Текущее время: 21 ноя 2024, 23:13
 Страница 1 из 1 [ Сообщений: 24 ]
 Заголовок сообщения: HP elitebook 820 G3 (Bios) Need bios dump
СообщениеДобавлено: 10 мар 2017, 12:53
Hello
I messed up my bios on hp elitebook 820 G3
There are two bios chip I read mx25l12873f like Mx25l12805d and get bios dump that seems to be valid After changing some data and write back I get corrupted bios.
Do I have to read write booth bios chips because I edited only one?
Can someone upload dump for booth bios chip?
 Заголовок сообщения: Re: HP elitebook 820 G3 (Bios) Need bios dump
СообщениеДобавлено: 10 мар 2017, 13:11
niktele писал(а):
I messed up my bios
can you upload your dumps here
СообщениеДобавлено: 10 мар 2017, 13:16
Yes later today will upload dump that I read form one bios chip
sent from gsmsverige
СообщениеДобавлено: 10 мар 2017, 13:19
СообщениеДобавлено: 10 мар 2017, 13:41
how you reading bios chips ? via programmer ?
СообщениеДобавлено: 10 мар 2017, 13:57
Yes ch341a
СообщениеДобавлено: 10 мар 2017, 20:29
https://drive.google.com/file/d/0B1wDK6 ... p=drivesdk
СообщениеДобавлено: 10 мар 2017, 20:45
With an attached dump whether there is an image on the screen ?
СообщениеДобавлено: 10 мар 2017, 20:58
I get logo one time and after that only restart by itself and fan spinning fast.
Will try later today to read chip again and compare with dump and after that erase and write original dump.
Can be a problem this model have two bios chip?
СообщениеДобавлено: 10 мар 2017, 21:15
I'm uploaded new dumps on the google drive HERE
СообщениеДобавлено: 10 мар 2017, 21:36
Thanks will try as soon I get home from work
СообщениеДобавлено: 11 мар 2017, 08:45
niktele писал(а):
will try as soon
can you send feedback about result here
СообщениеДобавлено: 11 мар 2017, 11:11
The file don't work.
If someone have another please upload
Thanks
СообщениеДобавлено: 11 мар 2017, 11:21
you had tested three files ?
---------- Добавлено спустя 1 минуту 53 секунды: ----------
niktele писал(а):
ch341a
may be problem with programmer ?
СообщениеДобавлено: 11 мар 2017, 11:24
Yes and pc don't start with that files, if I look in hex view files are completely different.
Try to compare with my upload there are big differences.
СообщениеДобавлено: 11 мар 2017, 11:48
try this
СообщениеДобавлено: 11 мар 2017, 12:26
valohadjeday писал(а):
try this
On 0016DE10 are stored serial and on this dump are not on that address
СообщениеДобавлено: 11 мар 2017, 14:17
on 0x3000 - 0x6ffff0 is ME(Intel Management Engine Firmware) region ,
I've had replaced it on a clean ME (no data , no serial, no ID)
Последний раз редактировалось valohadjeday 11 мар 2017, 14:22, всего редактировалось 1 раз.
СообщениеДобавлено: 11 мар 2017, 14:19
I've had replaced it on the clean ME (no data , no serial, no ID)
Ok will try tonight when I come home
Thanks
СообщениеДобавлено: 11 мар 2017, 23:49
Work in progress (I damage one pin on the board need to fix that to)
СообщениеДобавлено: 12 мар 2017, 00:11
Write done successfully
СообщениеДобавлено: 12 мар 2017, 12:19
Bad news
After trying all files that I get no success.
As soon I put battery back power button start blinking rapidly and can even try posted power on the machine.
I try to change only one number in original dump and machine starts about 20 second and then begin to restart every 10 seconds without any picture on screen.
It's looks like there are some checksum test as soon I put the battery or need to flash another chip that are on the board mx25l64....
For now i quit because I destroyed some print on the board an make a bridge with wire so I wait till someone have original backup or make successful writing on another machine.
Thanks guy's for all help.
I'm not done still waiting for solution :-)
СообщениеДобавлено: 26 мар 2017, 13:41
Upload you dump and I will make file for flashing bios that can reset password
The file can't be used file from one to another machine right now I don't know right reason for that but important thing are that solution works
Tested on elitebook 820 G3
 Заголовок сообщения: Re: HP elitebook 820 G3 (Bios) Need bios dump  [РЕШЕНО]
СообщениеДобавлено: 26 апр 2017, 14:58
This file remove bios password on my machine
В этой теме нет новых непрочитанных сообщений. Bios dump elitebook 850 G1 (Bios dump elitebook 850 G1) Bios dump elitebook 850 G1
zenelli
26223
23 мар 2015, 23:14
zenelli Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP elitebook 820 G3 (HP elitebook 820 G3) (BIOS) Пароль BIOS
Mary_Iv12
13 май 2019, 13:14
Sergej Перейти к последнему сообщению
В этой теме нет новых непрочитанных сообщений. HP elitebook 820 G3 (HP elitebook 820 G3) пароль биоса
timik01
29 дек 2018, 21:44
В этой теме нет новых непрочитанных сообщений. HP Elitebook (2570p i3 16mb) I need Bios dump
nafienew
27 фев 2016, 23:04
nafienew Перейти к последнему сообщению
Эта тема закрыта, вы не можете редактировать и оставлять сообщения в ней. HP (Elitebook 1030 G1) Need dump file for bios
siwyqq
15 апр 2017, 15:15
siwyqq Перейти к последнему сообщению
Сейчас этот форум просматривают: amoralezzz, erikalov, PBF, Rimas, uran и гости: 72
