Текущее время: 11 ноя 2026, 08:05
 Страница 30 из 31 [ Сообщений: 902 ]  На страницу Пред.  1 ... 27, 28, 29, 30, 31  След.
Куратор темы: buyanigor
 Заголовок сообщения: Re: MATS/MODS 400/455/520/570 Тест видеопамяти nVidia для флешки
СообщениеДобавлено: 21 сен 2026, 11:07
hrwang писал(а):
what amazing
i want to learn from you
This was created by our dear friend MEINSTER from Portugal, who developed this test. All credit should go to him.
It’s a very good and functional tool. It’s not yet a complete test and doesn’t work with every board, but it helps a lot. I’ve already managed to solve many problems using it.
Supporte | Hardware Diagnostics & Micro-soldering
⚡ Medir. Analisar. Reparar. | Grato por aprender e contribuir com esta comunidade!
СообщениеДобавлено: 22 сен 2026, 02:35
Supporte писал(а):
I have just received this, and I am leaving it here for anyone who wants to test it. If anyone has a repository or mirror to upload this file to, so that others who might need it in the future can easily access it, I would be incredibly grateful.
Once you have had a chance to test it, please leave your feedback in the comments. It is primarily aimed at the 4000 and 5000 series and works in both Legacy and UEFI modes.
https://www.swisstransfer.com/dl/01a067 ... 78d5eeff41
Hi, thank you for the upload. Could you re-upload this again, because sadly the upload got removed :/
Edit:
I found this source of the Meister versions of MATS/MOTS: https://drive.google.com/drive/folders/1dSKmQ-2Nw_im-QbXZin7TBbdFJR8AN1X – looks good
СообщениеДобавлено: 22 сен 2026, 13:31
I’ll send it again. I’m uploading it to SwissTransfer once more.
Posted after 26 minutes 33 seconds:
I’m uploading it again now. I’ve just realised why the previous link expired before the 30 days: in addition to the 30-day limit, SwissTransfer only allows up to 250 downloads. So I’m sure many people downloaded it, but unfortunately nobody was able to upload it to another repository to help contribute to the community.
Anyway, I’m sharing it here again. The link will be available for 30 days, or until it reaches 250 downloads — whichever comes first.
The file is **MATS MODS by MEINSTER V6**.
https://www.swisstransfer.com/dl/01a0c8 ... 00156823b4
https://drive.google.com/drive/folders/ ... sp=sharing
СообщениеДобавлено: 04 окт 2026, 17:55
What program did you use to write to the USB drive?
СообщениеДобавлено: 05 окт 2026, 08:12
RUFUS
СообщениеДобавлено: 08 окт 2026, 09:38
Имею ноут на RTX3070m 8Gb, в винде код 43, mats ничего не показал, запустил mods c ./mods gputest.js -oqa -old_gold -fan_speed 70 -dramclk_percent 100 -ignore_fatal_errors -run_on_error -matsinfo -test 3 - сколько по времени должен длиться тест? Пять часов уже орет вентилями
СообщениеДобавлено: 08 окт 2026, 18:34
сильно меньше чем 5 часов
снизьте до 50% хотяб
СообщениеДобавлено: 09 окт 2026, 12:25
Have you checked whether all the voltages are present and correct, including the GPU core and VRAM power rails? If the card isn't receiving power, it won't be detected, and the test won't run.
СообщениеДобавлено: 09 окт 2026, 19:09
Да конечно, все фазы и на видеочипе и на видеопамяти работают, проверял осциллографом.
Проверяю 520.175, ранние версии не нашел подходящих, все с ошибкой 464
Чип меняли да меня, с залитой платы, компаунд на чипе так себе.
---------- Добавлено спустя 32 минуты 28 секунд: ----------
Не дождался окончания теста, выключил вчера, сейчас флеху просмотрел, текстовый документ есть, 35кб весит в конце - Error Code = 000000000818
и надпись FAIL конечно, куда смотреть теперь фиг знает
СообщениеДобавлено: 11 окт 2026, 07:32
Добрый день. Прошу не кидаться тапками. Что скачать для карты GTX770?
Этого образа будет достаточно?
СообщениеДобавлено: 11 окт 2026, 10:57
viewtopic.php?f=48&t=124090
СообщениеДобавлено: 11 окт 2026, 14:19
спасибо. сам бы я ни за что не догадался....
СообщениеДобавлено: 11 окт 2026, 16:47
GK204 367 версия матс тестировать должна тоже.
viewtopic.php?f=48&t=110020
СообщениеДобавлено: 15 окт 2026, 11:23
яндекс диск накрылся, через mega не качает. нужен матс 520 для теста rtx4070
может кто есть добрый на гугл диск залить?))
СообщениеДобавлено: 15 окт 2026, 13:52
подскажите, в чем подвох
использую mats 455.127 для проверки RTX3050 (GN20-P0-R-K2-A1)
постоянно показывает ощибки чтения по всем микросхемам памяти
в furmark бублик крутится с этим gpu без замечаний
похоже, для теста нужна другая сборка
СообщениеДобавлено: 15 окт 2026, 19:14
Используйте не 127, а 195 версию, она точно работает с этим видеочипом.
