Текущее время: 17 май 2024, 05:32
jokercam472
Заголовок сообщения: Need help for first repair on RX 580 Добавлено: 04 июл 2021, 20:16 |
Сообщения: 5 Откуда: France, Paris
Hello,
Thanks for receiving me here ;) just discovered this forum 24h ago, hope you will be able to help me
Card : MSI Armor RX 580 - 8GB - V341 - v1.3 Symptom : no display, fan are spinning, blue screen of death under windows (message is "forever loop in thread" or something like that) under linux, message "Gfx test failed"
History is unknown, board is clean.
I can access and flash the bios with amdvbflash
REG1 is fine with 5.17 Volts output
U2 voltages are 0.98V PIN8 , 12V pin 5 U701 voltage is 1.58V PIN 8
VGPU (sorry don't know the exact term) is 0.95V each GDDR Memory chip does have 1.58V under it.
U900 (PGOOD) output mesuared on R900 is 2.15V => I think it is normal ?
What can I check now ?
Thanks for reading
jokercam472
Заголовок сообщения: Re: Need help for first repair on RX 580 Добавлено: 04 июл 2021, 23:09 |
aleksros писал(а): measure resistances on l900, l701, l500 and on pins 3 and 6 u300. you mean inductors ? do you want resistance when power is off, to check shorted inductors, or when power is on ? also I need help to locate U300 I couldn't find it :/ I was just abble to measure 1.8V on R65 but couldn't find u300. thanks
aleksros
Заголовок сообщения: Re: Need help for first repair on RX 580 Добавлено: 04 июл 2021, 23:24 |
Зарегистрирован: 26 ноя 2011, 01:09 Наличности на руках: 2,600.26
Сообщения: 4473 Откуда: Киев
jokercam472 писал(а): you mean inductors ? do you want resistance when power is off, to check shorted inductors, or when power is on ? not. on the switched off card, measure the resistance to ground. one wire of the multimeter to "ground", and the other to the measuring point that I indicated. readings in ohms. values - here. About U300 in privat message.
jokercam472
Заголовок сообщения: Re: Need help for first repair on RX 580 Добавлено: 05 июл 2021, 00:10 |
aleksros писал(а):
measure resistances on l900, l701, l500 and on pins 3 and 6 u300. Ok : L900 : 21 Ohms L701 : 31 ohms L500 : 31 ohms U300 (really thanks for your PM it was really obvious but for me I was sure it was BIOS :) 2090 ohms on pin 3 1030 ohms on pin 6
jokercam472
Заголовок сообщения: Re: Need help for first repair on RX 580 Добавлено: 18 июл 2021, 18:22 |
Hello, I'm here again. So I failed the diagnosys because the card is working on HDMI output (and maybe other output). we can see a "garbage screen" : so the result under TServer is obviously "FAIL" 1) where can I see the logs ?
2) what is the difference between binaries 580 , 580a , 580g ....thanks again EDIT : ok I switched my brain on, now the results : 580 outputLog detailsso bank D is failing ? I also read that : Failcase The connectivity between the board’s ASIC and DRAMs may have issues. The failure analysis personnel should also ensure there is acceptable noise in the power supplies.
