DISABEL RAM ON BOARD ASUS
Сборник мануалов по отключению страпами распаянной памяти на платах асус:
Disable onboard Ram Asus X550LD Rev 2.0\
Disable Onboard RAM Asus X555LD Rev 2.0\
Disable RAM onboard Asus K50IJ X5DIJ r2.1 r2.0 r2.2 r2.3 r2.4 r2.6\
Disable RAM onboard Asus K451L S451\
Disable RAM onboard Asus K550J X550JD\
Disable RAM onboard Asus N551JK\
Disable RAM onboard Asus Q302L TP300LA r2.0\
Disable RAM onboard Asus S301LA r2.0 r2.2\
Disable RAM onboard Asus s400ca rev 2.1\
Disable RAM onboard Asus TP500LN r 2.0\
Disable RAM onboard Asus U38N U38DT r2.0 r2.1\
Disable RAM onboard Asus UX32V UX32VD r2.1 r2.2 r2.4\
Disable RAM onboard Asus UX51VZ r2.0\
Disable RAM onboard Asus VivoBook S551LA S551LB r1.1 r2.1 r2.2\
Disable RAM onboard Asus X55VD\
Disable RAM onboard Asus X75VC - MB X75VB rev 2.0\
Disable RAM onboard Asus X75VD X75VD rev 2.0\
Disable RAM onboard Asus x450cc r2.0 r2.2 r2.3\
Disable Ram Onboard Asus X450LD REV 2.1\
Disable RAM onboard Asus X450VC r2.0\
Disable ram onboard Asus X451CA Rev 2.1\
Disable RAM ONBOARD Asus X452C X450VP r2.0 r2.1\
Disable RAM onboard Asus X455LJ\
Disable Ram onboard Asus X550CC Rev 2.0\
Disable RAM onboard Asus X550EP r1.1 r2.0\
Disable RAM onboard Asus X550L X550LC rev 2.0\
Disable RAM onboard Asus X550MD r2.0\
Disable RAM onboard Asus X551CA r2.1 r2.2\
Disable RAM onboard Asus X552W X550WE REV 2.0\
Disable RAM onboard Asus X555LP\
Disable RAM onboard Asus X751MD r1.1 r2.0\
Disable_RAM_onboard_Asus_X45vd_r2.0\
Disable_RAM_onboard_Asus_X54C_K54C_r2.1\
Disable_RAM_onboard_Asus_X451CA_Rev2.1\
! | Ciber SLasH писал(а): |
В архиве оставил только картинки, все BoardView удалил. |
