Заголовок сообщения: TVS Pressfit Diode BYZ50A* or BYZ35A* for Metabo impact wrench SSW LTX 600
Добавлено: 29 ноя 2022, 19:31
Зарегистрирован: 11 ноя 2022, 06:45 Наличности на руках: 0.00 Сообщения: 2 Откуда: Home
Hello,
like I described above, I'm searching for a pressfit diode. Those are used on the switch of a metabo ssw ltx 600 aswell and I need to replace it. Manufacturer is Diotech. They call it Silicon Protectifiers with TVS characteristics High-temperature diodes.
Cannot attach datasheet, but it can be found easily on google.
Thanks in advance
MoneyBot
MoneyBot
u666sa
Заголовок сообщения: Re: TVS Pressfit Diode BYZ50A* or BYZ35A* for Metabo impact wrench SSW LTX 600
Look on aliexpress. I found the 2nd one right away. You can also N rig a regular diode with same characteristics, perhaps. You search for BYZ50A or BYZ35A without *star* and you will find it.
salomalo
Добавлено: 02 дек 2022, 22:48
Thank you for the help. But I can't find them on aliexpress. Can you kindly provide me a link?
u666sa
Сейчас этот форум просматривают: falkonON и гости: 20
