Текущее время: 04 июн 2024, 14:12
 Заголовок сообщения: G62 (HP) graphic overheat
СообщениеДобавлено: 31 дек 2014, 22:48
I have this laptop with graphic card problem. The laptop starts normally but after 10 min the fan kicks in very fast and the laptop shuts down. I noticed with HWmonitor that the graphic chipset temp starts getting very high at 10 min up to 105 C. Tried different drivers but the problem the same. Is it cold soldering of BGA, can a reheat fix the problem. Any one with same problem or information for further troubleshooting.
 Заголовок сообщения: Re: G62 (HP) graphic overheat
СообщениеДобавлено: 31 дек 2014, 23:09
Try another heatpipe.
В личке все ответы платные.
СообщениеДобавлено: 01 янв 2015, 01:21
-clean dust iinside the fan and change thermal pad/paste,
-if no luck, reheat may fix the problem,
-and if no luck too, reball/replacing the GPU is the solution.
لا إله إلا الله محمد رسول الله
СообщениеДобавлено: 01 янв 2015, 02:04
actually i cleaned the fan house and reapplied new thermal paste. What is the best way of reheating, reflow or backing inside oven to be recommended?
I have no rework station so reflow with hot air gun or oven reheat are my chances to approach.
 Заголовок сообщения: Re: G62 (HP) graphic overheat  [РЕШЕНО]
СообщениеДобавлено: 03 янв 2015, 18:01
it's more safety to reflow it using hot air gun,
i not recommended backing inside oven, you may destroy it,
but you need to read this guide if you want to backing it in an oven.
СообщениеДобавлено: 04 янв 2015, 01:42
At first, test with another heatpipe..
СообщениеДобавлено: 04 янв 2015, 16:45
Reheated using a hot air gun gradualy under 10 min ( top temp 240 C in 30 seconds ), prior to that heated the whole pcb to 120 C on hot plate.
The board working fine now, no overheating problems using the same pipe. Shall see how long does this thing hold. Thanks for help.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. G62-b13SL (PM_I_HPC_S MV_MB_V3) CPU overheat after disabling discrete GPU
giofrida
03 авг 2016, 12:50
giofrida Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Freelance Graphic Designer looking for work
в форуме Поиск работы и сотрудников | Job search and offers
iddark
07 авг 2019, 19:50
iddark Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Graphic subboard, Nvidia R1.2 New
20 авг 2014, 13:30
D@nilYcH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell XPS M1530 (DH3 MB 07212-3 48.4W101.031) Failed NVIDIA graphic chip
в форуме Dell
bridx
18 ноя 2015, 12:01
kupersasha Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. asus K53sd (K53SD rev 6.0) don`t see graphic card
notemaster
05 мар 2016, 09:46
andrey__1986 Перейти к последнему сообщению
Сейчас этот форум просматривают: daneeya, DmitriyDDD, paveell, Skaypp и гости: 32
