Текущее время: 06 ноя 2026, 00:55
| Автор |
serjick
Заголовок сообщения: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз  Добавлено: 03 июн 2017, 17:03 |
| Интересующийся |
Сообщения: 41 Откуда: Saratov
Всем ДВС! Изначально висел на лого. При попытке прошивки вставал на 5%. Заменил флеш. Прошивка прошла успешно. Теперь лого на 7 секунд и перезагруз. Встал на UART
UART
<hit enter to activate fiq debugger> ▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒▒[PWRAP] pwrap_init_preloader [PWRAP] pwrap_init [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5 [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5 [PMIC_WRAP]wrap_init pass,the return value=0. pl pmic init start pl pmic efuse start pl pmic efuse BUCK trim [0x1C8]=0xEC02 [0x1CA]=0x805F [0x20E]=0xB0 [0x260]=0xF0 [0x286]=0x70 pl pmic efuse end pl pmic en rst [0x126]=0x13 [0xE]=0x1 [0x540]=0xA0 Battery exist [0xE]=0x1 [0x540]=0xA0 pl vm read [0x290]=0x68 pl vm set [0x290]=0x6A pl vm check [0x290]=0x6A pl pmic init done [PLFM] Init I2C: OK(0) [PLFM] Init PWRAP: OK(0) [PLFM] Init PMIC: OK(0) [PLFM] chip[CA00]
[BLDR] Build Time: 20130820-174037 ==== Dump RGU Reg ======== RGU MODE: 34 RGU LENGTH: FFE0 RGU STA: 40000000 RGU INTERVAL: FFF RGU SWSYSRST: 0 ==== Dump RGU Reg End ==== RGU: g_rgu_satus:2 mtk_wdt_mode_config mode value=34, tmp:22000030 PL RGU RST: ?? SW reset with bypass power key flag Find bypass powerkey flag mtk_wdt_mode_config mode value=70, tmp:22000071 kpd register for pmic set! mt_usb_calibraion: input_reg = 0x0 mt_usb_calibraion: term_vref = 0x0, clkref = 0x0, vrt_vref = 0x0, [RTC] bbpu = 0xD, con = 0x406 [RTC] irqsta = 0x0, pdn1 = 0x1000, pdn2 = 0x201, spar0 = 0x40, spar1 = 0x800 [RTC] new_spare0 = 0x0, new_spare1 = 0x1, new_spare2 = 0x1, new_spare3 = 0x1 [RTC] bbpu = 0xD, con = 0x406 SW reset with bypass power key flag SW reset with bypass power key flag [PLFM] WDT reboot bypass power key! [RTC] rtc_bbpu_power_on done [EMI] enable_combo_dis:0,has_emmc_nand:0 [SD0] Bus Width: 1 [SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(193) DS(0) RS(0) [SD0] Switch to High-Speed mode! [SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(96) DS(0) RS(0) [SD0] Bus Width: 8 [SD0] Size: 7376 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15106048), ro(0) [SD0] Initialized [SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(0) DS(0) RS(0) msdc_ett_offline_to_pl: size<2> m_id<0x70> msdc <0> <HYNIX > <MMC08G> msdc <1> <xxxxxx> <MMC08G> msdc failed to find *******EMMC_INFO******* eMMC partition size(1 block = 512Bytes): BOOT1:<8192> blocks BOOT2:<8192> blocks RPMB :<8192> blocks GP1 :<0> blocks GP2 :<0> blocks GP3 :<0> blocks GP4 :<0> blocks USER :<15106048> blocks *******EMMC_INFO******* found:1,i:0 [EMI] DDR3 [EMI] eMMC/NAND ID = 70,1,0,4D,4D,43,30,38,47 [EMI] MDL number = 0 init ddr3 x32 Delay test rank 0 coarse = 12 rank 0 fine = 40 10:| 0 1 1 1 0 0 opt_dle value:7 byte:0, (DQS,DQ)=(8,A) byte:1, (DQS,DQ)=(8,B) byte:2, (DQS,DQ)=(8,A) byte:3, (DQS,DQ)=(8,B) [EMI] DRAMC calibration passed
