Текущее время: 19 ноя 2026, 21:09
 Заголовок сообщения: RTX 2070 MODS K4Z80325BC-HC14 for K4Z80325BC-HC16?
СообщениеДобавлено: 22 дек 2022, 21:02
HELLO
RTX mod
Does anyone know if I can change the memories in an RTX 2070 the memories K4Z80325BC-HC14 for K4Z80325BC-HC16.
would it have a good performance increase, or will it cause problems?
has anyone tried it?
 Заголовок сообщения: Re: RTX 2070 MODS K4Z80325BC-HC14 for K4Z80325BC-HC16?
СообщениеДобавлено: 22 дек 2022, 21:30
there won't be any problems
overclock up to max 15.500
СообщениеДобавлено: 23 дек 2022, 03:53
It would work.
Hc16 got the higher speed and same timings.
СообщениеДобавлено: 23 дек 2022, 11:19
thank you guys.
I will try it soon. then I left the results here.
that of 15500mhz it will automatically set that speed or do i have to do mod bios to adjust speed?
СообщениеДобавлено: 23 дек 2022, 23:45
Hc14 got the 1750mhz memory speed
Hc16 is sertified for 2000mhz
There is no need in any actions, the vbios speed is also 1750 got this card.
СообщениеДобавлено: 27 дек 2022, 12:45
Yeah, both HC14 and HC16 are compatible between each other, they share the same die revision, you can also solder HC18 IC if you can found some at a resonnable price, even HC12 could works but only a few card are running GDDR6 at only 12Gbps and 1.35v. Furthermore by "upgrading" the memory from HC14 to HC16/18 you will be able to overclock the memory higher. Finally there is no issue mixing HC12/14/16/18 IC on the same card as long as it's stock memory bandwidth is equal to the lowest IC which is 12Gbps (in case of a mix with at least one HC12).
В этой теме нет новых непрочитанных сообщений. куплю одну банку D9WCW и одну K4Z80325BC-HC14 (Москва)
в форуме Куплю | Buy
elite128
10 мар 2021, 21:36
elite128 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Продам Samsung K4Z80325BC-HC14
MisterAlex
19 сен 2022, 14:23
MisterAlex Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2070, Kакие тесты mods/mats запускать?
darker123
24 янв 2022, 23:43
В этой теме нет новых непрочитанных сообщений. Gigabyte RTX 2070 mods fail
Tinynja
09 фев 2022, 22:46
Tinynja Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. MSI RTX 2070 gaming Z 8Gb ошибка MODS
sergun
15
6674
18 янв 2025, 14:11
feedme Перейти к последнему сообщению
Сейчас этот форум просматривают: leglon, odisseyii и гости: 67
