Зарегистрирован: 01 ноя 2014, 20:01 Наличности на руках: 36.00 Сообщения: 34 Откуда: sweden
I have this laptop with graphic card problem. The laptop starts normally but after 10 min the fan kicks in very fast and the laptop shuts down. I noticed with HWmonitor that the graphic chipset temp starts getting very high at 10 min up to 105 C. Tried different drivers but the problem the same. Is it cold soldering of BGA, can a reheat fix the problem. Any one with same problem or information for further troubleshooting.
Зарегистрирован: 10 апр 2012, 22:42 Наличности на руках: 86.09 Сообщения: 285 Откуда: Indonesia
-clean dust iinside the fan and change thermal pad/paste, -if no luck, reheat may fix the problem, -and if no luck too, reball/replacing the GPU is the solution.
montarbo писал(а):
reflow or backing inside oven to be recommended?
it's more safety to reflow it using hot air gun, i not recommended backing inside oven, you may destroy it, but you need to read this guide if you want to backing it in an oven.
