Заголовок сообщения: Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
Добавлено: 22 янв 2021, 19:36
Зарегистрирован: 24 мар 2015, 20:47 Наличности на руках: 142.10 Сообщения: 24 Откуда: Greece
i attach only battery to the laptop and it show orange led,when it loads windows right below corner it sais battery is charging , i plug the charger and its charging normaly, i remove the charger and keeps say battery is charging, with charger plugged in when it charge full the led becomes green and after i remove the charger the green led of full charge is still on. any ideas?
IOD
Заголовок сообщения: Re: Asus (K53SD rev 5.1) battery is charging icon and orange led" without charger plugged in.
yes! ACDET (pin 5 PU8800) with AC adapter and without? 2.49 with ac adapter plugged in, and 0v without ac adapter, i made a lot of chip replacements and still the same :( Without PR8846 i dont have red light and charging icon but it doesnt charge when i plug in the adapter(i just noticed).
IOD
PR8846 return. EXTPWR (pin 13 PU8800), ACOK# (pin 5 PQ8809), AC_IN_OC# (pin 6 PQ8809) with AC adapter and without?
kosmo555
Добавлено: 25 янв 2021, 00:46
EXTPWR (pin 13 PU8800) without adapter 0v , with adapter 001v, ACOK# (pin 5 PQ8809) without adapter 0v , with adapter it rise instantly to 5v and the next second goes to 0v, AC_IN_OC# (pin 6 PQ8809) without adapter 0v, with adapter rise instantly to 3.20v and the next second goes to 0v.
IOD
- in this is problem. On the DATASHEET: EXTPWR - Valid adapter active-low detect logic open-drain output. Pulled low when input voltage is above ACDET programmed threshold, OR input current is greater than 1.25 A with 10-mW sense resistor. Connect a 10-kW pullup resistor from EXTPWR pin to pullup supply rail.
kosmo555
Добавлено: 25 янв 2021, 15:57
what you mean pullup supply rail? thank you very much my friend.
IOD
Добавлено: 26 янв 2021, 02:30
ohh i see. so i have a 0ohm resistance from pin 13 to #ACOK , where exactly is the problem? that extpwr should be 0v only with adapter plugged in? and with battery not?
kosmo555
Добавлено: 26 янв 2021, 13:00
so i connect from vref pin 10 -> 10kohm resistance to pin 13 extpwr ?
IOD
Сейчас этот форум просматривают: ussur_xxx и гости: 32
