The Microcontroller is handing control of the system to the processor. This code will persist if there is no processor detected.
1. Reseating the processor. 2. Replacing the processor. 3. Replacing the system board.
The memory has encountered an error.
1. Reseating the memory. 2. Replacing the memory. 3. Replacing the system board.
A system board component is faulty.
The video card is preventing the system from completing POST.
1. Replacing the video card. 2. Replacing the system board.
The keyboard is preventing the system from completing POST.
1. Reseating the keyboard cable. 2. Replacing the keyboard. 3. Replacing the system board.
USB controller initialization.
1. Removing any USB devices. 2. Replacing the system board.
No SODIMM installed.
1. Installing the memory. 2. Reseating the memory. 3. Replacing the memory. 4. Replacing the system board.
Turning on the LCD panel (after video configuration).
1. Reseating the LCD cable. 2. Replacing the LCD panel. 3. Replacing the video card.
The modem is preventing the system from completing POST.
1. Reseating the modem. 2. Replacing the modem. 3. Replacing the system board.
В зависимости от расположения индикаторов , в разных моделях по годах выпуска - по разному оформлены Dell
на официальном сайте в PDF документации для каждой можели упоминается назначение индикаторов , но суть одинакова у всех
