Заголовок сообщения: Searching for software, script for Cayman XT gpu (hd6970)
Добавлено: 30 дек 2022, 13:35
Зарегистрирован: 28 дек 2021, 00:42 Наличности на руках: 668.09 Сообщения: 108 Откуда: Magyarország
I have downloaded tserver with a big amounts of preconfigured tests, but i cant seem to find one for cayman xt gpu-s. Is there one, or how can i test my gpu-s?
Thanks in advance!
MoneyBot
MoneyBot
madking
Заголовок сообщения: Re: Searching for software, script for Cayman XT gpu (hd6970)
Добавлено: 30 дек 2022, 18:15
Зарегистрирован: 03 ноя 2017, 00:24 Наличности на руках: 3,828.01 Сообщения: 4192 Откуда: Budapest
Добавлено: 05 авг 2024, 22:27
mad king
Thanks for the resources!
preex The download link went down, but i have it on a hdd. It has several paritions with different linux enviroments. Do you have an idea how can i share it?
RhOuCnK
Добавлено: 11 авг 2024, 23:17
The issue is finally solved. It turned out that even if the suite does not contain a "memfa" script, it can be found when launching tserver with "-menu". In the GUI you can select different tests / bundle of tests and memfa is one of them.
This way all the cards that are supported by the tserver version can be tested even if memfa isnt defined. I could test several HD5770, HD6870 and HD6970 cards.
This test also produces memfa.log so the result can be seen.
I dont have the resources to test more cards at the moment, but i think that this way several more older cards can be tested. I will leave this thread open to update it with new cards that i have tried it with.
