dani82If you track VDDCI_COMP in any circuit containing VDDCI, you will see how the control signal is applied to this pin. I mean the 7th pin. It performs both an enabling function and a compensation function.
You can use this circuit for example:
viewtopic.php?f=48&t=88497&p=915354&hilit=%2AV341%2A#p915354The chip is different, the principle is the same.
