Текущее время: 21 июн 2024, 09:41
 Заголовок сообщения: Acer Aspire V3-571G (LA-7912P) Not power on
СообщениеДобавлено: 23 апр 2014, 22:15
I have Acer Aspire V3-571G (LA-7912P) which is not functioning properly.
01. There is 3.3v and 5v present
02. No SUSP# and SYSON
When i pressed power button laptop power on for few seconds and turn off.
Since there is no SUSP#, I suspect there might be a problem in both ROMs U42 and U36.
Still I am not re program BIOS and could you please tell me which ROM chip i must re-program?
 Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) Not power on
СообщениеДобавлено: 24 апр 2014, 08:33
help me plz...anyone?
СообщениеДобавлено: 24 апр 2014, 22:19
I reprogrammed the BIOS but problem exist? any ideas?
СообщениеДобавлено: 24 апр 2014, 23:03
Заблокирован
plz :-) http://vlab.pp.ru/viewtopic.php?p=59795#p59795
In English:
0. When BIOS & EC-firmware 100% are working
1. When EC power is present, his quartz working and EC reading the bios data (look data exchange on BIOS chip an oscilloscope)
2. When ACIN = 3.3V
3. When LID_SW# = 3.3V
4. When EC drop RESET from SouthBridge, т.е. EC_RSMRST# = 3.3V
5. When by pressing of the power button the signal ON/OFFBTN# falls to zero and the same signal is broadcast in PBTN_OUT#
6. When from the SouthBridge signals PM_SLP_S3# and SLP_S5# are drop, i.e. voltage on them will be 3.3V
Under these conditions EC should give command for start.
СообщениеДобавлено: 25 апр 2014, 01:28
Что именно и в какие микросхемы вы программировали?
Там есть несколько вариантов.
Ремонт ноутбуков
Санкт-Петербург +79313406112
Ессентуки +79283151170
СообщениеДобавлено: 25 апр 2014, 12:27
In English:
2. When ACIN = 3.3V
Good point I checked some of these voltages but i missed few. I'll let you know the results.thnx
СообщениеДобавлено: 29 апр 2014, 16:01
BIOS and EC flashed but no success. I suspect EC is bad but i dont have the chip right now for testing.
СообщениеДобавлено: 30 апр 2014, 00:28
Озвучте напряжения на cpu в момент включения и сопротивление на шинах питания cpu и gpu.
Так может быть как при не исправном cpu и его цепей питания, так и при не исправном gpu.
В любом случае EC предпочитает отключить ноутбук.
Ремонт ноутбуков
 Заголовок сообщения: Re: Acer Aspire V3-571G (LA-7912P) Not power on  [РЕШЕНО]
СообщениеДобавлено: 07 дек 2014, 11:52
After I reballed the PCH SUSP# and SYSON signals are back and laptop turned on. I think dry contacts on PCH is the problem. I use this methode to repair dead laptops such as Acer V3,E1 , Dell 3521, HP 15n.
Thanks for helping me.
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. Acer Q5WV1 rev.2.0 (LA-7912P) does not light any LED panel, not power
eletmoraes
21 апр 2016, 11:32
andromedax Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. e1-571g (COMPAL LA-7912P - REV 02) Not charging
alifakhrniya
28 июл 2014, 15:21
alifakhrniya Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. V3-571G\E1-571G\PackardBell (LA-7912P) Через несколько секунд после подключения СЗУ к плате с установленной АК
FSergey
06 авг 2017, 02:27
В этой теме нет новых непрочитанных сообщений. ASER V3-571G (LA-7912P r 1) Нужна board view на LA-7912P r 1
masser
16 фев 2017, 08:57
masser Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Aspire V5-571g (Petra) Оperating system not found, нет реакции на F2 F 12
boasoft
16 фев 2016, 14:00
boasoft Перейти к последнему сообщению
Сейчас этот форум просматривают: i001546 и гости: 29