[MEM] complex R/W mem test pass ▒▒▒▒▒▒▒▒▒▒▒============func=load_pt_from_fixed_addr===scan pmt from 700000===== find pt at 700000 next pt 0 64bit parse PMT find pt part PRELOADER size 0000000000000000 0000000000600000 part MBR size 0000000000600000 0000000000080000 part EBR1 size 0000000000680000 0000000000080000 part __NODL_PMT size 0000000000700000 0000000000400000 part __NODL_PRO_INFO size 0000000000B00000 0000000000300000 part __NODL_NVRAM size 0000000000E00000 0000000000500000 part __NODL_PROTECT_F size 0000000001300000 0000000000A00000 part __NODL_PROTECT_S size 0000000001D00000 0000000000A00000 part __NODL_SECCFG size 0000000002700000 0000000000020000 part UBOOT size 0000000002720000 0000000000060000 part BOOTIMG size 0000000002780000 0000000000600000 part RECOVERY size 0000000002D80000 0000000000600000 part SEC_RO size 0000000003380000 0000000000600000 part __NODL_MISC size 0000000003980000 0000000000080000 part LOGO size 0000000003A00000 0000000000300000 part EBR2 size 0000000003D00000 0000000000080000 part __NODL_EXPDB size 0000000003D80000 0000000000A00000 part ANDROID size 0000000004780000 0000000028A00000 part CACHE size 000000002D180000 0000000007E00000 part USRDATA size 0000000034F80000 00000000A0000000 part __NODL_FAT size 00000000D4F80000 00000000F7780000
[PART] blksz: 512B [PART] [0x0000000000000000-0x00000000005FFFFF] "PRELOADER" (12288 blocks) [PART] [0x0000000000600000-0x000000000067FFFF] "MBR" (1024 blocks) [PART] [0x0000000000680000-0x00000000006FFFFF] "EBR1" (1024 blocks) [PART] [0x0000000000700000-0x0000000000AFFFFF] "PMT" (8192 blocks) [PART] [0x0000000000B00000-0x0000000000DFFFFF] "PRO_INFO" (6144 blocks) [PART] [0x0000000000E00000-0x00000000012FFFFF] "NVRAM" (10240 blocks) [PART] [0x0000000001300000-0x0000000001CFFFFF] "PROTECT_F" (20480 blocks) [PART] [0x0000000001D00000-0x00000000026FFFFF] "PROTECT_S" (20480 blocks) [PART] [0x0000000002700000-0x000000000271FFFF] "SECURE" (256 blocks) [PART] [0x0000000002720000-0x000000000277FFFF] "UBOOT" (768 blocks) [PART] [0x0000000002780000-0x0000000002D7FFFF] "BOOTIMG" (12288 blocks) [PART] [0x0000000002D80000-0x000000000337FFFF] "RECOVERY" (12288 blocks) [PART] [0x0000000003380000-0x000000000397FFFF] "SECSTATIC" (12288 blocks) [PART] [0x0000000003980000-0x00000000039FFFFF] "MISC" (1024 blocks) [PART] [0x0000000003A00000-0x0000000003CFFFFF] "LOGO" (6144 blocks) [PART] [0x0000000003D00000-0x0000000003D7FFFF] "EBR2" (1024 blocks) [PART] [0x0000000003D80000-0x000000000477FFFF] "EXPDB" (20480 blocks) [PART] [0x0000000004780000-0x000000002D17FFFF] "ANDSYSIMG" (1331200 blocks) [PART] [0x000000002D180000-0x0000000034F7FFFF] "CACHE" (258048 blocks) [PART] [0x0000000034F80000-0x000001FFD4F7FFFF] "USER" (-3145728 blocks) [PART] [0x000001FFD4F80000-0x000001FFD4F7FFFF] "FAT" (0 blocks) [ROM_INFO] 'v2','0x2700000','0x20000','0x3380000','0x2C00' [SEC_K] SML KEY AC = 0 [SEC_K] SBC_PUBK Found [SEC] AES Legacy : 0 [SEC] SECCFG AC : 1
[SEC] read '0x2700000' 0x41,0x4E,0x44,0x5F,0x53,0x45,0x43,0x43,
[LIB] SecLib.a '20121226-155014' [LIB] CFG read size '0x4000' '0x1860' [LIB] Name = [LIB] Config = 0x22, 0x22 0x31,0x41,0x35,0x35 [platform_vusb_on] PASS
[TOOL] <UART> wait sync time 150ms->131ms [TOOL] <UART> receieved data: () [PART] Image with part header [PART] name : LK [PART] addr : FFFFFFFFh [PART] size : 239992 [PART] magic: 58881688h
