Apacer AS340 120GB (на контроллере Phison PS3111) Появляется логотип и ОС виснет... бывает работает без проблем В логе: "Драйвер обнаружил ошибку контроллера \Device\Ide\IdePort0"
phison_flash_id
v0.845a Drive: 0(ATA) OS: 6.1 build 7601 Service Pack 1 Model: Apacer AS340 120GB Fw : AP613PE0 Size : 114473 MB Firmware lock supported [FB 00 01 01] Drive unlocked [FB 00 01 03] P/N : 22060120 , SBSM61.5 S11fw: SBFM61.3, 2021Mar11 S11rv: M61.3-90 Bank00: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0x6 - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die Bank01: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0x6 - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die Bank08: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0x6 - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die Bank09: 0x98,0x3c,0x98,0xb3,0x76,0x72,0x8,0x6 - Toshiba 64L BiCS3 TLC 16k 256Gb/CE 256Gb/die 2Plane/die Controller : PS3111 Flash CE : 4 Flash Channel : 2 Dram Size,MB : 32 Flash CE Mask : [++------ ++------] Flash Mode/Clk: 2/5 (Set 2/5) Block per Die : 2956 Block per CE : 2956 Page per Block: 768 SLC Cache : 786432(0xc0000) PE Cycle Limit: 3000
ParPage : 00 MaxBBPerPlane : 152 Plane : 2
Defects All(per plane) Early Later Bank00: 10(4,6) 10(4,6) 0(0,0) Bank01: 52(36,16) 50(35,15) 2(1,1) Bank08: 6(4,2) 6(4,2) 0(0,0) Bank09: 3(3,0) 3(3,0) 0(0,0) Total : 71 69 2
Early defect list Bank00: 58 200 201 256 745 1706 1747 1751 1755 1759 Bank01: 256 1180 1182 1465 1467 1469 1471 1472 1473 1474 1475 1476 1477 1478 1479 1480 1482 1484 1486 1488 1490 1492 1494 1496 1498 1500 1502 1504 1506 1508 1510 1514 1518 1522 1526 1532 1546 1550 1552 1580 1622 1628 2457 2481 2842 2929 2933 2937 2941 2953 Bank08: 25 256 460 1227 1986 2096 Bank09: 256 2346 2868
Later defect list Bank01: 1243 2486
PS3111 smart configuration: Attr Tresh Flags ValId WrstId RawId Description 0x09: 0x00 0x32 0x0000 0x0000 0x0600 - Power on hours 0x0C: 0x00 0x32 0x0000 0x0000 0x0607 - Power on/off cycles 0xA3: 0x00 0x32 0x0000 0x0000 0x0201 - Max Erase Count 0xA4: 0x00 0x32 0x0000 0x0000 0x0202 - Avg Erase Count 0xA6: 0x00 0x32 0x0000 0x0000 0x0302 - Total Later Bad Block Count 0xA7: 0x00 0x32 0x0000 0x0000 0x0709 0xA8: 0x00 0x32 0x0000 0x0000 0x0103 - SATA PHY error count 0xAB: 0x00 0x32 0x0000 0x0000 0x0501 - Program Fail Count 0xAC: 0x00 0x32 0x0000 0x0000 0x0502 - Erase Failure Count 0xAF: 0x00 0x32 0x0000 0x0000 0x0100 - Number of ECC Error 0xC0: 0x00 0x32 0x0000 0x0000 0x0608 - Unexpected Power Loss Count 0xC2: 0x3A 0x22 0x0300 0x0301 0x0800 - Current Temp/Min Temp/Max Temp 0xE7: 0x00 0x12 0x0000 0x0000 0x020A - SSD life left 0xF1: 0x00 0x32 0x0000 0x0000 0x0400 - Host Write (Sectors)
Перепрошивка поможет или нет?
