Текущее время: 10 ноя 2026, 05:20
| Автор |
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 21 сен 2026, 11:07 |
| Интересующийся |
Зарегистрирован: 14 янв 2026, 00:07 Наличности на руках: 45.04
Сообщения: 34 Откуда: Sri Lanka
hrwang писал(а): what amazing i want to learn from you This was created by our dear friend MEINSTER from Portugal, who developed this test. All credit should go to him. It’s a very good and functional tool. It’s not yet a complete test and doesn’t work with every board, but it helps a lot. I’ve already managed to solve many problems using it.
_________________ Supporte | Hardware Diagnostics & Micro-soldering ---------------------------------------------------------------------------- ⚡ Medir. Analisar. Reparar. | Grato por aprender e contribuir com esta comunidade!
MoneyBot
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки |
MoneyBot
xiconfjs
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 22 сен 2026, 02:35 |
| Я тут случайно |
Сообщения: 1 Откуда: far far away
Supporte писал(а): I have just received this, and I am leaving it here for anyone who wants to test it. If anyone has a repository or mirror to upload this file to, so that others who might need it in the future can easily access it, I would be incredibly grateful. Once you have had a chance to test it, please leave your feedback in the comments. It is primarily aimed at the 4000 and 5000 series and works in both Legacy and UEFI modes. https://www.swisstransfer.com/dl/01a067 ... 78d5eeff41 Hi, thank you for the upload. Could you re-upload this again, because sadly the upload got removed :/ Edit: I found this source of the Meister versions of MATS/MOTS: https://drive.google.com/drive/folders/1dSKmQ-2Nw_im-QbXZin7TBbdFJR8AN1X – looks good
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 22 сен 2026, 13:31 |
| Интересующийся |
xiconfjs писал(а): Could you re-upload this again xiconfjs писал(а): Could you re-upload this again, I’ll send it again. I’m uploading it to SwissTransfer once more. Posted after 26 minutes 33 seconds:I’m uploading it again now. I’ve just realised why the previous link expired before the 30 days: in addition to the 30-day limit, SwissTransfer only allows up to 250 downloads. So I’m sure many people downloaded it, but unfortunately nobody was able to upload it to another repository to help contribute to the community. Anyway, I’m sharing it here again. The link will be available for 30 days, or until it reaches 250 downloads — whichever comes first. The file is **MATS MODS by MEINSTER V6**. https://www.swisstransfer.com/dl/01a0c8 ... 00156823b4https://drive.google.com/drive/folders/ ... sp=sharing
leonemax81
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 04 окт 2026, 17:55 |
| Интересующийся |
Зарегистрирован: 19 авг 2018, 11:39 Наличности на руках: 84.03
Сообщения: 22 Откуда: italia
What program did you use to write to the USB drive? Supporte писал(а): The file is **MATS MODS by MEINSTER V6**. https://www.swisstransfer.com/dl/01a0c8 ... 00156823b4 What program did you use to write to the USB drive?
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 05 окт 2026, 08:12 |
| Интересующийся |
leonemax81 писал(а): What program did you use to write to the USB drive? RUFUS
I*Wi!!*Ki!!*You
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 08 окт 2026, 18:34 |
| Интересующийся |
Сообщения: 45 Откуда: Казань
Димон писал(а): -dramclk_percent 100 сильно меньше чем 5 часов снизьте до 50% хотяб
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 09 окт 2026, 12:25 |
| Интересующийся |
Димон писал(а): Имею ноут на RTX3070m 8Gb, в винде код 43, mats ничего не показал Have you checked whether all the voltages are present and correct, including the GPU core and VRAM power rails? If the card isn't receiving power, it won't be detected, and the test won't run.