[PART] load "UBOOT" from 0x0000000002720200 (dev) to 0x81E00000 (mem) [SUCCESS] [PART] load speed: 15624KB/s, 239992 bytes, 15ms [SECRO] Don't read [AUTHEN] rsa.N length = 1024 bytes [AUTHEN] rsa.E length = 20 bytes [LIB] NS-CHIP [LIB] Don't check
Device APC domain init setup:
[PLFM] ram_console->start=0x23A [PLFM] ram_console(0x2)=0x2 (boot reason) 0:dram_rank_size:40000000
[PLFM] boot reason: 4 [PLFM] boot mode: 0 [PLFM] META COM0: 0 [PLFM] <0x800A0008>: 0x0 [PLFM] boot time: 403ms
[BLDR] jump to 0x81E00000 [BLDR] <0x81E00000>=0xEA000007 [BLDR] <0x81E00004>=0xEA006369 [PROFILE] ------- i2c init takes 0 ms -------- mtk_wdt_mode LK config mode value=71 mtk_wdt_mode_config LK mode value=30, tmp:22000030 UB wdt init mtk_wdt_mode LK config mode value=30 mtk_wdt_mode_config LK mode value=79, tmp:22000079 [LEDS]LK: leds_init: mt65xx_backlight_off [LEDS]LK: mt65xx_backlight_off [LEDS]LK: lcd-backlight level is 0 [DDP] disp_bls_set_backlight: 0, PWM div 36 [PROFILE] ------- led init takes 2 ms -------- [LEDS]LK: isink_init: turn on PMIC6320 isink DISP/disp common log enabled DISP/lcd log enabled DISP_Init, 599 DISP/DISP_Init, 603 DISP/DISP_Init, 608 DISP/DISP_Init, 614 DISP/DISP_Init, 637 [DDP]disp_path_config(), srcModule=2, addr=0x0, inFormat=0, pitch=0, bgROI(0,0,1024,768), bgColor=0, outFormat=0, dstModule=13, dstAddr=0x0, DISI_MODULE_DPI0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 ASSERT error ASSERT error ASSERT error ASSERT error RDMA: w=1024, h=768, pitch=3072, mode=0 ASSERT error [DSS]===== DISP OVL Reg Dump: ============ [DSS](000)OVL_STA =0x1e [DSS](004)OVL_INTEN =0xf [DSS](008)OVL_INTSTA =0x0 [DSS](00C)OVL_EN =0x1 [DSS](010)OVL_TRIG =0x0 [DSS](014)OVL_RST =0x0 [DSS](020)OVL_ROI_SIZE =0x3000400 [DSS](024)OVL_DATAPATH_CON =0x0 [DSS](028)OVL_ROI_BGCLR =0x0 [DSS](02C)OVL_SRC_CON =0x4 [DSS](030)OVL_L0_CON =0xff [DSS](034)OVL_L0_SRCKEY =0x0 [DSS](038)OVL_L0_SRC_SIZE =0x0 [DSS](03C)OVL_L0_OFFSET =0x0 [DSS](040)OVL_L0_ADDR =0x0 [DSS](044)OVL_L0_PITCH =0x0 [DSS](0C0)OVL_RDMA0_CTRL =0x3ff0000 [DSS](0C4)OVL_RDMA0_MEM_START_TRIG =0x0 [DSS](0C8)OVL_RDMA0_MEM_GMC_SETTING =0x10101010 [DSS](0CC)OVL_RDMA0_MEM_SLOW_CON =0x0 [DSS](0D0)OVL_RDMA0_FIFO_CTRL =0x1000000 [DSS](050)OVL_L1_CON =0xff [DSS](054)OVL_L1_SRCKEY =0x0 [DSS](058)OVL_L1_SRC_SIZE =0x0 [DSS](05C)OVL_L1_OFFSET =0x0 [DSS](060)OVL_L1_ADDR =0x0 [DSS](064)OVL_L1_PITCH =0x0 [DSS](0E0)OVL_RDMA1_CTRL =0x3ff0000 [DSS](0E4)OVL_RDMA1_MEM_START_TRIG =0x0 [DSS](0E8)OVL_RDMA1_MEM_GMC_SETTING =0x10101010 [DSS](0EC)OVL_RDMA1_MEM_SLOW_CON =0x0 [DSS](0F0)OVL_RDMA1_FIFO_CTRL =0x1000000 [DSS](070)OVL_L2_CON =0x1000 [DSS](074)OVL_L2_SRCKEY =0xff [DSS](078)OVL_L2_SRC_SIZE =0x3000400 [DSS](07C)OVL_L2_OFFSET =0x0 [DSS](080)OVL_L2_ADDR =0xbf800000 [DSS](084)OVL_L2_PITCH =0x800 [DSS](100)OVL_RDMA2_CTRL =0x3ff0001 [DSS](104)OVL_RDMA2_MEM_START_TRIG =0x0 [DSS](108)OVL_RDMA2_MEM_GMC_SETTING =0x10101010 [DSS](10C)OVL_RDMA2_MEM_SLOW_CON =0x0 [DSS](110)OVL_RDMA2_FIFO_CTRL =0x1000000 [DSS](090)OVL_L3_CON =0xff [DSS](094)OVL_L3_SRCKEY =0x0 [DSS](098)OVL_L3_SRC_SIZE =0x0 [DSS](09C)OVL_L3_OFFSET =0x0 [DSS](0A0)OVL_L3_ADDR =0x0 [DSS](0A4)OVL_L3_PITCH =0x0 [DSS](120)OVL_RDMA3_CTRL =0x3ff0000 [DSS](124)OVL_RDMA3_MEM_START_TRIG =0x0 [DSS](128)OVL_RDMA3_MEM_GMC_SETTING =0x10101010 [DSS](12C)OVL_RDMA3_MEM_SLOW_CON =0x0 [DSS](130)OVL_RDMA3_FIFO_CTRL =0x1000000 [DSS](1C4)OVL_DEBUG_MON_SEL =0x1800000 [DSS](1C4)OVL_RDMA0_MEM_GMC_SETTING2 =0x1800000 [DSS](1C8)OVL_RDMA1_MEM_GMC_SETTING2 =0x180 [DSS](1CC)OVL_RDMA2_MEM_GMC_SETTING2 =0x0 [DSS](1D0)OVL_RDMA3_MEM_GMC_SETTING2 =0x0 [DSS](240)OVL_FLOW_CTRL_DBG =0xf8c02 [DSS](244)OVL_ADDCON_DBG =0x0 [DSS](248)OVL_OUTMUX_DBG =0x0 [DSS](24C)OVL_RDMA0_DBG =0x10000001 [DSS](250)OVL_RDMA1_DBG =0x10000001 [DSS](254)OVL_RDMA2_DBG =0x10000001 [DSS](258)OVL_RDMA3_DBG =0x10000001 [DSS]===== DISP WDMA1 Reg Dump: ============ [DSS](000)WDMA_INTEN =0x0 [DSS](004)WDMA_INTSTA =0x0 [DSS](008)WDMA_EN =0x0 [DSS](00C)WDMA_RST =0x0 [DSS](010)WDMA_SMI_CON =0x3 [DSS](014)WDMA_CFG =0x0 [DSS](018)WDMA_SRC_SIZE =0x0 [DSS](01C)WDMA_CLIP_SIZE =0x0 [DSS](020)WDMA_CLIP_COORD =0x0 [DSS](024)WDMA_DST_ADDR =0x0 [DSS](028)WDMA_DST_W_IN_BYTE =0x0 [DSS](02C)WDMA_ALPHA =0xff [DSS](030)WDMA_BUF_ADDR =0x0 [DSS](034)WDMA_STA =0x1 [DSS](038)WDMA_BUF_CON1 =0x1000ff [DSS](03C)WDMA_BUF_CON2 =0x10101010 [DSS](040)WDMA_C00 =0x0 [DSS](044)WDMA_C02 =0x0 [DSS](048)WDMA_C10 =0x0 [DSS](04C)WDMA_C12 =0x0 [DSS](050)WDMA_C20 =0x0 [DSS](054)WDMA_C22 =0x0 [DSS](058)WDMA_PRE_ADD0 =0x0 [DSS](05C)WDMA_PRE_ADD2 =0x0 [DSS](060)WDMA_POST_ADD0 =0x0 [DSS](064)WDMA_POST_ADD2 =0x0 [DSS](070)WDMA_DST_U_ADDR =0x0 [DSS](074)WDMA_DST_V_ADDR =0x0 [DSS](078)WDMA_DST_UV_PITCH =0x0 [DSS](090)WDMA_DITHER_CON =0x0 [DSS](0A0)WDMA_FLOW_CTRL_DBG =0x1 [DSS](0A4)WDMA_EXEC_DBG =0x0 [DSS](0A8)WDMA_CLIP_DBG =0x0 [DSS]===== DISP RDMA0 Reg Dump: ======== [DSS](000)RDMA_INT_ENABLE =0x0 [DSS](004)RDMA_INT_STATUS =0x0 [DSS](010)RDMA_GLOBAL_CON =0x101 [DSS](014)RDMA_SIZE_CON_0 =0x400 [DSS](018)RDMA_SIZE_CON_1 =0x300 [DSS](024)RDMA_MEM_CON =0x80 [DSS](028)RDMA_MEM_START_ADDR =0x0 [DSS](02C)RDMA_MEM_SRC_PITCH =0x0 [DSS](030)RDMA_MEM_GMC_SETTING_0 =0x10101010 [DSS](034)RDMA_MEM_SLOW_CON =0x0 [DSS](030)RDMA_MEM_GMC_SETTING_1 =0x20 [DSS](040)RDMA_FIFO_CON =0x80f00008 [DSS](054)RDMA_CF_00 =0x0 [DSS](058)RDMA_CF_01 =0x0 [DSS](05C)RDMA_CF_02 =0x0 [DSS](060)RDMA_CF_10 =0x0 [DSS](064)RDMA_CF_11 =0x0 [DSS](068)RDMA_CF_12 =0x0 [DSS](06C)RDMA_CF_20 =0x0 [DSS](070)RDMA_CF_21 =0x0 [DSS](074)RDMA_CF_22 =0x0 [DSS](078)RDMA_CF_PRE_ADD0 =0x0 [DSS](07C)RDMA_CF_PRE_ADD1 =0x0 [DSS](080)RDMA_CF_PRE_ADD2 =0x0 [DSS](084)RDMA_CF_POST_ADD0 =0x0 [DSS](088)RDMA_CF_POST_ADD1 =0x0 [DSS](08C)RDMA_CF_POST_ADD2 =0x0 [DSS](090)RDMA_DUMMY =0xfff00000 [DSS](094)RDMA_DEBUG_OUT_SEL =0x0 [DSS](0x020)CFG_SCL_MOUT_EN =0x0 [DSS](0x024)CFG_OVL_MOUT_EN =0x2 [DSS](0x028)CFG_COLOR_MOUT_EN =0x0 [DSS](0x02C)CFG_TDSHP_MOUT_EN =0x0 [DSS](0x030)CFG_MOUT_RST =0x0 [DSS](0x034)CFG_RDMA0_OUT_SEL =0x2 [DSS](0x038)CFG_RDMA1_OUT_SEL =0x0 [DSS](0x03C)CFG_OVL_PQ_OUT_SEL =0x0 [DSS](0x040)CFG_WDMA0_SEL =0x0 [DSS](0x044)CFG_OVL_SEL =0x0 [DSS](0x048)CFG_OVL_PQ_IN_SEL =0x0 [DSS](0x04C)CFG_COLOR_SEL =0x0 [DSS](0x050)CFG_TDSHP_SEL =0x0 [DSS](0x054)CFG_BLS_SEL =0x0 [DSS](0x058)CFG_DBI_SEL =0x0 [DSS](0x05C)CFG_DPI0_SEL =0x0 [DSS](0x60))CFG_MISC =0x0 [DSS](0x70))CFG_PATH_DEBUG0 =0x0 [DSS](0x74))CFG_PATH_DEBUG1 =0x0 [DSS](0x78))CFG_PATH_DEBUG2 =0x600013 [DSS](0x7C))CFG_PATH_DEBUG3 =0x0 [DSS](0x80))CFG_PATH_DEBUG4 =0x0 [DSS](0x100)CFG_CG_CON0 =0xffff1ecc [DSS](0x104)CFG_CG_SET0 =0x0 [DSS](0x108)CFG_CG_CLR0 =0x0 [DSS](0x110)CFG_CG_CON1 =0xfffffcf8 [DSS](0x114)CFG_CG_SET1 =0x0 [DSS](0x118)CFG_CG_CLR1 =0x0 [DSS](0x120)CFG_HW_DCM_EN0 =0x0 [DSS](0x124)CFG_HW_DCM_EN_SET0 =0x0 [DSS](0x128)CFG_HW_DCM_EN_CLR0 =0x0 [DSS](0x130)CFG_HW_DCM_EN1 =0x0 [DSS](0x134)CFG_HW_DCM_EN_SET1 =0x0 [DSS](0x138)CFG_HW_DCM_EN_CLR1 =0x0 [DSS](0x800)CFG_MBIST_DONE0 =0x0 [DSS](0x804)CFG_MBIST_DONE1 =0x0 [DSS](0x808)CFG_MBIST_FAIL0 =0x0 [DSS](0x80C)CFG_MBIST_FAIL1 =0x3ffff [DSS](0x810)CFG_MBIST_FAIL2 =0x0 [DSS](0x814)CFG_MBIST_HOLDB0 =0xffffffff [DSS](0x818)CFG_MBIST_HOLDB1 =0xffffffff [DSS](0x81C)CFG_MBIST_MODE0 =0xff [DSS](0x820)CFG_MBIST_MODE1 =0x55aa0000 [DSS](0x824)CFG_MBIST_BSEL0 =0x0 [DSS](0x828)CFG_MBIST_BSEL1 =0x0 [DSS](0x82C)CFG_MBIST_BSEL2 =0x0 [DSS](0x830)CFG_MBIST_BSEL3 =0x5aaaa50a [DSS](0x834)CFG_MBIST_CON =0x5555aaa5 [DSS](0x870)CFG_DEBUG_OUT_SEL =0x0 [DSS](0x874)CFG_TEST_CLK_SEL =0x0 [DSS](0x880)CFG_DUMMY =0x0 [DSS]((0x0) CFG_MUTEX_INTEN =0x1 [DSS]((0x4) CFG_MUTEX_INTSTA =0x0 [DSS]((0x8) CFG_REG_UPD_TIMEOUT=0xff [DSS]((0xC) CFG_REG_COMMIT =0x0 [DSS](0x20)CFG_MUTEX_EN(0) =0x0 [DSS](0x24)CFG_MUTEX(0) =0x3 [DSS](0x28)CFG_MUTEX_RST(0) =0x0 [DSS](0x2c)CFG_MUTEX_MOD(0) =0x84 [DSS](0x30)CFG_MUTEX_SOF(0) =0x2 [DSS](0x40)CFG_MUTEX_EN(1) =0x0 [DSS](0x44)CFG_MUTEX(1) =0x0 [DSS](0x48)CFG_MUTEX_RST(1) =0x0 [DSS](0x4c)CFG_MUTEX_MOD(1) =0x0 [DSS](0x50)CFG_MUTEX_SOF(1) =0x0 [DSS](0x60)CFG_MUTEX_EN(2) =0x0 [DSS](0x64)CFG_MUTEX(2) =0x0 [DSS](0x68)CFG_MUTEX_RST(2) =0x0 [DSS](0x6c)CFG_MUTEX_MOD(2) =0x0 [DSS](0x70)CFG_MUTEX_SOF(2) =0x0 [DSS](0x80)CFG_MUTEX_EN(3) =0x0 [DSS](0x84)CFG_MUTEX(3) =0x0 [DSS](0x88)CFG_MUTEX_RST(3) =0x0 [DSS](0x8c)CFG_MUTEX_MOD(3) =0x0 [DSS](0x90)CFG_MUTEX_SOF(3) =0x0 [DSS](0xa0)CFG_MUTEX_EN(4) =0x0 [DSS](0xa4)CFG_MUTEX(4) =0x0 [DSS](0xa8)CFG_MUTEX_RST(4) =0x0 [DSS](0xac)CFG_MUTEX_MOD(4) =0x0 [DSS](0xb0)CFG_MUTEX_SOF(4) =0x0 disp_bls_config : PWM config data (0,0) [DDP] disp_bls_config : gBLSMutexID = 3 DISP/DPI_Set_DrivingCurrent not implement for 6575[DISP] - uboot - DSI_PowerOn. 0x 0,0x 0,0x 0 [DISP] - uboot - DSI_PowerOff. 0x 0,0x 0,0x 0 DISP/DISP_Init, 642 DISP/DISP_Init, 657 [PROFILE] ------- disp init takes 276 ms --------
[LK_pmic6329_init] Start................... [LK_PMIC_INIT] PMIC CID=0x2020 [LK_PMIC_INIT] Turn Off chrind [LK_PMIC_INIT_SETTING_V1] PMIC Chip = 2020 [LK_PMIC_INIT_SETTING_V1] 20121220 (>=2) [LK_PMIC_INIT_SETTING_V1] Done [LK_PMIC_INIT_SETTING_V1] [LK_PMIC_CUSTOM_SETTING_V1] Done [PROFILE] ------- pmic6329_init takes 4 ms -------- [PROFILE] ------- platform_early_init takes 496 ms -------- [mmc_legacy_init]: start [mmc_legacy_init]: start mmc_init_host [msdc_init]: start [SD0] Bus Width: 1 [SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(0) DDR(0) DIV(193) DS(0) RS(0) [msdc_init]: finish succesfully [mmc_legacy_init]: start mmc_init_card [mmc_init_card]: start [SD0] Switch to High-Speed mode! [SD0] SET_CLK(260kHz): SCLK(259kHz) MODE(2) DDR(1) DIV(96) DS(0) RS(0) [SD0] Bus Width: 8 [SD0] Size: 7376 MB, Max.Speed: 52000 kHz, blklen(512), nblks(15106048), ro(0) [SD0] Initialized [SD0] SET_CLK(52000kHz): SCLK(50000kHz) MODE(2) DDR(1) DIV(0) DS(0) RS(0) [mmc_init_card]: finish successfully addr_trans_init addr_trans_init done [mt_part_register_device] [mt_part_register_device]malloc 1024 : 81e59508 mt6577_part_init_pmt ============func=load_pt_from_fixed_addr===scan pmt from 700000===== find pt at 700000 next pt 0 64bit parse PMT, size pt = 88 Find pt partition PRELOADER size 0000000000000000 0000000000600000 partition MBR size 0000000000600000 0000000000080000 partition EBR1 size 0000000000680000 0000000000080000 partition __NODL_PMT size 0000000000700000 0000000000400000 partition __NODL_PRO_INFO size 0000000000b00000 0000000000300000 partition __NODL_NVRAM size 0000000000e00000 0000000000500000 partition __NODL_PROTECT_F size 0000000001300000 0000000000a00000 partition __NODL_PROTECT_S size 0000000001d00000 0000000000a00000 partition __NODL_SECCFG size 0000000002700000 0000000000020000 partition UBOOT size 0000000002720000 0000000000060000 partition BOOTIMG size 0000000002780000 0000000000600000 partition RECOVERY size 0000000002d80000 0000000000600000 partition SEC_RO size 0000000003380000 0000000000600000 partition __NODL_MISC size 0000000003980000 0000000000080000 partition LOGO size 0000000003a00000 0000000000300000 partition EBR2 size 0000000003d00000 0000000000080000 partition __NODL_EXPDB size 0000000003d80000 0000000000a00000 partition ANDROID size 0000000004780000 0000000028a00000 partition CACHE size 000000002d180000 0000000007e00000 partition USRDATA size 0000000034f80000 00000000a0000000 partition __NODL_FAT size 00000000d4f80000 00000000f7780000 [SD0] boot device found [PROFILE] ------- NAND/EMMC init takes 101 ms -------- [mt_part_get_partition] MISC [mt_part_get_partition] 1cc00 [LK_ENV]ENV SIG Wrong [LK_ENV]no valid env [PROFILE] ------- ENV init takes 3 ms -------- [mt_part_get_partition] LOGO [mt_part_get_partition] 1d000 [mt_part_get_partition] LOGO [mt_part_get_partition] 1d000
========================================= [LK_BOOT] LOGO magic number : 0x58881688 [LK_BOOT] LOGO name : LOGO [LK_BOOT] LOGO size : 1093915 ========================================= read the data of LOGO [AUXADC] u4Sample_times=1, ret_data=786, u4channel[0]=786. [AUXADC] u4Sample_times=2, ret_data=786, u4channel[0]=1572. [AUXADC] u4Sample_times=3, ret_data=786, u4channel[0]=2358. [AUXADC] u4Sample_times=4, ret_data=786, u4channel[0]=3144. [AUXADC] u4Sample_times=5, ret_data=786, u4channel[0]=3930. [AUXADC] adc_result_temp=786, adc_result=3684, r_val_temp=4. bq24196_chrg_status = 0 is_low_battery, FALSE DISP/panel is enabled [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbf800000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbf800000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 [wwy] hardware address = bfc80000, fb_offset_logo = 3 [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbfc80000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbfc80000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 [PROFILE] ------- load_logo takes 249 ms -------- kpd read addr: 0x0502: data:0x41fc kpd register for pmic set! [AUXADC] u4Sample_times=1, ret_data=787, u4channel[0]=787. [AUXADC] u4Sample_times=2, ret_data=787, u4channel[0]=1574. [AUXADC] u4Sample_times=3, ret_data=787, u4channel[0]=2361. [AUXADC] u4Sample_times=4, ret_data=787, u4channel[0]=3148. [AUXADC] u4Sample_times=5, ret_data=787, u4channel[0]=3935. [AUXADC] adc_result_temp=787, adc_result=3689, r_val_temp=4. bq24196_chrg_status = 0 is_low_battery, FALSE [LEDS]LK: mt65xx_backlight_on [LEDS]LK: lcd-backlight level is 255 [DDP] disp_bls_set_backlight: 255, PWM div 36 [PROFILE] ------- backlight takes 7 ms --------