СообщениеДобавлено: 16 окт 2026, 11:00
ruzalit ,спасибо!
если не секрет 455.195 где искать?
Алиса говорит на влабе. Но неочевидно.
СообщениеДобавлено: 16 окт 2026, 11:32
Сейчас не знаю где, ссылки битые, я пользуюсь сборками и в них разные есть версии. В лс скинул одноразовую ссылку.
СообщениеДобавлено: 16 окт 2026, 12:49
и мне можно тоже. заранее спасибо
СообщениеДобавлено: 16 окт 2026, 13:12
Я только 455.195 скинул, вам то нужна 520. Чуть выше ссылка есть на гугл с сборкой.
СообщениеДобавлено: 18 окт 2026, 18:21
ruzalit
для GA107 GN20-S7-B-MP-KB-A1 RTX2050 не подскажите какую версию использовать, если 455.195, то можно и мне ссылку
СообщениеДобавлено: 18 окт 2026, 19:14
в лс скинул.
СообщениеДобавлено: 19 окт 2026, 03:24
С меги не скачивает. Будьте добры, кто имеет, перезалейте на гугл или яндекс, пожалуйста
СообщениеДобавлено: 19 окт 2026, 13:58
There’s a Google Drive link I shared a little further up in the thread containing the latest version of MEINSTER’s test.
СообщениеДобавлено: 21 окт 2026, 07:25
Image is corrupted and cannot be opened with basic Windows utilities. I've tried download it 2 times and both no changes. Occurs an error. Then I've tried it with UltraISO and threw error as well. And i thought okay let's just write it on my flash so my flash goes in error as same as i'm just trynna open it regularly. Do you have any possibilites to extract files out of it and upload it as archive no image method please
СообщениеДобавлено: 21 окт 2026, 08:27
It’s quite simple. You just need to download a compressed file that is around 20 GB in size. It’s compressed using 7-Zip, but I use WinRAR to extract it, and it works perfectly for me.
Once extracted, you’ll have an IMG file of around 60 GB. Open Rufus, which is a tool for writing ISO/IMG images to a drive, select the image file and your USB drive. The USB drive must be larger than 64 GB. I used a standard 128 GB USB drive, but I believe an external HDD or SSD should work just as well.
Once the image has been written to the drive, boot from it with Secure Boot disabled, and you’re good to go!
СообщениеДобавлено: 27 окт 2026, 21:46
ruzalit писал(а):
в лс скинул.
Можно и мне пожалуйста
СообщениеДобавлено: 28 окт 2026, 06:51
Для GA107 (GN20-S7-B-MP-KB-A1, RTX 2050 mobile) верная линия — 455. Начинать лучше с универсальной сборки 455.127: версии вида 455.195 привязаны к конкретной разводке платы и на другой карте дают ложные ошибки по каналам. Запуск: ./mods gputest.js -skip_rm_state_init. Если на мобильной карте mods не стартует — попробуйте чистый mats, он менее требователен к инициализации состояния памяти.
---------- Добавлено спустя 1 час 3 минуты 5 секунд: ----------
Raw .img — это не архив, а побайтовый образ флешки вместе с таблицей разделов, поэтому 7-Zip, UltraISO и стандартные средства Windows и ругаются на «повреждённый файл». Писать его нужно в режиме образа диска: Rufus — выбрать .img и режим записи «Образ диска», либо USB Image Tool — Restore. Перед записью сверьте SHA256 с указанным автором: если хеш совпал, файл целый, и ошибка была именно от попытки открыть образ архиватором. И ещё: и .iso, и .img пишутся на одну и ту же флешку целиком, после записи разделы в Windows могут не отображаться — это нормально.
СообщениеДобавлено: 09 ноя 2026, 21:31
Привет. Lenovo Legion Y540, NM-C531/ RTX 2060 Mobile (TU106).
Ошибка 43, не работает HDMI.
По диагностике MODS/MATS 520.175 все ошибки находятся исключительно в канале FBIOC0 (536370 ошибок). Остальные каналы без ошибок.
Видеопамять Samsung K4Z80325BC-HC14.
Менять чип памяти C0?
СообщениеДобавлено: 09 ноя 2026, 22:55
С0 и с1 местами меняйте и если ошибка останется, то перекатывайте видеочип и всю оставшуюся с компаундом видеопамять.
В этой теме нет новых непрочитанных сообщений. Пошаговая инструкция Mods+Mats Тест видеопамяти
[ На страницу: 1 ... 22, 23, 24 ]
marcev174
704
484861
28 сен 2026, 15:18
Supporte Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Помогите правильно запустить тест mats mods 94,178
massimko
21 окт 2023, 17:49
ser51 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Mods Mats 455.167 для Uefi
SpeedLan
16 мар 2023, 13:36
com77 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. MATS/MODS 455 проверка памяти со встроенной видеокартой
vitas-iv
05 май 2023, 15:29
vitas-iv Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Mats mods 400.184 разбирайте господа!
[ На страницу: 1, 2, 3 ]
clockerkz
88
88794
19 мар 2020, 01:42
Rom Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 29