Димон
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 09 окт 2026, 19:09 |
| Интересующийся |
Зарегистрирован: 24 окт 2016, 10:10 Наличности на руках: 13.05
Сообщения: 80 Откуда: Славгород
Да конечно, все фазы и на видеочипе и на видеопамяти работают, проверял осциллографом. Проверяю 520.175, ранние версии не нашел подходящих, все с ошибкой 464 Чип меняли да меня, с залитой платы, компаунд на чипе так себе. ---------- Добавлено спустя 32 минуты 28 секунд: ---------- Не дождался окончания теста, выключил вчера, сейчас флеху просмотрел, текстовый документ есть, 35кб весит в конце - Error Code = 000000000818 и надпись FAIL конечно, куда смотреть теперь фиг знает
MoneyBot
MoneyBot
Sanches524
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 16 окт 2026, 12:49 |
| Пользователь |
Зарегистрирован: 22 авг 2015, 07:45 Наличности на руках: 34.46
Сообщения: 625 Откуда: Междуреченск
ruzalit писал(а): В лс скинул одноразовую ссылку. и мне можно тоже. заранее спасибо
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 19 окт 2026, 13:58 |
| Интересующийся |
Ecnelis писал(а): С меги не скачивает. Будьте добры, кто имеет, перезалейте на гугл или яндекс, пожалуйста There’s a Google Drive link I shared a little further up in the thread containing the latest version of MEINSTER’s test.
Supporte
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 21 окт 2026, 08:27 |
| Интересующийся |
Ecnelis писал(а): Image is corrupted and cannot be opened with basic Windows utilities. I've tried download it 2 times and both no changes. Occurs an error. Then I've tried it with UltraISO and threw error as well. And i thought okay let's just write it on my flash so my flash goes in error as same as i'm just trynna open it regularly. Do you have any possibilites to extract files out of it and upload it as archive no image method please  It’s quite simple. You just need to download a compressed file that is around 20 GB in size. It’s compressed using 7-Zip, but I use WinRAR to extract it, and it works perfectly for me. Once extracted, you’ll have an IMG file of around 60 GB. Open Rufus, which is a tool for writing ISO/IMG images to a drive, select the image file and your USB drive. The USB drive must be larger than 64 GB. I used a standard 128 GB USB drive, but I believe an external HDD or SSD should work just as well. Once the image has been written to the drive, boot from it with Secure Boot disabled, and you’re good to go!
alexkotyara
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 27 окт 2026, 21:46 |
| Я тут случайно |
Зарегистрирован: 11 апр 2025, 18:31 Наличности на руках: 16.03
Сообщения: 7 Откуда: smolensk
ruzalit писал(а): в лс скинул.
Можно и мне пожалуйста
gexiu2026
Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки  Добавлено: 28 окт 2026, 06:51 |
| Я тут случайно |
Сообщения: 1 Откуда: Hangzhou, China
Для GA107 (GN20-S7-B-MP-KB-A1, RTX 2050 mobile) верная линия — 455. Начинать лучше с универсальной сборки 455.127: версии вида 455.195 привязаны к конкретной разводке платы и на другой карте дают ложные ошибки по каналам. Запуск: ./mods gputest.js -skip_rm_state_init. Если на мобильной карте mods не стартует — попробуйте чистый mats, он менее требователен к инициализации состояния памяти. ---------- Добавлено спустя 1 час 3 минуты 5 секунд: ---------- Raw .img — это не архив, а побайтовый образ флешки вместе с таблицей разделов, поэтому 7-Zip, UltraISO и стандартные средства Windows и ругаются на «повреждённый файл». Писать его нужно в режиме образа диска: Rufus — выбрать .img и режим записи «Образ диска», либо USB Image Tool — Restore. Перед записью сверьте SHA256 с указанным автором: если хеш совпал, файл целый, и ошибка была именно от попытки открыть образ архиватором. И ещё: и .iso, и .img пишутся на одну и ту же флешку целиком, после записи разделы в Windows могут не отображаться — это нормально.
Похожие темы |
Ответы |
Просмотры |
Последнее сообщение |
Пошаговая инструкция Mods+Mats Тест видеопамяти
[ На страницу: 1 ... 22, 23, 24 ]
marcev174 |
704 |
484500 |
28 сен 2026, 15:18
Supporte
Помогите правильно запустить тест mats mods 94,178
massimko |
5 |
6491 |
21 окт 2023, 17:49
ser51
Mods Mats 455.167 для Uefi
SpeedLan |
3 |
9003 |
16 мар 2023, 13:36
com77
MATS/MODS 455 проверка памяти со встроенной видеокартой
vitas-iv |
3 |
8896 |
05 май 2023, 15:29
vitas-iv
Mats mods 400.184 разбирайте господа!
[ На страницу: 1, 2, 3 ]
clockerkz |
88 |
88758 |
19 мар 2020, 01:42
Rom