[FACTORY] Check factory boot [FACTORY] Wait 50ms for special keys detecting pmic just reset
[RECOVERY] Check recovery boot [RECOVERY] Wait 50ms for special keys detecting pmic just reset [mboot_recovery_load_misc]: size is 6144 [mboot_recovery_load_misc]: misc_addr is 0x81e5d920 [mt_part_get_partition] MISC [mt_part_get_partition] 1cc00 [LK_BOOT] Load 'MISC' partition to 0x81E5D920 (6144 bytes in 1 ms) [pmic_detect_powerkey] Release WDT get boot reason is 4 from pre-loader [is_force_boot] Bypass Kernel Power off charging mode and enter Normal Boot [kernel_power_off_charging_detection] Turn off HW Led < Kernel Enter Normal Boot > [PROFILE] ------- boot mode select takes 155 ms -------- [partition_get_index]find preloader PRELOADER index 0 [partition_get_index]find seccfg SECURE index 8 [mt_part_get_partition] SECURE [mt_part_get_partition] 13800 [partition_get_index]find sec_ro SECSTATIC index 12 [mt_part_get_partition] SECSTATIC [mt_part_get_partition] 19c00 [partition_get_index]find seccfg SECURE index 8 [partition_get_index]find sec_ro SECSTATIC index 12 [partition_get_index]find sec_ro SECSTATIC index 12 [SEC_SRO] Search SECRO - HASH is not corrected [SEC_INIT] Search SECRO - SW sec boot not enabled [AUXADC] u4Sample_times=1, ret_data=761, u4channel[0]=761. [AUXADC] u4Sample_times=2, ret_data=761, u4channel[0]=1522. [AUXADC] u4Sample_times=3, ret_data=761, u4channel[0]=2283. [AUXADC] u4Sample_times=4, ret_data=762, u4channel[0]=3045. [AUXADC] u4Sample_times=5, ret_data=762, u4channel[0]=3807. [AUXADC] adc_result_temp=761, adc_result=3567, r_val_temp=4. g_boot_mode = 0 check VBAT=3567 mV with 3450 mV [bq24196_dump_register] Reg[0x0]=0x37 [bq24196_dump_register] Reg[0x1]=0xB [bq24196_dump_register] Reg[0x2]=0x60 [bq24196_dump_register] Reg[0x3]=0x11 [bq24196_dump_register] Reg[0x4]=0xB2 [bq24196_dump_register] Reg[0x5]=0x9A [bq24196_dump_register] Reg[0x6]=0x3 [bq24196_dump_register] Reg[0x7]=0x4B [bq24196_dump_register] Reg[0x8]=0x0 [bq24196_dump_register] Reg[0x9]=0x80 [bq24196_dump_register] Reg[0xA]=0x2B [PROFILE] ------- battery init takes 11 ms -------- show_logo, in_addr=0xbf4000a4, fb_addr=0xbf800000, logolen=89267, ticks=1470 ticks=1536 [wwy] hardware address = bf800000, fb_offset_logo = 0 [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbf800000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 [PROFILE] ------- show logo takes 74 ms -------- [PROFILE] ------- sw_env takes 0 ms -------- [PROFILE] ------- platform_init takes 619 ms -------- [partition_get_index]find preloader PRELOADER index 0 [partition_get_index]find seccfg SECURE index 8 [mt_part_get_partition] SECURE [mt_part_get_partition] 13800 [partition_get_index]find sec_ro SECSTATIC index 12 [mt_part_get_partition] SECSTATIC [mt_part_get_partition] 19c00 [partition_get_index]find seccfg SECURE index 8 [partition_get_index]find sec_ro SECSTATIC index 12 [partition_get_index]find sec_ro SECSTATIC index 12 [SEC_SRO] Search SECRO - HASH is not corrected [SEC_INIT] Search SECRO - SW sec boot not enabled [LIB] NS-CHIP [LIB] Don't check [mt_part_get_partition] BOOTIMG [mt_part_get_partition] 13c00 [mt_part_get_partition] BOOTIMG [mt_part_get_partition] 13c00 part page addr is 0xd
