Заголовок сообщения: Dell Studio 1558 (Intel - DAFM9CMB8C0 - Rev : C) Abnormal Shutdown [РЕШЕНО]
Добавлено: 03 июл 2015, 13:51
Зарегистрирован: 12 май 2014, 21:17 Наличности на руках: 70.07 Сообщения: 50 Откуда: Iran
Hi everybody.
There is this notebook shutting down abnormally and randomly. After powering up, a couple of seconds later it shuts down. I suspected it was overheating but after cleaning the fan, it was still happening. So i decided to desolder EMC1422 (thermal shutdown IC) and everything is okay. tried with another IC and also changed CPU temperature sensor with no luck. without 1422 IC system is working OK but fan is constantly on. Any help will be appreciated.
Ivan
Заголовок сообщения: Re: Dell Studio 1558 (Intel - DAFM9CMB8C0 - Rev : C) Abnormal Shutdown
Добавлено: 03 июл 2015, 22:00
Зарегистрирован: 30 апр 2011, 11:57 Наличности на руках: 0.63 Сообщения: 32 Откуда: Moldova
Soldering back 1422 IC , flash a new BIOS and check with another cpu...
FRD
Добавлено: 04 июл 2015, 20:35
before desoldering 1422 I reflashed BIOS with no luck. Also has checked with another cpu. At first it takes a little longer (a minute or so) then starts to shut down randomly at shorter periods.
FRD
Добавлено: 05 июл 2015, 21:44
At last it turned out to be a GPU related problem. After reballing GPU everything is working flawlessly. somehow it had lowered fan speed and after that fan speed went to normal. as GPU was getting hot it was shutting down. Now it's OK.
Сейчас этот форум просматривают: Stanreed и гости: 25
