Текущее время: 16 июн 2024, 05:13
 Заголовок сообщения: Aspire E1-571 (Q5WV1 LA-7912A) Many defective MosFET's
СообщениеДобавлено: 17 ноя 2016, 20:26
Hi to all of you,
I have a strage defective laptop mainboard.
It's an Acer Aspire E1-571
The board vendor: HannStar
Q5WV1 LA-7912A
Rev: 2.0
2012-08-24
The laptop sudden would not start anymore no respond and no LEDs whatsoever.
I discovered that the PSU was gone defective due to a short in the DC-Plug input, as the dc-plug and inside connector where okay I looked further thr circuit.
As I measure the input FET and Caps I soon saw that PQ9 was shorted what is comon whit these boards normaly due to shorted cap(s).
There are no brun components nor PCB tracks!
At the moment I gave up on trying to repair as I now discovered so many many FET's are shorted.
List of shorted FET's:
PQ9 AO4304 shematic page 47
Although PQ10 & PQ11 are just fine !
PQ29 FDMC7696 shematic page 50
PQ30 AO6504 shematic page 50
PQ35 FDMC7696 shematic page 52
PQ36 AO6504 shematic page 52
PQ37 FDMC7696 shematic page 52
PQ38 FDMC7696 shematic page 52
PQ39 AO6504 shematic page 52
PQ40 AO6504 shematic page 52
If I go any further with repairing I need to know at least what the heck is going on here and if one of you guys have experience similar defects like these?
Thanks in advance for your reaction!
Regards, Geert
 Заголовок сообщения: Re: Aspire E1-571 (Q5WV1 LA-7912A) Many defective MosFET's
СообщениеДобавлено: 17 ноя 2016, 21:29
How you check this MOSFETs?
Профессиональный ремонт ноутбуков и моноблоков в Екатеринбурге, т. 372-23-60
СообщениеДобавлено: 17 ноя 2016, 23:50
Source to Drain and Drain to Source.
I did not de-solder them just measure on PCB.
Regards, Geert
СообщениеДобавлено: 18 ноя 2016, 01:01
All of these mosfet are good, may be. You not correct check its.
СообщениеДобавлено: 26 ноя 2016, 20:35
@ Ewwwgeny
How can I not correct measure, even when I de-solder the fet's ????
All mosfets are tested off-board with a transitor/mosfet tester.
As I already menstion they are all defective.
Anyone have a clue what could happend with this mainboard, have any of you encounter similair issues?
Regards, Geert
СообщениеДобавлено: 26 ноя 2016, 21:19
Открытый мосфет будет прозваниваться тестером как пробитый. Если касаться щупом тестера ножки Gate, то в зависимости от контакта (+ или -) он будет открываться или закрываться и оставаться в этом положении до следующего прикосновения к Gate. Попробуйте разные комбинации и возможно вы получите другой результат, мосфеты перестанут быть пробитыми.
СообщениеДобавлено: 27 ноя 2016, 01:10
I have to use Google Translate:
Outdoor mosfet will prozvanivatsya tester as a punched. If Gate legs touch probe tester, depending on a contact (+ or -) it will open or close and to remain in this position until the next touch to Gate. Try different combinations and you may get a different result, mosfety cease to be punched.
I know that you short the GATE and SOURCE it opens the Source to Drain.
Here an example video(s) of this behavior, forward to timeline 2m20sec.
Here another one:
Regards, Geert
СообщениеДобавлено: 27 ноя 2016, 01:34
Ok.
But I never saw 10 bad mosfat in one motherboard in different circuits simultaneously.
Good luck!
В этой теме нет новых непрочитанных сообщений. Вместо Mosfet soic-8 установить mosfet в другом корпусе
MVV1983
07 окт 2023, 23:22
В этой теме нет новых непрочитанных сообщений. yota many крутится нолик
в форуме Мобильные модемы для сотовых сетей | Mobile modems for cellular networks
silver046sam
23 июл 2019, 20:19
silver046sam Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. Samsung (Many) Downloader
в форуме Samsung
Pasha_ZZZ
1297
04 мар 2022, 06:21
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. ACER ASPIRE E1-571 (Q5WV1 LA-7912P REV:2.0) Packard Bell to ACER
Vovan800
22 сен 2014, 05:59
Vovan800 Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. куплю материнку ACER ASPIRE E1-571 (Q5WV1 LA-7912P REV:2.0)
в форуме Куплю | Buy
vov4444vov
09 дек 2014, 09:30
vov4444vov Перейти к последнему сообщению
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 31
