Текущее время: 21 ноя 2026, 04:22
 Заголовок сообщения: HP 255 G7 (LA-G07JP) No initialization, Strange behavior
СообщениеДобавлено: 15 фев 2024, 16:12
Hi..
this board came with symptoms that it turns on with no init, the fan goes to full speed, the screen flickers and the board keeps cycling like there is a reset, nothing on the caps-lock..
I made a USB bios recovery and the board started with it and screen shows "Flashing Boot Block" then a restart with no display and no init like it was before, USB bios recovery didn't work again..
after flashing it (rarely) gives caps-lock code 5 long 3 short
disassembled and checked, found some rotten SPI resistors in the exact same location mentioned here: viewtopic.php?f=53&t=135346&p=1018810&hilit=%2Ala+g07%2A#p1018810
Вложение:
and rotten divider resistors at PU301:
Вложение:
all replaced but still nothing, checked SPI signals and found that sometimes there's attempts to read and sometimes it's silent, in some attempts (in 1 of 100) it reads and board initialized..
replaced and flashed KB9022 ec chip, bios flashed with official bios, still nothing...
checked the whole board and found low resistance on 3V PL302 = 18 ohms !
injecting the line reveals a heating network controller UL1, removed and the resistance became 30 ohms, still low
removed all peripherals and the resistance still 30 ohms with 200mA consumption, nothing is heating on the board except a barely heating cpu
definitely a dead pch..
Before sending him to the grave the question is could a dead Ryzen pch still able to post and init or I miss-diagnosed it ?? :ps_ih:
 Заголовок сообщения: Re: HP 255 G7 (LA-G07JP) No initialization, Strange behavior
СообщениеДобавлено: 15 фев 2024, 19:29
have you tried to remove Pu301? it can be damaged
СообщениеДобавлено: 15 фев 2024, 22:46
yes of course I did that and the line resistance still 30 ohms
СообщениеДобавлено: 16 фев 2024, 10:30
Check a switch u17. if its okay try to remove Ryzen
СообщениеДобавлено: 16 фев 2024, 20:34
checked and still nothing, I can't remove/replace the cpu I don't have the tools for it..
it is the only thing that heats up on the board and consumes 200mA but the funny part is that it reads the bios and give init sometimes !
I also noticed that the resistance is not fixed, it varies between 16~41 ohms each time the board switched on/off
В этой теме нет новых непрочитанных сообщений. Asrock RX580 - strange behavior
TheMArcos
29 сен 2020, 06:29
TheMArcos Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. RTX 2060 6GB ZOTAC AMP - Strange behavior/crash if core >1700MHz
cxav
10 июн 2021, 23:16
preex Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP 15t-dw300 (LA-K201P Rev 2.0) Strange slips behavior after flooding..
mohammedsf
27 янв 2023, 05:23
mohammedsf Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 255 G7 (LA-G07JP Rev:2.0) Нет инициализации, помогите определить элементы
agsojer
11
3090
16 авг 2023, 13:12
agsojer Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP 255 G7 (la-g07jp rev:2.0) выключение вместо перезагрузки
Shalun-avd
01 авг 2023, 09:37
Shalun-avd Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 115
