Текущее время: 21 ноя 2024, 20:15
Часовой пояс: UTC + 4 часа
 Заголовок сообщения: Asus N56JN (Compal) Charging issue
СообщениеДобавлено: 19 май 2024, 19:02
Good Day Experts.
I have an Asus N56JN rev2.0 which works fine only on adapter but wont charge,. When charger is connected charging led is lit but battery is not charging and battery keeps draining until its dead.. without battery there is 2.56 volts on battery +connector and 3.3v on battery scl sda pins, acdet 2.5v when battery is connected it takes 0 amps via bench PSU which means not charging. bq24735 replaced but no help. anyone can shed a light and guide me into right direction, Thanks
 ! Ciber SLasH писал(а):
Where indication of a platform?
link: >>> Ruled creations of a subject and definition of a platform of the laptop <<< oblige:
Requirements at creation of a new subject in the section on repair of laptops:
- provide the name of a platform of the device.
 Заголовок сообщения: Re: Asus N56JN (Compal) Charging issue
СообщениеДобавлено: 19 май 2024, 20:50
When creating a topic, you must indicate the model of the motherboard.
what about the input mosfets?
take measurements on bq24735 and post it.
СообщениеДобавлено: 19 май 2024, 22:34
Thanks for replying
bq24735 has below voltages
chg acn 19.1v
chg acp 19.1v
chg cmsrc 19.1v
chg acdrv 19.1v
chg acok 3.1v
chg acdet 2.25v
chg iout 0v
sda, scl 3.3v
ILIM 0.872V
BATDRV 2.29v
srn 2.29v
srp 2.29v
chg lg 0v
regn 6v
bst 5.8v
chg hg 2.25v
chg lx 2.29v
vcc 19.1v
Thanks in advance.
СообщениеДобавлено: 19 май 2024, 22:55
frankmnld
frankmnld писал(а):
chg acdrv 19.1v
Этот замер, если его приложить к остальным замерам, говорит о том, что пробит входной mosfet.
Should be 25v.
Сообщение не в тему
В прошлом году был в Эйндховене, прекрасный город, чудесная страна.
СообщениеДобавлено: 19 май 2024, 23:15
Input mosfet means the 1st mosfet where the adapter voltage comes in..? if yes that i have replaced. before the mosfet there was no charging led. after the mosfet charging led came on but still not charging.. or you mean some other mosfet. what can i do..?
Ow thats right about the city. have you visited any other places .?
СообщениеДобавлено: 19 май 2024, 23:42
frankmnld
Two mosfets, на gates которых приходит сигнал acdrv
PQ8801, PQ8802 on board
Последний раз редактировалось Виктор1985 19 май 2024, 23:52, всего редактировалось 1 раз.
СообщениеДобавлено: 19 май 2024, 23:43
Ok. let me check that.. Thanks
СообщениеДобавлено: 20 май 2024, 12:12
frankmnld писал(а):
chg acdet 2.25v
обычно acdet 2.6v
СообщениеДобавлено: 20 май 2024, 14:30
ruzalit
Кстати да. Для этого чарджера пределы acdet 2.4 - 3.15в, единственное, acok тогда не должно быть, если acdet "неправильный". Ну и правильный acdet никак не залечит пробитый мосфет на входе.
СообщениеДобавлено: 20 май 2024, 14:57
I guess i have written it wrong. acdet is indeed 2.65v.. replaced both input mosfets but still the same. 2.55v on battery+.
СообщениеДобавлено: 20 май 2024, 15:38
frankmnld Goedemiddah)
Acdrv now? We need to see 25v on this pin, and then replace the new battery.
СообщениеДобавлено: 20 май 2024, 16:28
На 20 vcc выводе чарджера номинал резистора pr8842 в пределах 10 Ом ? Снимите временно защитную сборку PD6001
СообщениеДобавлено: 20 май 2024, 17:27
I have replaced 2 diodes near the bq735 and took out 1st input mosfet and bypassed with a wire. now i do see 11.20v on bat+ pin and battery is also charging since its now at 95% from 7%..
But..now..if i remove the adapter it still says connected and charging while adapter is not connected.
2nd.. windows not updating battery percentage so seems like it only charhe when its off.
Posted after 3 minutes 44 seconds:
Its still the same yet symptoms at above
Posted after 17 minutes 57 seconds:
A windows reinstall fixed charger detection issue i guess now it does not give false charger connected. it does charge but in wondows it does not change the percentage. everytime i connect disconnect charger or restarts the laptop then it shows the actual percentage but its not updating in windows
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS N56JN (N56JN rev 2) не запускается
tmii
16 июн 2016, 00:38
tmii Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Samsung keyboard maping issue NP450R5E (ramos) keyboard maping issue
в форуме Samsung
minanpil13
03 апр 2019, 10:30
minanpil13 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus N56J (Asus N56JN REV 2.0) Подобрать шлейф матрицы
fermer
906
18 фев 2024, 12:37
fermer Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Asus n56j (n56jn rev2.0) Нужен диод 1SS355PT
Sergez
09 авг 2017, 17:58
Sergez Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ASUS N56JN-CN129H (N56NJ) НЕТ ПОСТОВ
MsDos26
2065
13 мар 2018, 15:41
MsDos26 Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