============================================================ [LK_BOOT] Android Partition Name : BOOTIMG [LK_BOOT] Android Boot IMG Hdr - Magic : ANDROID [LK_BOOT] Android Boot IMG Hdr - Kernel Size : 0x40bac0 [LK_BOOT] Android Boot IMG Hdr - Rootfs Size : 0x9b0b5 [LK_BOOT] Android Boot IMG Hdr - Page Size : 0x800 ============================================================ > page count of kernel image = 2072 > kernel mem offset = 0x80008000 > rootfs mem offset = 0x80414000 > boot image size = 0x4a8800 [mt_part_get_partition] BOOTIMG [mt_part_get_partition] 13c00
read the data of BOOTIMG (size = 0x4a8800) > from - 0x0000000002780800 (skip boot img hdr) > to - 0x80007e00 (starts with kernel img hdr)
========================================= [LK_BOOT] KERNEL magic number : 0x58881688 [LK_BOOT] KERNEL name : KERNEL [LK_BOOT] KERNEL size : 0x40b8c0 =========================================
========================================= [LK_BOOT] ROOTFS magic number : 0x58881688 [LK_BOOT] ROOTFS name : ROOTFS [LK_BOOT] ROOTFS size : 0x9aeb5 ========================================= [PROFILE] ------- load boot.img takes 81 ms -------- [LK]DISP_GetPages: disp_fb_pages=2! DISP/[Func]LCD_ConfigOVL disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=2, source=0, fmt=1, addr=0xbf800000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=0, key=0, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 disp_path_config_layer, 48 [DDP]disp_path_config_layer(), layer=3, source=0, fmt=1, addr=0xbf980000, x=0, y=0 w=1024, h=768, pitch=2048, keyEn=1, key=-16777216, aen=0, alpha=0 ASSERT error OVLLayerSwitch,89 ASSERT error OVLLayerConfig,161 lcd one 21151 [wwy] mt_disp_adjusting_hardware_addr fb_offset_logo = 3 SSSS:0x808610c4 SSSS:0x0 SSSS:0x0 SSSS:0x80 [PROFILE] ------- boot_time takes 1265 ms -------- [LK_ENV]get_env hibboot [LK_ENV]get_env resume resume = NULL booting linux @ 0x80008000, ramdisk @ 0x84000000 (634549) [LEDS]LK: leds_deinit: LEDS off [LEDS]LK: red level is 0 [LEDS]LED PMIC#6:0 [LEDS]LK: green level is 0 [LEDS]LED PMIC#7:0 [LEDS]LK: blue level is 0 [LEDS]LED PMIC#6:0 DRAM Rank :1 DRAM Rank[0] Size = 0x40000000 cmdline: console=tty0 console=ttyMT0,921600n1 root=/dev/ram lcm=1-qp08_changcheng_tm097b3 fps=4727 lcm_type=0 pl_t=403 lk_t=1265 printk.disable_uart=1 boot_reason=4 lk boot time = 1265 ms lk boot mode = 0 lk finished --> jump to linux kernel
Uncompressing Linux... done, booting the kernel. <hit enter to activate fiq debugger>
Не грузит ядро?
MoneyBot
Заголовок сообщения: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз |
MoneyBot
kalipso
Заголовок сообщения: Re: Prestigio MultiPad 4 Ultra quad 8.0 3G pmp7280c 3g quad вечный перезагруз  Добавлено: 06 янв 2018, 21:39 |
| Я тут случайно |
Зарегистрирован: 05 янв 2018, 01:26 Наличности на руках: 29.00
Сообщения: 15 Откуда: волгоград
serjick писал(а): С неё пересадил Samsung 8Гб. Прошил - всё завелось. Всем спасибо. Закрываю Все верно память сдохла!
