Текущее время: 17 июн 2025, 12:11
 Заголовок сообщения: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing
СообщениеДобавлено: 18 окт 2014, 00:23
Hi everyone, this old laptop came to me with password [stringent security] issue and after swapping bios chip, password was removed and I found out the South-bridge needed re-balling [smart-card error issue]. After re-balling, laptop charging led blinks six times and then restarts. I want to know if anyone has encountered this issue and how it was solved. I suspect South-bridge but i want confirmation... :-):
 Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing
СообщениеДобавлено: 18 окт 2014, 10:22
Участник АСЦ
Участник АСЦ
6 Caps Lock/Num Lock BIOS BIOS authentication failure
booknot.ru тел (343)237-37-37
СообщениеДобавлено: 18 окт 2014, 12:50
Thanks for the reply but in this case it is the charging Indicator (orange led) that is blinking..
СообщениеДобавлено: 18 окт 2014, 13:06
Участник АСЦ
Участник АСЦ
I don't see what charging LED blinking, sorry.
charging LED blinking - problem with Power.
СообщениеДобавлено: 18 окт 2014, 19:55
I totally agree with you that it is a power issue because I just realized that there is no voltage on coil L29 [+VCCP] and L26 [+VCC_CORE], but everything was okay before the re-balling.All components around the South-bridge are okay. I will like to know if there are some signals I can check to verify whether the problem is from South-bridge or elsewhere.
 Заголовок сообщения: Re: HP NC6120 (Inventec Davos DF) Six LED blinks repeatedly after reballing  [РЕШЕНО]
СообщениеДобавлено: 25 окт 2014, 05:34
Hi everyone, after going through a lot of ordeal due to the client threatening me to either fix the motherboard or replace the laptop... :sh_ok:, i realised the problem was lack of PWR_GOOD_3 due to reduced output from Q34 [voltage drop from +V3s to +V2.1s], so replacing Q34 solved the issue... :ya_hoo_oo:
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP nx6310 (Inventec DAVOS 3.0) Не дружит с двумя ядрами CPU
infinity
28 янв 2016, 13:38
infinity Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. nx6310 (INVENTEC DAVOS 3.0.) высокий уровень ADP_EN#
roman05
10 июл 2016, 22:21
roman05 Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Asus G751J (G751JY rev 2.5) Not starting, led blinks
Djosla
19 авг 2017, 11:02
Djosla Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Pixus Play Six помогите опознать элемент
mishka007-84
15 сен 2015, 10:27
dastali Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP Compaq nc6120 (6050A0055001-A04) Гаснет экран при входе в Windows
georgiy91
12
1576
28 янв 2022, 16:32
georgiy91 Перейти к последнему сообщению
Сейчас этот форум просматривают: karval, nekromantred и гости: 5
