055,D059,D060,D061,D062,D063
If you are getting failure for first MB of FB then try option -no_scan_out
Error Code = 00000001
Thanks/Спасибо
 Заголовок сообщения: Re: Inno3D 1080Ti memory problems
СообщениеДобавлено: 21 ноя 2022, 22:55
Вы правы - может быть несколько причин для такого поведения. Начните с малого и замените память.
СообщениеДобавлено: 22 ноя 2022, 07:17
Начать с малого - это визуальный осмотр доски и кристалла, а также замер сопротивлений по основным линиям питания. GDDR5X дохнет редко, да и такое количество ошибок вовсе не повод менять память. Их можно получить и на вполне исправной карте.
СообщениеДобавлено: 30 апр 2023, 17:35
YunicheK
Подскажи, можно ли выпаять или отключить канал на неисправный чип памяти, который выдает ошибку записи в FBIOD0 или есть какие то еще варианты кроме перечиповки?
Последний раз редактировалось igorsh24 30 апр 2023, 21:59, всего редактировалось 1 раз.
СообщениеДобавлено: 30 апр 2023, 20:47
igorsh24 писал(а):
Подскажи, можно ли выпаять неисправный чип памяти, будет ли дальше работать карта на 10gb ?
Разумеется карта работать не будет на 10GB.
СообщениеДобавлено: 30 апр 2023, 22:01
есть ли какие то еще варианты кроме перечиповки?
СообщениеДобавлено: 01 май 2023, 14:40
Нужно понимать что MATS не указывает на неисправный чип памяти, он показывает проблемный канал. А причина может быть как в умершем канале в самом ГПУ, так и в чипе памяти, так и в самом тестолите (перебитые дорожки, серые пятаки как под памятью так и под ГПУ или и вовсе их отрыв). Поэтому да, вариантов много. Но про отключение канала забудьте. Это невозможно и нецелесообразно.
СообщениеДобавлено: 03 фев 2024, 02:16
A rather strange thing happened - I almost forgot about the card, took it out of the drawer and put it to the machine - giving code 43 and GPU-Z would not even detect the BIOS version. Then I dismantled it, inspected again, put together - and code 43 was gone! I did absolutely nothing to the card. I was able to run 3DMark, but then it crashed after like 10 minutes of benchmarking, so I restart the PC and tried to run it again but got BSOD after like a minute of 3DMark. But strange, code 43 is no longer present, except that the card is bugging. There were no visual artifacts while the card was running fine. I think I might try to re-heat the core and memory and see if it actually fixes the card. Anyone experienced such a behavior?
СообщениеДобавлено: 04 фев 2024, 20:38
Я бы для начала перекатал бы всю память. Очень часто серые пятаки на памяти.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. GTX1070 Founders - no Memory Voltage, with external Memory-Power all fine
Assassin
23 авг 2020, 23:26
Assassin Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. GTX 1070 mobile MSI, memory all error memory
PT-AH
23 сен 2022, 05:42
black7705 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Inno3D 1080Ti режет частоты
Grizli_saratov
19 сен 2021, 12:09
hangover84 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aorus 1080TI + Zotac 1080TI please help
hashwood
14
3969
27 апр 2022, 10:09
acidwise Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Aspire 5740 (09285-1M) Video problems
miros84
03 авг 2016, 00:12
Сейчас этот форум просматривают: Aleks.mp3, galkinvv, ret_y, vovanch-k и гости: 35
