I have a strage defective laptop mainboard. It's an Acer Aspire E1-571 The board vendor: HannStar Q5WV1 LA-7912A Rev: 2.0 2012-08-24
The laptop sudden would not start anymore no respond and no LEDs whatsoever. I discovered that the PSU was gone defective due to a short in the DC-Plug input, as the dc-plug and inside connector where okay I looked further thr circuit.
As I measure the input FET and Caps I soon saw that PQ9 was shorted what is comon whit these boards normaly due to shorted cap(s).
There are no brun components nor PCB tracks!
At the moment I gave up on trying to repair as I now discovered so many many FET's are shorted.
List of shorted FET's:
PQ9 AO4304 shematic page 47 Although PQ10 & PQ11 are just fine !
If I go any further with repairing I need to know at least what the heck is going on here and if one of you guys have experience similar defects like these?
Thanks in advance for your reaction!
_________________ Regards, Geert
Lex66
Заголовок сообщения: Re: Aspire E1-571 (Q5WV1 LA-7912A) Many defective MosFET's
All of these mosfet are good, may be. You not correct check its.
@ Ewwwgeny How can I not correct measure, even when I de-solder the fet's ????
All mosfets are tested off-board with a transitor/mosfet tester. As I already menstion they are all defective. Anyone have a clue what could happend with this mainboard, have any of you encounter similair issues?
Ewwwgeny
Добавлено: 26 ноя 2016, 21:19
Зарегистрирован: 08 июн 2016, 15:07 Наличности на руках: 1.00 Сообщения: 175 Откуда: Калининград
Открытый мосфет будет прозваниваться тестером как пробитый. Если касаться щупом тестера ножки Gate, то в зависимости от контакта (+ или -) он будет открываться или закрываться и оставаться в этом положении до следующего прикосновения к Gate. Попробуйте разные комбинации и возможно вы получите другой результат, мосфеты перестанут быть пробитыми.
G33RT
I have to use Google Translate: Outdoor mosfet will prozvanivatsya tester as a punched. If Gate legs touch probe tester, depending on a contact (+ or -) it will open or close and to remain in this position until the next touch to Gate. Try different combinations and you may get a different result, mosfety cease to be punched.
I know that you short the GATE and SOURCE it opens the Source to Drain.
Here an example video(s) of this behavior, forward to timeline 2m20sec.
Here another one:
Ewwwgeny
Добавлено: 27 ноя 2016, 01:34
Ok. But I never saw 10 bad mosfat in one motherboard in different circuits simultaneously. Good luck!
Сейчас этот форум просматривают: Geo1986 и гости: 19
