Текущее время: 21 май 2024, 17:17
 Страница 1 из 1 [ Сообщений: 19 ]
 Заголовок сообщения: Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
СообщениеДобавлено: 22 янв 2021, 19:36
i attach only battery to the laptop and it show orange led,when it loads windows right below corner it sais battery is charging , i plug the charger and its charging normaly, i remove the charger and keeps say battery is charging, with charger plugged in when it charge full the led becomes green and after i remove the charger the green led of full charge is still on. any ideas?
 Заголовок сообщения: Re: Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
СообщениеДобавлено: 22 янв 2021, 20:47
Bios flashed?
СообщениеДобавлено: 22 янв 2021, 21:27
yes, i tried 1 different and a clear me version.
СообщениеДобавлено: 22 янв 2021, 21:41
Charger replaced?
СообщениеДобавлено: 23 янв 2021, 00:38
ohh you mean charger ic? yes allaready replaced it.
СообщениеДобавлено: 23 янв 2021, 12:58
yes! ACDET (pin 5 PU8800) with AC adapter and without?
СообщениеДобавлено: 23 янв 2021, 17:55
Thanks for your answer! ill check as soon as i get to home :)
СообщениеДобавлено: 24 янв 2021, 01:28
2.49 with ac adapter plugged in, and 0v without ac adapter, i made a lot of chip replacements and still the same :(
Without PR8846 i dont have red light and charging icon but it doesnt charge when i plug in the adapter(i just noticed).
СообщениеДобавлено: 24 янв 2021, 17:22
PR8846 return. EXTPWR (pin 13 PU8800), ACOK# (pin 5 PQ8809), AC_IN_OC# (pin 6 PQ8809) with AC adapter and without?
СообщениеДобавлено: 25 янв 2021, 00:46
EXTPWR (pin 13 PU8800) without adapter 0v , with adapter 001v,
ACOK# (pin 5 PQ8809) without adapter 0v , with adapter it rise instantly to 5v and the next second goes to 0v,
AC_IN_OC# (pin 6 PQ8809) without adapter 0v, with adapter rise instantly to 3.20v and the next second goes to 0v.
СообщениеДобавлено: 25 янв 2021, 15:39
- in this is problem. On the DATASHEET: EXTPWR - Valid adapter active-low detect logic open-drain output. Pulled low when input voltage is above ACDET programmed threshold, OR input current is greater than 1.25 A with 10-mW sense resistor. Connect a 10-kW pullup resistor from EXTPWR pin to pullup supply rail.
СообщениеДобавлено: 25 янв 2021, 15:57
what you mean pullup supply rail? thank you very much my friend.
СообщениеДобавлено: 25 янв 2021, 17:26
See this: bq24740
СообщениеДобавлено: 26 янв 2021, 02:30
ohh i see. so i have a 0ohm resistance from pin 13 to #ACOK , where exactly is the problem? that extpwr should be 0v only with adapter plugged in? and with battery not?
СообщениеДобавлено: 26 янв 2021, 13:00
so i connect from vref pin 10 -> 10kohm resistance to pin 13 extpwr ?
СообщениеДобавлено: 26 янв 2021, 13:28
kosmo555 Chek/replace PQ8809, PR8846.
СообщениеДобавлено: 26 янв 2021, 14:13
pq8809 allready replaced, pr8846 100kohm replaced too, i will put another one pq8809 again to see.
СообщениеДобавлено: 26 янв 2021, 21:01
Hello, i replaced pq8809 and still the same.
Posted after 20 minutes 15 seconds:
pr8846 has 3.20v
СообщениеДобавлено: 28 янв 2021, 15:39
i dont think that this will be fixed, anyway thank you for your time my friend :)
В этой теме нет новых непрочитанных сообщений. Macbook Pro A1278 i5 MB 820-2936 B (решены) connecting only the battery without charging LED
в форуме Apple
maxx7
04 ноя 2016, 14:13
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Satellite L350 PSLD0E (6050A2170201-MB-A03) run only without charger
в форуме Toshiba
habibou11
31 дек 2015, 14:48
DreamCatcher Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Probook 4540s (Rocky-Itel) Plugged in not charging
P.zonouz
02 фев 2015, 20:52
popesko Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell G3 3779 (LA-F611P) Self-Charging when charger is disconnected
в форуме Dell
abuholm
02 окт 2022, 06:46
abuholm Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. dell P41G002 (DAJW8CM8E1 REV: E) no power , led battery on , led power off
в форуме Dell
eletmoraes
24 фев 2020, 23:01
eletmoraes Перейти к последнему сообщению
Сейчас этот форум просматривают: Atlantt, DimaMHZ, Google [Bot], Skaypp, sseryozh, Tokser063 и гости: 39
