Текущее время: 21 ноя 2026, 04:53
 Заголовок сообщения: Asus FX505DD (FX505DD MB REV:2) No image trought edp connection
СообщениеДобавлено: 06 фев 2023, 22:46
hi everyone
got this motherboard with ripped edp connector and traces rebuilded them and soldered a new edp connector but no image
laptop seems like turn on because bloq mayus led turn on when key is pressed
measured all pins and nothing looks wrong
when measured while laptop was turned on i´ve realized that edp_hpd, LCD_BKLTEN_PCH and LCD_BL_PWM_PCH are geting low voltage values instead of 1v, 3 and 2.5
for a have been looking on schematics, those signals come from chipset so its chipset damaged?
i have tested flex, screen on other laptop and both work so where should i start to look at?
i havent tried to load windows because theres no image trought hdmi on bios, should reprogram bios?
someone have measurements of the edp connector from a similar motherboard? so would me make sure that rebuild of traces was performed well
thanks in advance
ill attach an image of the motherboard
 Заголовок сообщения: Re: Asus FX505DD (FX505DD MB REV:2) No image trought edp connection
СообщениеДобавлено: 07 фев 2023, 01:03
if EDP_HPD (2.5-3.5v) appears, then the board saw the matrix
СообщениеДобавлено: 07 фев 2023, 01:45
Serguz05
hi tanks for your response
thats the problem, why the board isnt detecting the matrix?
where could i start to look on the board?
i've already tested connection betwen the edp connector and the display and all pins have conection
from where comes the trigger for edp_hpd?
edp_hpd comes from display?
grettings
СообщениеДобавлено: 07 фев 2023, 12:00
edp hpd is produced by the matrix itself.
what is the resistance on the signals EDP_AU..., EDP_TX... on the capacitors from the processor.
Вложение:
СообщениеДобавлено: 09 фев 2023, 05:15
Serguz05
ok ill check and post results
tanks
---------- Добавлено спустя 19 минут 30 секунд: ----------
Serguz05
so i measured
edp aux have 425 in diode mode from cpu to capacitor in both edp aux n and p
all edp tx have 270 value in diode mode
theres no broken link betwen capacitor and connector
СообщениеДобавлено: 19 фев 2023, 06:29
so i was able to repair the laptop
the problem was a short betwen edp_hp and LCD_BKLTEN_PCH
now im facing 3 more problems that i will explain in a new post
thank you all
greetings
В этой теме нет новых непрочитанных сообщений. Asus fx505dd (Asus fx505dd) Залит. Номинал резистора.
duddits
14 апр 2022, 11:14
duddits Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. tv plasma sony KDL-46ex725 image with black stripe at the top of the image
eletmoraes
06 сен 2017, 16:25
eletmoraes Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. tv LG 42PQ30R has image defect as attached image
в форуме PDP
eletmoraes
21 ноя 2019, 01:43
В этой теме нет новых непрочитанных сообщений. Asus fx505dd-bq121 (Fx505dd rev.2) Не поднимаются дежурки
ReedZed
09 янв 2023, 09:27
ReedZed Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS FX505DD (FX505DD Rev. 2.0) Опознать элемент
guljaysv
16 фев 2023, 18:42
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 184
