Текущее время: 19 сен 2024, 05:49
 Заголовок сообщения: Searching for software, script for Cayman XT gpu (hd6970)
СообщениеДобавлено: 30 дек 2022, 14:35
I have downloaded tserver with a big amounts of preconfigured tests, but i cant seem to find one for cayman xt gpu-s.
Is there one, or how can i test my gpu-s?
Thanks in advance!
 Заголовок сообщения: Re: Searching for software, script for Cayman XT gpu (hd6970)
СообщениеДобавлено: 30 дек 2022, 19:15
here search viewtopic.php?f=48&t=100822&hilit=%2Atserver%2A
СообщениеДобавлено: 04 янв 2023, 00:16
RhOuCnK
hı can you share this program
СообщениеДобавлено: 05 авг 2024, 23:27
mad king
Thanks for the resources!
preex
The download link went down, but i have it on a hdd.
It has several paritions with different linux enviroments.
Do you have an idea how can i share it?
СообщениеДобавлено: 12 авг 2024, 00:17
The issue is finally solved.
It turned out that even if the suite does not contain a "memfa" script, it can be found when launching tserver with "-menu".
In the GUI you can select different tests / bundle of tests and memfa is one of them.
This way all the cards that are supported by the tserver version can be tested even if memfa isnt defined.
I could test several HD5770, HD6870 and HD6970 cards.
This test also produces memfa.log so the result can be seen.
I dont have the resources to test more cards at the moment, but i think that this way several more older cards can be tested.
I will leave this thread open to update it with new cards that i have tried it with.
В этой теме нет новых непрочитанных сообщений. Need memory test software/script for RX 6900XT ASROCK
[ На страницу: 1, 2, 3, 4 ]
thegregin
94
21445
01 июл 2024, 23:03
kaare123 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. memory test software/script for RX 6950XT
Vdfm
27 ноя 2023, 16:00
dapove15662 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Видеокарту HD6970 2gb iMac
в форуме Куплю | Buy
zoom222
17 мар 2017, 19:02
zoom222 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. need some help for ati cards with memory errors for making script
[ На страницу: 1 ... 54, 55, 56 ]
ilie321
1664
342898
26 авг 2024, 10:53
lexgreem Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. vram test tool issue script ..
bokin021
24 июн 2022, 17:07
DoktorVGA Перейти к последнему сообщению
Сейчас этот форум просматривают: tangol и гости: 21
