Текущее время: 03 май 2024, 09:38
 Заголовок сообщения: Asus N56V (LG LP156WF1 ) Help with EDID program
СообщениеДобавлено: 16 фев 2017, 19:12
Hey guys,
I buy a EDID - eeprom cable programmer, and i need to program a LCD LG LP156WF1. my programmer is a EZP2010, and when i put the flat cable in LCD the programmer don't recognize the bios in LCD it say's "Detect chip error".
I have the .bin file and can't read the chip in LCD. i need to have another programmer other than EZP2010?
Cump's
 Заголовок сообщения: Re: Asus N56V (LG LP156WF1 ) Help with EDID program
СообщениеДобавлено: 16 фев 2017, 22:21
in program you must choose:
Type - 24eeprom
Many - atmel(or other)
chip -AT24C02
and read/prog
СообщениеДобавлено: 17 фев 2017, 14:43
Read chip error !
i try many LCD's and no one work!
Can be a bad flat programmer ?? Do the cables connections look good?
This u1 it is the bios?
thanks for your reply
СообщениеДобавлено: 21 фев 2017, 21:48
any idea ? anyone?
СообщениеДобавлено: 21 фев 2017, 23:13
maybe.
Сheck communication, usually for 15.6 lcd:
4pin lcd - V EEDID = 3V
6pin lcd - Clk EEDID
7pin lcd - DATA EEDID
GND conect to eny from 10,13,16...
---------- Добавлено спустя 6 минут 23 секунды: ----------
Also check the cable connection to the programmer
---------- Добавлено спустя 9 минут 53 секунды: ----------
on programmer:
4pin - GND
5pin -DATA
6pin - CLK
8pin - VCC
СообщениеДобавлено: 22 фев 2017, 18:32
Євген, i can read the bios now! But can't erase the original file!!
I try to write over the original file, but i think don't work.. Because the LCD shows a very colors like a rainbow..
it is possible to erase the bios??
Євген, thanks one more time for reply
СообщениеДобавлено: 22 фев 2017, 20:48
I think the problem is the write-protect.
7pin eeprom must be connected to GND
СообщениеДобавлено: 22 фев 2017, 21:03
may be AT24C02 read only (ROM)
may be need replace eeprom
to another chip
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus n56v (n56v rev.2.3) включается на 5-10 сек и гаснет
yak30sn
13
3042
06 апр 2020, 17:39
yak30sn Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. n56v (n56v) замена видеочипа
figvam
27 май 2021, 17:07
kyssa Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. help for asus x552e (help for asus x552e) help
serwanjaf7
05 авг 2016, 18:08
serwanjaf7 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 14:43
PT-AH Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Cannot program winbond w25q64bv with EZP2010
abuholm
4392
01 ноя 2014, 23:39
abuholm Перейти к последнему сообщению
Сейчас этот форум просматривают: alexchech88, Google [Bot], Uicholi и гости: 55
