Текущее время: 16 июн 2024, 08:49
 Заголовок сообщения: GTX 1080ti not detected!
СообщениеДобавлено: 08 янв 2022, 01:24
Hello guys, happy holidays!
I have a Zotac 1080ti AMP Extreme. All voltages present, no short anywhere, core voltage is 800 mv, no missing components, no bad traces, yet still the card won't get detected!
pexrst is also ok on pins 1,2,4. The only clue I have is that I have 550 ohms on 1.8V which might suggest something. Can anyone help?
 Заголовок сообщения: Re: GTX 1080ti not detected!
СообщениеДобавлено: 08 янв 2022, 01:55
does the monitor react when turned on?
СообщениеДобавлено: 08 янв 2022, 02:09
check pex reset resistance (A11) it should be about 8Kohm or Mom
Pex_refclk on diode mode(A13 A14) it should be about 1.6v
of course pex TX0 (before the capacitors) and RX0 (diode mode)
even if it's a memory problem you should see it in device manager if you have mainboard video to connect to display.
СообщениеДобавлено: 08 янв 2022, 09:02
PEX reset A11 should be checked in a diode mode with red lead of the multimeter to the ground. It should give around 0.4...0.8V depending on the card. In the opposite polarity it should be open circuit.
Measuring a resistance of a single pin is useless because you can find only the "KZ" state using ohms. This magic resistance of the chip does not come from a resistance itself. It is quantum tunneling (Туннельный эффект) https://en.wikipedia.org/wiki/Quantum_tunnelling which gives experience of the low resistance of billions of transistors but it is only experience, not a real resistance coming from resistivity.
You can measure this "resistance" of the voltage rails with a large amount of semiconductors but not a single pin, where you can't even measure a diode reverse leakage by yourself.
СообщениеДобавлено: 08 янв 2022, 22:06
It's not being detected at all, not in device manager, nor in the Bios menu
 Заголовок сообщения: Re: GTX 1080ti not detected!  [РЕШЕНО]
СообщениеДобавлено: 09 янв 2022, 09:01
To TC.
Check it. All pair. Diode mode, + on GROUND.
В этой теме нет новых непрочитанных сообщений. ZOTAC GEFORCE GTX 1070 AMP! CORE ED 8GB 256 BIT DDR5 not detected
Pandemonium6
18
2153
17 авг 2021, 07:43
Pandemonium6 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Gigabyte GTX 1080 G1 card not detected
Traptor
208
14 июн 2024, 06:44
hrwang Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP4510s (INVENTEC 6050A2252701-MB-a03) Ошибка mouse not detected
jjoloka
2654
17 июл 2015, 16:51
jjoloka Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. asus x550d (x750d rev2.0) h.d.d not detected
alifakhrniya
29 янв 2016, 22:37
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. EliteOne 800 G1 (HP) 511-CPU fan not detected
KlimenkoEY
13 апр 2017, 12:18
KlimenkoEY Перейти к последнему сообщению
Сейчас этот форум просматривают: Google [Bot] и гости: 26
