Текущее время: 18 июн 2024, 16:28
 Заголовок сообщения: Dell N5010 DG15 NOT START
СообщениеДобавлено: 01 июл 2013, 12:17
I study this topic: viewtopic.php?p=59795#p59795
But I find there is somethings different.
I have N5010 DG15 with this voltage:
AC_IN_KBC#=.17V
LID_CLOSE#=3.3V
PCH_RSMRST=3.3
PM_SLP_S3#=0V
EC & BIOS firmware sews and OK.
But not start.
so I test voltage on working exact M.B and I see this:
AC_IN_KBC#=.17V
LID_CLOSE#=3.3V
PCH_RSMRST=3.3
PM_SLP_S3#=0V but working fine.
I want to know this voltage existence to laptop start is necessary? so why second one start and work fine without AC_IN_KBC#,PM_SLP_S3#?
Don't give up without the fight.
 Заголовок сообщения: Re: Dell N5010 DG15 NOT START
СообщениеДобавлено: 01 июл 2013, 12:46
see start-up sequence in schematic diagram (p94 or 98)
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 01 июл 2013, 14:39
thank for good advise. I follow voltage according to Power sequence . all exist and good , by pressing power switch KBC_PWRBTN_EC# & PM_PWRBTN# goes to 0 but after power switch press, PM_SLP_S4# not appear on EC. U think it mean we have corrupted HUB(PCH)?
СообщениеДобавлено: 01 июл 2013, 22:56
If PM_RSMRST# is 3.3V, BIOS Ok and previus conditions ok then it possible.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 06 июл 2013, 15:10
I changed PCH(HM57), so.......... When plug power jack turns ON and goes OFF after 1 sec, I sinned on PL4901, resistance 10 Ohm, took PL4901 and connect power jack and turns and stays ON. So there is Short circuit, but I cannot find, I checked 1.05VTT connections but no success. What do you think?
СообщениеДобавлено: 06 июл 2013, 16:27
Try to program bios (with clear ME), because you had changed PCH. Maybe it didn't solder?
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 06 июл 2013, 20:00
I sewed BIOS, but what is ME bios?
СообщениеДобавлено: 06 июл 2013, 20:19
ME - Managment Engine - is a Intel part for ME-engine in PCH. ME-region is a part of flash IC. Other parts are: BIOS-region (bios exactly), GB-rerion, OEM-region. There is a lot of information about ME.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 06 июл 2013, 20:28
Wonderful, U have any reference to digging more about this? ( ME-region and .......) and How can I made BIOS, ME_region?
СообщениеДобавлено: 06 июл 2013, 20:47
on DELL web bios with clear ME.
viewtopic.php?f=181&t=6897
http://vlab.su/viewtopic.php?f=181&t=7012
viewtopic.php?f=181&t=2460
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 07 июл 2013, 10:27
RsM писал(а):
I confused, there is some exact techniques to generate ME-Clean Bios files? I mean that Where I can prepare ME firmware and How to send it into the bios files?
СообщениеДобавлено: 07 июл 2013, 12:37
Lab DC power supply to short circuit: 1V 2A (find hot elements) or try to find in scheme (+1.05V_VTT) by "brute force" (sorting one-by-one)
http://kythuatphancung.com/uploads/down ... INTEL-.pdf
В сети
СообщениеДобавлено: 07 июл 2013, 14:46
I do this before, without CPU , V=1V , current =0.28A there is no hot element, with CPU, V=1 current= 2.13A there is no hot element again!
I checked according to schematic, some route goes to CPU( I swapped CPU), some goes to Clock ( took it and test) and some goes to PCH ( changed IT before), mysterious!
---------- Добавлено спустя 1 час 3 минуты 20 секунд: ----------
does any one has Clean ME-region BIOS for this laptop? Nobody answered my question about creating ME-region Bios!
СообщениеДобавлено: 08 июл 2013, 15:32
RsM писал(а):
Can You be kind enough and Upload ME-Region Bios?
СообщениеДобавлено: 08 июл 2013, 21:22
I told you all yet. If you don't see - it is your problem. There isn't ME-region BIOS. Read carefully.
Think, try. Bye.
-приворот winDOвSa
-розыгрыш автоБАНа
СообщениеДобавлено: 09 июл 2013, 20:27
reball s-bridge or rework it
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell inspiron n5010 (DG15 MB 48.4HH01.011) Не включается.
в форуме Dell
Аверкеев
5315
17 окт 2014, 09:06
orbit Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Dell Inspiron N5010 (09909-1 DG15) чип 216-0729042 сильно греется,через 10 секунд отлючается
в форуме Dell
giorgi
5097
10 ноя 2014, 19:42
Silentredcat Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Dell N5010 (DG15) Нет реакции на кнопку
в форуме Dell
console-master
11 мар 2015, 12:21
pan-74 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. dell inspiron n5010 (09909-1 dg15-mb 48.4hh01.011) Охлаждение
в форуме Dell
peit
29 янв 2017, 17:58
apallon666 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. DELL INSPIRION N5010 (DG15) Артефакты
в форуме Dell
antares_87
19 май 2015, 13:36
antares_87 Перейти к последнему сообщению
Сейчас этот форум просматривают: Ivanches, Zluka, zmyslony53 и гости: 11
