Текущее время: 01 июн 2024, 16:09
P.zonouz
Заголовок сообщения: Dell N5010 DG15 NOT START Добавлено: 01 июл 2013, 12:17 |
Зарегистрирован: 01 июн 2013, 20:03 Наличности на руках: 18.07
I study this topic: viewtopic.php?p=59795#p59795But I find there is somethings different. I have N5010 DG15 with this voltage: AC_IN_KBC#=.17V LID_CLOSE#=3.3V PCH_RSMRST=3.3 PM_SLP_S3#=0V EC & BIOS firmware sews and OK. But not start. so I test voltage on working exact M.B and I see this: AC_IN_KBC#=.17V LID_CLOSE#=3.3V PCH_RSMRST=3.3 PM_SLP_S3#=0V but working fine. I want to know this voltage existence to laptop start is necessary? so why second one start and work fine without AC_IN_KBC#,PM_SLP_S3#?
_________________ Don't give up without the fight.
RsM
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 01 июл 2013, 22:56 |
Модератор |
Сообщения: 8282 Откуда: Сыктывкар
P.zonouz писал(а): U think it mean we have corrupted HUB(PCH)? If PM_RSMRST# is 3.3V, BIOS Ok and previus conditions ok then it possible.
P.zonouz
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 06 июл 2013, 20:00 |
RsM писал(а): Try to program bios (with clear ME), because you had changed PCH. Maybe it didn't solder? I sewed BIOS, but what is ME bios?
P.zonouz
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 06 июл 2013, 20:28 |
RsM писал(а): ME - Managment Engine - is a Intel part for ME-engine in PCH. ME-region is a part of flash IC. Other parts are: BIOS-region (bios exactly), GB-rerion, OEM-region. There is a lot of information about ME. Wonderful, U have any reference to digging more about this? ( ME-region and .......) and How can I made BIOS, ME_region?
P.zonouz
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 07 июл 2013, 10:27 |
RsM писал(а): I confused, there is some exact techniques to generate ME-Clean Bios files? I mean that Where I can prepare ME firmware and How to send it into the bios files?
P.zonouz
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 07 июл 2013, 14:46 |
Doc писал(а): Lab DC power supply to short circuit: 1V 2A (find hot elements) or try to find in scheme (+1.05V_VTT) by "brute force" (sorting one-by-one) http://kythuatphancung.com/uploads/down ... INTEL-.pdfI do this before, without CPU , V=1V , current =0.28A there is no hot element, with CPU, V=1 current= 2.13A there is no hot element again! I checked according to schematic, some route goes to CPU( I swapped CPU), some goes to Clock ( took it and test) and some goes to PCH ( changed IT before), mysterious! ---------- Добавлено спустя 1 час 3 минуты 20 секунд: ---------- does any one has Clean ME-region BIOS for this laptop? Nobody answered my question about creating ME-region Bios!
P.zonouz
Заголовок сообщения: Re: Dell N5010 DG15 NOT START Добавлено: 08 июл 2013, 15:32 |
RsM писал(а): Can You be kind enough and Upload ME-Region Bios?
