Текущее время: 21 ноя 2026, 04:07
 Заголовок сообщения: Need help for first repair on RX 580
СообщениеДобавлено: 04 июл 2021, 19:16
Hello,
Thanks for receiving me here ;) just discovered this forum 24h ago, hope you will be able to help me
Card : MSI Armor RX 580 - 8GB - V341 - v1.3
Symptom : no display, fan are spinning, blue screen of death under windows (message is "forever loop in thread" or something like that)
under linux, message "Gfx test failed"
History is unknown, board is clean.
I can access and flash the bios with amdvbflash
REG1 is fine with 5.17 Volts output
U2 voltages are 0.98V PIN8 , 12V pin 5
U701 voltage is 1.58V PIN 8
VGPU (sorry don't know the exact term) is 0.95V
each GDDR Memory chip does have 1.58V under it.
U900 (PGOOD) output mesuared on R900 is 2.15V => I think it is normal ?
What can I check now ?
Thanks for reading
 Заголовок сообщения: Re: Need help for first repair on RX 580
СообщениеДобавлено: 04 июл 2021, 21:15
measure resistances on l900, l701, l500 and on pins 3 and 6 u300.
СообщениеДобавлено: 04 июл 2021, 22:09
you mean inductors ? do you want resistance when power is off, to check shorted inductors, or when power is on ?
also I need help to locate U300 I couldn't find it :/ I was just abble to measure 1.8V on R65 but couldn't find u300.
thanks
СообщениеДобавлено: 04 июл 2021, 22:24
not.
on the switched off card, measure the resistance to ground. one wire of the multimeter to "ground", and the other to the measuring point that I indicated.
readings in ohms. values - here.
About U300 in privat message.
СообщениеДобавлено: 04 июл 2021, 23:10
Ok :
L900 : 21 Ohms
L701 : 31 ohms
L500 : 31 ohms
U300 (really thanks for your PM it was really obvious but for me I was sure it was BIOS :)
2090 ohms on pin 3
1030 ohms on pin 6
СообщениеДобавлено: 05 июл 2021, 10:00
order by resistance. the patient is more likely alive than dead))
now there are two options - memory problems or a dying GPU. learn to test memory on amd cards. if the order is with memory, then change the GPU.
topics for studying memory testing on amd cards -
full theme
viewtopic.php?f=48&t=100822
download link from this thread
https://drive.google.com/file/d/111xZBU ... sp=sharing
СообщениеДобавлено: 05 июл 2021, 20:17
many thanks, I will read the links you provided to test the memory, hope the GPU is not dead.
СообщениеДобавлено: 18 июл 2021, 17:22
Hello, I'm here again.
So I failed the diagnosys because the card is working on HDMI output (and maybe other output).
we can see a "garbage screen" :
so the result under TServer is obviously "FAIL"
1) where can I see the logs ?
2) what is the difference between binaries 580 , 580a , 580g ....
thanks again
EDIT : ok I switched my brain on, now the results :
580 output
Log details
so bank D is failing ?
I also read that :
Failcase
The connectivity between the board’s ASIC and DRAMs may have issues. The failure analysis personnel should
also ensure there is acceptable noise in the power supplies.
В этой теме нет новых непрочитанных сообщений. Motherboard desktop repair _ Ps2 port mainboard repair
в форуме Gigabyte
no2comvn
13 янв 2017, 10:44
no2comvn Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. lenvo l520 (please help me i need bin lenvo l520) please help me i need bin lenvo l520
issabaouch
10 ноя 2017, 01:06
В этой теме нет новых непрочитанных сообщений. sve14ag19l (mbx-276) freezing on first sony logo
в форуме Sony
alifakhrniya
12 июн 2019, 11:25
alifakhrniya Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP probook 640 G2( energy star) (-) does not turn on without draining all the power first
Raydel87
12 июн 2019, 04:11
Raydel87 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Help help Help memory samsung detect micron (domate)
PT-AH
02 ноя 2022, 13:43
PT-AH Перейти к последнему сообщению
Сейчас этот форум просматривают: Anapchanin, kaare123 и гости: 63
