Hi.
I received this card and used AGt and Tserver but there would be no output from AGT and Tserver (Ak600,AK400)...(I use it as secondary card and not main display)
Changed the Bios with working and verified one related to the memory chips and there still 0 MB vram on gpuz and no output from AGT, Tserver....
I used Thermal cam and no hot points on memory chips.
All Voltages are Normal and All ohms too.
I suspected that the GPU chip is dead and changed the chip and reworked it with good Gpu...
Strangely still I get 0 MB vram and no Agt/Tserver output, If I use The card for main display its output is constant blackscreen with no alarming beeps....
